Detailed Product Images for the Off the Shelf Items
texkb
The company I work for is certified under ISO 13485 and for our product we have some specialty pieces and other items such as electronic components are just off the shelf items. For our specialty pieces we have detailed product drawings and specs. But for the off the shelf items we do not keep detailed product drawings as we are currently operating under the assumption that since it is an off the shelf part that we will accept the manufacturers description of that part. My question then is can we operate under that assumption that since it is an off the shelf item(s) we will adopt the suppliers detailed specs for that item(s) as our detailed specs or do we need to defined the specs for those off the shelf item(s) such as electronic pieces on our own?
Ronen E
Problem Solver
Moderator
It all depends on the criticality of the component. A risk analysis could help determine what characteristics (if any) of any component are important and how a deviation in them would affect these components' function and the device in whole.
I'd say that for a component deemed critical you must at least have the supplier's formal specification in YOUR files, as detailed as you can get it. For any characteristic deemed critical you must either have the supplier's specification for it, or, if not available, document in your system (be it in a drawing or in any other clear way) what are the acceptable limits to ensure proper function. Once you have all the above documented, this should be the basis for the contractual engagement with the supplier. For any component deemed critical for the device, you also better include a clause stating that the supplier must notify you in writing and in advance of any significant change in the above critical characteristics.
For all components deemed non-critical I would just try to get the supplier's standard specification (it's always good to have it on file, no matter the level of detail), and include a requirement to notify of significant changes within a reasonable time frame.
Cheers,
Ronen.
K
kgott
In case this helps. I recently worked for a company that built transportable accomodation. We provided our customers with data sheets from the suppliers of washing machines, air conditioners etc which for us; were off the shelf items.
E Steelmaking NCR Reports - Product has no custumer or detailed specifications Manufacturing and Related Processes 1
R DMR or Manufacturing Documentation - How detailed does the documentation have to be? ISO 13485:2016 - Medical Device Quality Management Systems 1
D Are detailed engineering requirements Design Inputs or Design Outputs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
G VDA 6.3 Automotive Audit with detailed questions Audit Questionnaire Process Audits and Layered Process Audits 8
QMMike Software to Record Detailed Final Audit / Inspection Data Software Quality Assurance 2
V ISO 9001 Detailed documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
U How detailed do Procedures and Flowcharts need to be ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M How detailed should procedures be if standards or guidance documents exist? Document Control Systems, Procedures, Forms and Templates 10
L Requirement to write a Detailed Inspection Plan (DIP) APQP and PPAP 5
C Detailed NQA-1 Audit Checklist Other ISO and International Standards and European Regulations 1
R Medical Device Software Segregation and Detailed Design IEC 62304 - Medical Device Software Life Cycle Processes 10
D Generating a detailed Process Plan - Help needed Process Audits and Layered Process Audits 6
M AS9100 5.6.2(c) Review Input: Process Performance - Detailed explanation needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S AMS 2750 rev E - Changes Detailed - Work In Progress Manufacturing and Related Processes 13
G Detailed Project Plan for Implementing AS9100C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
Q How detailed should Process Maps be? Process Maps, Process Mapping and Turtle Diagrams 7
B I'm trying to write detailed Customer Service Work Instructions Customer Complaints 10
T AS9100C Work Instruction Clarification - How detailed should a Work Instruction be? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
S Audit on Manufacturing Processes - a) Audit Checklist, and b) Detailed Audit Report Process Audits and Layered Process Audits 13
apestate Are detailed blueprints or CAD drawings of aircraft available? Federal Aviation Administration (FAA) Standards and Requirements 7
D Do all Non Conformance Reports need a detailed Root Cause Analysis? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
A Process Mapping - for "Audits" - Detailed process map + macro map + FMEA Process Maps, Process Mapping and Turtle Diagrams 10
S Structure for Implementing ISO 9001 - Detailed action plan of the significant steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Cl 6.3, Infrastructure - How detailed I should get with this clause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A RoHS Compliant Declaration - General or Detailed? RoHS, REACH, ELV, IMDS and Restricted Substances 6
S A detailed ISO 17025 'Table of Contents' ISO 17025 related Discussions 9
J Training Records - How detailed? ISO 13485 Requirements Training - Internal, External, Online and Distance Learning 7
G Control Plans vs. Detailed Routings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Quality System Process Map - Is this too detailed or not enough detail? Process Maps, Process Mapping and Turtle Diagrams 77
D How detailed should an equipment maintenance record made by engineer be? Records and Data - Quality, Legal and Other Evidence 5
K Need DETAILED Procedure Template for Dental Insurance Co. Document Control Systems, Procedures, Forms and Templates 21
D Detailed Six Sigma Case Study Needed Six Sigma 9
R Good Manufacturing Practices - How you document your GMP's - GHP's and how detailed US Food and Drug Administration (FDA) 8
T Sarbanes Oxley Act (SOX) linkage to a documented QMS - Detailed Procedures Required? Document Control Systems, Procedures, Forms and Templates 21
W Writing Reports - Giving detailed information on a Continuous Improvement Project Quality Tools, Improvement and Analysis 2
A How to Calibrate a Vernier Caliper - Detailed Procedure General Measurement Device and Calibration Topics 25
M Data submittal for surveillance audit - Detailed list of documents requested IATF 16949 - Automotive Quality Systems Standard 7
K Control Plan - Does not replace information in detailed operator instruction FMEA and Control Plans 1
M Quality Manual - Our current one is too detailed. Suggestions appreciated! Quality Management System (QMS) Manuals 25
Marc Root Cause Analysis and ISO 9001 - An excellent detailed discussion Problem Solving, Root Cause Fault and Failure Analysis 7
J Work Instructions - How detailed do work instructions need to be? QS-9000 - American Automotive Manufacturers Standard 6
G Process Flow Diagrams - How detailed the PFD has to be QS-9000 - American Automotive Manufacturers Standard 3
H Medical device Product Registration Registrars and Notified Bodies 2
A Can a power Supply be an accessory to a medical device, if it is an 'off-the-shelf' product. IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Extension to shelf life of new product under MDR EU Medical Device Regulations 1
lanley liao Are there guidelines for application of all API monogrammal product? Oil and Gas Industry Standards and Regulations 2
S ISO 11137- Simulated product vs SIP Other Medical Device Related Standards 2
K "World Class Product" based QM. I need advice. Quality Management System (QMS) Manuals 14
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 0
William55401 Distributed By Product - Best Practices for Configuration Management and Purchasing Controls ISO 13485:2016 - Medical Device Quality Management Systems 0
