I like the concept of "waste" and "unnecessary" waste. Let us also consider the concepts of "justified capital expenditure" and "rejected capital expenditure". Here we go:
$1 = per piece cost of 100% final inspection (finding 0.5% failures)x 8000 / year
$8,000
$240 = per piece cost of a failure reaching the customer x 8000 / year @ 0.5%
$9,600
This is necessary waste "saving" me $1,600 per year plus 40 failed units in the hands of customers. The circuit board is first assembled by machine (near flawless), then assembled by hand (about half of the failures are generated here). Finally, the board is assembled into a housing that protects it from the environment and also serves as a heatsink.
Now, given $8,000 per year of "waste", this is what the lean hype guys have to work with in order to justify capital expenditures on mistake-proofing. They all have the magic until they realize that any further mistake-proofing is going to take either automation and/or serious design changes to allow for automation. After that, they disappear into the woodwork.
Second lesson:
$4,800 = $60 per hour x 1 hour per board x 5 boards per unit x 16 units per month cost to pre-test circuit boards 1 by 1 to assure 0 defects at final test so that some "lean genius" can eliminate "unnecessary" final test and rework.
$960 = $40 per hour x 1 hour per unit x 16 units per month cost to final test only +
$180 = $60 per hour x 3 hours per defective unit x 1 defective unit per month cost to troubleshoot the 1 defective final unit each month (93.75% yield, how terrible).
Now, that's $4,800 vs. $1,140 to assure that no defective units reach the customer. Would you believe that our "lean" VP was actually going to implement board level test? Only when I pointed out that we still would not save the $960 did he back off this position: 90% of "final test" was actually establishing traceability of the measurements (while making sure that they were correct) so that we could issue the calibration certificates that every customer required.
