G
Geoff Lee
Detection Rating d-FMEA
I am implementing FMEA in design and development of appliances. I find Occurence ratings to be fairly self-explanatory. Also, Severity ratings seem to be described in understandable terms; degrees of performance degradation, operability, dissatisfaction of user, hazard etc. These enable a group to fairly readily reach consensus on ratings.
However, most Detection rating scales are less helpful. They tend to have a few distinctive descriptions at the extremes of the scale, for example 1="can be corrected prior to prototype", 10="None" etc. However, for the main part, they seem to have a sliding scale from, for example, 8="lowest effectiveness" to 2="highest effectiveness". Such sliding scales do not lead to ready consensus amongst an FMEA team. Nor, as a leader, can I provide effective guidance on where a particular method might lie on such a scale.
It seems to me that a Detection method should have several characteristics:
1 ability to detect whether the failure mode does occur
2 verify what causes it
3 determine its level of occurence (i.e. provide a degree of confidence in the Occurence rating)
So, I would hope that a set of Detection scale descriptions could be generated which might be framed in these, or similar, terms. For example, we might have:
1="Proven detection of failure mode from all causes, with accurate measure of occurence"
5="Detects failure mode in most cases, provides good guidance on occurence"
Does anyone know of any such Detection scales or have any comments on this issue?
Thanks,
Geoff
Thanks,
Geoff
