Detection rating for a user (surgeon) related failure mode in DFMEA
Hi Guys
I have a question about detection rating for a user related failure mode in DFMEA.
This failure happens if the surgeon is not following the instructions provide in 'info for use'.
I could not find any relevant thread so am posting here. Let me know if this thread is not appropriate.
Here is the scenario...
The product is a medical device (For reference the severity rating is 9 and occurrence rating is 4 based on actual complaints received.
The only controls we have in place are the instructions about the following in 'information for Use':
1. what sort of experience the surgeon should have.
2. what should be done by the physician during the operation to avoid this failure mode.
What sort of detection rating should be given to these type of controls.
The detection rating table which we have is not very helpful.
Desikiwi
GRP
Hi Guys
Desikiwi
Medical is not my field, but I see you could check the Hazard Analysis in ISO14971 Medical devices -- Application of risk management to medical devices.
At any rate, and in general terms when dealing with FMEA, detection rankings are relative entries in a table you yourself can build or adapt. The extremes are obviously something like detection ensured and no detection. If you already have knowledge from best practices in your industry or if you can benchmark from applicable fmeas, decide how many steps to use between extremes. In the automotive industry it is common to use 10 steps. Although you will find sources recommending as few as possible, say 5.
How does this detection compare with other detections given in the fmea? It is very important to rank your failure modes consistently. The numbers will not point to any objective quantity, but will help designers to prioritize issues.
Until someone in the Cove with medical experience jumps in, I can only offer for you to share your detection rating table and compare concepts with reputable automotive sources.
Kevin Mader
One of THE Original Covers!
Why is the surgeon not following the IFU? Overlooked? Or the device is being used off label? (foreseeable misuse?)
It's hard to say much about the assignments of risk without the tables to evaluate. If your table descriptions aren't operational enough, then you might need to recreate better definitions of risk and re-estimate the risk values that you have assigned. As GRP notes, you are after reasonable continuity throughout the exercise. In my risk documents, I like to list all the assumptions that the team operated on for future reference. Details on how you arrived at a definition should be recorded as well (especially where things aren't as obvious; in between the extremes so-to-speak). Start with the AIAG definitions and tailor to suite your business and perhaps the design.
Generally speaking, clinical personnel are better trained and educated (physicians/surgeons). But perhaps your failure mode has nothing to do with mental acuity and is more related to other limitations (sight, sound, physical ability, etc.). What I'm saying is that their ability to read and understand your IFU may not factor much into avoiding the failure mode. Keep that in mind if that's the case. Leverage standards that are available to you (e.g., Human Factors). You may find a golden nugget to solve some problems/answer questions. And leverage you Clinical personnel; they should be able to render reasonable explanations on mitigations presented.
Come back to us if you have more questions. Good luck!
P Design FMEA - Detection Rating criteria ISO 14971 - Medical Device Risk Management 3
S FMEA Visual Inspection Detection Rating FMEA and Control Plans 5
A PFMEA (Process FMEA) Detection Rating - Actions to Reduce RPN FMEA and Control Plans 3
P Detection Rating in PFMEA and Process Controls FMEA and Control Plans 6
Q FMEA: Visual Detection Rating IATF 16949 - Automotive Quality Systems Standard 25
Chennaiite PFMEA rating - Occurence Rating and Detection Rating - Some clarification FMEA and Control Plans 15
I FMEA Detection Rating - What is Soft or Hard? FMEA and Control Plans 7
V Detection rating for visual inspection in PFMEA FMEA and Control Plans 19
P The Origin of the FMEA Detection Rating FMEA and Control Plans 7
M PFMEA Detection Rating for Operator Hazards FMEA and Control Plans 5
J DFMEA SOD Rating Scale - Severity, Occurance, and Detection FMEA and Control Plans 1
F pFMEA Detection Rating Scale - No automated inspections FMEA and Control Plans 5
E FMEA Severity, Occurrence, and Detection Rating - I am in need of some examples FMEA and Control Plans 19
G Assignation of RPN rating (Detection) on Visual Inspection where subsequent operation FMEA and Control Plans 18
J PFMEA Controls - Rating Prevention, Detection and Occurrance FMEA and Control Plans 10
G Detection Rating in Design FMEAs (DFMEA) FMEA and Control Plans 2
A Does the Detection rating have anything to do with Prevention? FMEA and Control Plans 3
T RPN Thresholds and How Detection Fits In ISO 14971 - Medical Device Risk Management 5
I Does anybody use Detection in medical device Design FMEA? ISO 14971 - Medical Device Risk Management 18
A Literature review/HACCP validation of metal detection Food Safety - ISO 22000, HACCP (21 CFR 120) 0
Jimmy123 FMEA - Preventive vs Detection Control FMEA and Control Plans 7
B Detection of Orange peel Manufacturing and Related Processes 3
C Detection Action for Failure Effects - AIAG 4th Edition Layout FMEA and Control Plans 5
C PCBA Hardware Component different failure types - How to rate detection? FMEA and Control Plans 8
S Are Defibrillator Protection and Pacemaker pulse detection features mandatory as per IEC 60601-2-25 or 2-27...? IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
Ashok sunder Is it possible to reduce FMEA Occurrence and Detection Ranking after corrective action taken for customer complaints? FMEA and Control Plans 6
D How to fill a Process FMEA - Three columns - Severity, occurrence and Detection FMEA and Control Plans 16
R DFMEA Severity 9-10 with Occurrence 3 and Detection 3 - Actions FMEA and Control Plans 3
K Creating together Standard Definition for Prevention and Detection FMEA FMEA and Control Plans 1
Q PFMEA Scope and Detection Controls FMEA and Control Plans 1
D Signal Detection-If Ppk>1, compare measurement system to process. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L Environmental Gas Leak Detection Equipment Recomendations Miscellaneous Environmental Standards and EMS Related Discussions 2
J Control Chart Pattern Detection Statistical Analysis Tools, Techniques and SPC 3
M Changing FMEA template to include Detection Ranking for the PFMEA FMEA and Control Plans 2
C How to evaluate the Detection Ranking of a new Design Control FMEA and Control Plans 1
C Poka Yoke and FMEA Detection Ranking FMEA and Control Plans 3
K 4th Edition AIAG FMEA Occurrence, Severity and Detection Criteria for Plastics FMEA and Control Plans 1
Z PFMEA Detection Controls and Ranking - Prevent Shipment FMEA and Control Plans 3
S PCR suitable for detection of Salmonella Food Safety - ISO 22000, HACCP (21 CFR 120) 1
J Moisture Detection and Measurement in Vacuum Oven (Plastic Dryness) General Measurement Device and Calibration Topics 2
E MSA of Attribute Gauges Signal Detection Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Calibrate Hole Presence Detection Device? General Measurement Device and Calibration Topics 5
T Root Cause - The difference between Occurence and Detection Problem Solving, Root Cause Fault and Failure Analysis 3
G Determining the "Detection" Number Component of the FMEA RPN FMEA and Control Plans 5
X Computer-Aided Detection for Mammography - Class A, B or C? IEC 62304 - Medical Device Software Life Cycle Processes 5
K Are 'Work Instructions' a Detection Control or Prevention Control? FMEA and Control Plans 8
P Removing Detection from DFMEA - Medical Device company using ISO 13485 FMEA and Control Plans 3
G ISO Registrars/CBs citing for use of "Detection" in Risk Management ISO 14971 - Medical Device Risk Management 27
