Detection Action for Failure Effects - AIAG 4th Edition Layout
Cephissus
Dear all,
Sincere apologies if this was discussed before... I'm pretty sure it must have been.
So basically in the standard AIAG 4th Edition Layout we have two seperate columns for when the Detection Action is for the Failure Mode and when the Detection Action is for the Failure Cause.
What happens when the Detection Action is for the Failure Effect?
Where do we put that?
Thanks a lot for your support
Remember, an FMEA is a risk identification, prioritization and mitigation tool. The further upstream (failure cause) that a detection is used, the more effective the mitigation. If you are not trying to detect the failure cause or failure mode, you are not mitigating the risk. By conciously allowing the failure effect to occur, you are accepting the risk, not mitigating it.
GRP
Dear all,
The columns you describe do not seem familiar to me. In the AIAG 4th edition you have columns for prevention controls and detection controls.
The prevention controls act on the causes and/or failure mode and have an effect on the occurrence ranking. The detection controls act on the failure mode and determine the detection ranking.
If your "current controls" point toward the effect, then it is likely there is a mix up between failure mode, effect and cause.
If you can share some details of the line you are analyzing we can give it a go.
Marc
Can you attach a copy/picture of the form you're using?
Cephissus
Yes so let's consider the following hypothetical Failure Chain:
Too high pressure on the machine -> Too low Thickness -> Too high sound levels
For this failure chain, I could have detection actions aiming at:
- Controlling the pressure (at the Cause level)
- Controlling the Thickness (at the Mode level)
- Controlling the Sound (at the Effect level)
Since the Detection Actions column only has two options (Cause & Mode). What do I do with the 3rd one (Detection Action on Effect) ?
GRP
The 3rd column that you mention does not seem to appear above and I do not think it is featured in any of the 4th edition templates.
At any rate, a high pressure on the machine produces low thickness (product) and this results on high sound levels (due to low thickness), correct?
Function: to produce the part
Req: thickness [mm] (product)
Failure mode: low thickness (product)
Cause: low pressure in the machine (wrong setup? sensor malfunction? calibration off?)
Effects: high sound level (I assume this is the effect on the end user)
You are right to address detections of the cause and/or failure mode. You have an alarm for low pressure, or close loop control, or you have setup sheets, 1st piece check, variable/attribute gauging, and so on.
IMHO it makes no sense to discuss detection of the effect, being that the effect is what the end user (in this case) perceives or experiences. As such, the product is out there in the field. A detection of this would be through a complaint.
I would question the reason and value of including this detection type in the template.
Has anyone ever seen detection of the effect in the FMEA literature?
Ashok sunder Is it possible to reduce FMEA Occurrence and Detection Ranking after corrective action taken for customer complaints? FMEA and Control Plans 6
A Corrective Action vs. FMEA Occurance, Detection, Severance Nonconformance and Corrective Action 5
P Design FMEA - Detection Rating criteria ISO 14971 - Medical Device Risk Management 3
I Does anybody use Detection in medical device Design FMEA? ISO 14971 - Medical Device Risk Management 18
A Literature review/HACCP validation of metal detection Food Safety - ISO 22000, HACCP (21 CFR 120) 0
Jimmy123 FMEA - Preventive vs Detection Control FMEA and Control Plans 7
B Detection of Orange peel Manufacturing and Related Processes 3
C PCBA Hardware Component different failure types - How to rate detection? FMEA and Control Plans 8
P Detection rating for a user (surgeon) related failure mode in DFMEA APQP and PPAP 3
S Are Defibrillator Protection and Pacemaker pulse detection features mandatory as per IEC 60601-2-25 or 2-27...? IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
D How to fill a Process FMEA - Three columns - Severity, occurrence and Detection FMEA and Control Plans 16
R DFMEA Severity 9-10 with Occurrence 3 and Detection 3 - Actions FMEA and Control Plans 3
K Creating together Standard Definition for Prevention and Detection FMEA FMEA and Control Plans 1
Q PFMEA Scope and Detection Controls FMEA and Control Plans 1
D Signal Detection-If Ppk>1, compare measurement system to process. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L Environmental Gas Leak Detection Equipment Recomendations Miscellaneous Environmental Standards and EMS Related Discussions 2
J Control Chart Pattern Detection Statistical Analysis Tools, Techniques and SPC 3
M Changing FMEA template to include Detection Ranking for the PFMEA FMEA and Control Plans 2
C How to evaluate the Detection Ranking of a new Design Control FMEA and Control Plans 1
C Poka Yoke and FMEA Detection Ranking FMEA and Control Plans 3
K 4th Edition AIAG FMEA Occurrence, Severity and Detection Criteria for Plastics FMEA and Control Plans 1
Z PFMEA Detection Controls and Ranking - Prevent Shipment FMEA and Control Plans 3
S PCR suitable for detection of Salmonella Food Safety - ISO 22000, HACCP (21 CFR 120) 1
S FMEA Visual Inspection Detection Rating FMEA and Control Plans 5
J Moisture Detection and Measurement in Vacuum Oven (Plastic Dryness) General Measurement Device and Calibration Topics 2
E MSA of Attribute Gauges Signal Detection Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Calibrate Hole Presence Detection Device? General Measurement Device and Calibration Topics 5
T Root Cause - The difference between Occurence and Detection Problem Solving, Root Cause Fault and Failure Analysis 3
G Determining the "Detection" Number Component of the FMEA RPN FMEA and Control Plans 5
X Computer-Aided Detection for Mammography - Class A, B or C? IEC 62304 - Medical Device Software Life Cycle Processes 5
K Are 'Work Instructions' a Detection Control or Prevention Control? FMEA and Control Plans 8
P Removing Detection from DFMEA - Medical Device company using ISO 13485 FMEA and Control Plans 3
G ISO Registrars/CBs citing for use of "Detection" in Risk Management ISO 14971 - Medical Device Risk Management 27
R FMEA Detection Ranking for Testing Machines FMEA and Control Plans 8
S WEC/Nelson Detection Rules: Must process be in control? Statistical Analysis Tools, Techniques and SPC 1
K Defect Detection for Fresh Injection Molding Solid Parts Manufacturing and Related Processes 5
B "Detection, NOT Prevention!" - Relying on Final Inspection Quality Manager and Management Related Issues 48
M Customer requires Controls Detection to match Control Plan Control Method FMEA and Control Plans 2
M DFMEA Detection Ranking in AIAG FMEA Manual 4th Ed. - Explanation wanted IATF 16949 - Automotive Quality Systems Standard 6
Rameshwar25 Signal Detection Method Zone Classification Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S MSA with Non Replicable Samples Measured at Detection Limit Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
A PFMEA (Process FMEA) Detection Rating - Actions to Reduce RPN FMEA and Control Plans 3
L FMEA Occurrence, Severity and Detection Criteria FMEA and Control Plans 3
V Detection ranking in FMEA FMEA and Control Plans 4
P Detection Rating in PFMEA and Process Controls FMEA and Control Plans 6
S Charting Detection Limit Data Statistical Analysis Tools, Techniques and SPC 2
K Design FMEA Detection Scoring - FMEA 3rd edition manual FMEA and Control Plans 7
Q FMEA: Visual Detection Rating IATF 16949 - Automotive Quality Systems Standard 25
