Detecting non-visible defects in machined brass - Where to start?
ScottK
Not out of the crisis
OK - I'm totally new to nondestructive testing so I'm looking for a starting point here.
Here's the situation - we've seen a significant increase in subsurface defects in half hard C36000 Brass rod. We've run across more inclusions during machining in the last two months than the owner has seen in 14 years.
To make matters worse, it's all of our suppliers. It's not narrowed down to a single supplier/heat/batch/whatever.
And some of our parts are for use in pretty high pressure applications.
None of our suppliers are being very supportive other than giving us our money back for the bad lots.
Needless to say we're terrified of the liability the failure of a high pressure valve could bring
So I've been tasked with researching testing alternatives -
Buy equipment? What kind?
Find a test lab?
Can you test machined brass parts for non-visible cracks, gaps, inclusions, etc?
TIA for any advice
errhine
Involved - Posts
Re: detecting non-visible defects in machined brass... where to start?
Any reason you couldn't do non destructive testing with ultrasound? There are many NDT methods used in aerospace, that are available, I dont see why they can't be used in other industries.
Cari Spears
Have you sent any of the material to a metallurgical lab for independent testing?
ScottK
errhine - I've just got a call from a guy that sells ultrasonic testing equipment - so I guess that's avenue 1.
Cari - No, we have not. Are there any labs you might recommend?
thanks!
antho10359
Since this problem is across multiple lots and multiple suppliers ... the only common denominator is the process. Have your storage facilities changed. (Too Hot or Cold) Have any process changes been made or personnel changed. Does the problem come and go ... happen on only one shift... Just a thought
True Position
If they are non-visable but surface you could look at die penetrant.
If they are sub-surface your may be looking at ultrasonic. Why bother with radiographic if UT would do the job? Also, I dunno if Eddy Current would work, but that's another relatively quick inspection.
Here's my favorite web site on NDT, the community college level descriptions:
http://www.ndt-ed.org/EducationResources/CommunityCollege/communitycollege.htm
One thing with NDT, is most customers will want certified level two techs to perform all inspections. With UT, you need many hours of practice, if I recall it's approximately 2,000 hours for Lvl II plus a number of hours of training.
Good luck
SteelMaiden
Good luck
You can set up eddy current to catch sub surface defects, but you have to have an "as produced" sample with a known defect to get the proper set-up. Might be easier to UT?
ScottK
Good luck
wow. that's a great resource... I can see how I'm going to spend my morning tomorrow.
:thanx:
K
Kevin H
I'm familiar with all the above suggested methods as they refer to steel - if your material was steel and the problem was non-metallic inclusions two methods come to mind - magnaflux (magnetic particle) testing, and destructive testing of a small sample by preparing a sample for metallographic analysis under a microscope to check inclusion levels. Once one is found, you might also want to have an SEM analysis to get a rough chemical composition to help detect the probable source.
Extrapolating to brass, my guess would be sampling incoming material and having someone do a metallographic analysis, and then rejecting/approving based on analytical results. I do not believe ultrasound, radiographic, or eddy current would detect an inclusion on a microscopic level. Either ultrasound or radiographic should be able to detect macro size defects.
Do you have any information as to size/chemical composition of the defects you're encountering?
Q Opportunities only derived from Risks? Detecting Risk & Opportunities in ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T Probablity of correctly detecting a defect size Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Richard Regalado ISO 27001 A.10.4.1 - Detecting, Preventing and Recovering from Malicious Code Threats IEC 27001 - Information Security Management Systems (ISMS) 3
P Difficulty in Detecting Within Lot Variation when using Zbar W (Normalize) Chart Statistical Analysis Tools, Techniques and SPC 14
K Seeking Methods of Detecting Microbe Food Safety - ISO 22000, HACCP (21 CFR 120) 10
Q Validation of X-RAY Process used in detecting voids in castings Qualification and Validation (including 21 CFR Part 11) 9
M Recommendations for detecting "Triangle Effect" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
E Accredited vs. non-accredited labs for 60601 compliance in the US IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Accredited vs. non-accredited labs for 60601 compliance in the US Other Medical Device Related Standards 0
L Water requirement for Non-sterile topical OTCs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
B Procedure packs with non-medical devices EU Medical Device Regulations 1
W Non Sterile Medical Device Environmental Tests Other Medical Device Related Standards 4
S Advice on how to reduce overhead of handling non-conforming material Nonconformance and Corrective Action 7
G Team to analyze a non conformance Customer Complaints 26
J Promoting and marketing of a non approved device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
G 0 non conformities in registrar audits over 4 years Management Review Meetings and related Processes 12
K CE Marking Class 1 (Non sterile) medical device CE Marking (Conformité Européene) / CB Scheme 3
S Non parametric test for semi-quantitative data. Statistical Analysis Tools, Techniques and SPC 5
B Free Sales Certificate for Non Medical Devices Other Medical Device Related Standards 2
P Ppk results shown as asterisk after the transformation of Non-normal data Using Minitab Software 4
I When is necessary to have RoHS declaration on non-electrical parts? REACH and RoHS Conversations 1
Johnnymo62 Non Aerospace topics - Anything for military trucks, trailers, Humvee type vehicles? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
G Dealing with non conformity caused by Supplier Components detected in the production line IATF 16949 - Automotive Quality Systems Standard 14
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
A FDA guidance on non-sterile Medical Device Packaging Medical Device and FDA Regulations and Standards News 7
E Qualification for non gmp service providers Supplier Quality Assurance and other Supplier Issues 1
R MDD x PPE Directive - Statement of Non-Applicability EU Medical Device Regulations 3
B Exclusions or justification for non-applicability of IEC standards Reliability Analysis - Predictions, Testing and Standards 1
C Non-EU Language Requirements Other Medical Device Regulations World-Wide 3
A Non-Conformances Found After 3rd Party Sorting Supplier Quality Assurance and other Supplier Issues 12
T ISO 13485 8.3 - Non-Conforming Materials - on-line rework or part of process? ISO 13485:2016 - Medical Device Quality Management Systems 11
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
D Using non-conforming components even though the final assembly is conforming? Manufacturing and Related Processes 5
N Competent Authority notification for non-EU manufacturer EU Medical Device Regulations 4
M CE marking for NON-EU EU Medical Device Regulations 0
E Non-GMP examples in Pharmaceutical industry Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
S Non-Conformance and Deviations ISO 13485:2016 - Medical Device Quality Management Systems 4
B Risk Assessment Checklist for Non product Software IEC 62304 - Medical Device Software Life Cycle Processes 1
T Ideas for developing a Supplier Quality Management System, non automotive ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
N Audit non-compliance - API Spec Q1 9th Ed 5.6.1.2 b Oil and Gas Industry Standards and Regulations 10
R Applicability of new non-harmonized standards (MDD/MDR) EU Medical Device Regulations 14
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Guidance on manufacturing non-surgical face masks US Food and Drug Administration (FDA) 3
D Do non-IATF customers need to be included in audit scope? IATF 16949 - Automotive Quality Systems Standard 23
C If it doesn't prevent a non-conformance, is it a preventive action? IATF 16949 - Automotive Quality Systems Standard 13
