Determining Internal Audit Frequency - ISO 9001 Clause 8.2.2.4
I am a little unsure how to interpret the requirement for the frequency of audits as required by TS16949 clause 8.2.2.4.
It indicates that an Annual Plan is required and all processes, activities and shifts are scheduled in accordance with the plan.
It may seem obvious that they have to be covered within the annual plan however the I am suspicious of the wording in the standard.
Any help would be appreciated.
Sidney Vianna
Post Responsibly
Looks like this is your first post. Welcome to the Cove.
You did, however, mixed up ISO 9001 and TS-16949. There is no 8.2.2.4 in ISO 9001. You are reading TS. And, indeed, TS requires an annual audit plan.
F
fuzzy
Welcome to the Cove! While this may seem to be a trick requirement:notme: , I find that we often think only of the minimum, hence the standard just requires your plan to show the frequency (unspecified). For me under an ISO plan, I choose to audit certain processes more than once annually, based on previous audit findings in that process or clause. Throw in the TS mention of shifts, and this complicates the schedule; must be why they call it a plan:confused:
I'd suggest that you take a look at ISO 9004:2000. It makes interesting reading and, therefore, an opportunity to deal with scheduling audits in a flexible manner. It is quite usual to have a whole calender of audits, say 1/month. Certainly, there are some items of the quality system which should be audited around scheduled events. For example, if you know when a registrar auditor is going to be visiting, then it makes sense to perform an audit (just) prior to that visit. Like cleaning house before family come to stay!!
In most other respects, your audit scheduling should be based on 'status and importance' of the activity or process. There have been other posts here regarding this, but in a nutshell, it could mean using audits to look at processes which are 1) performing under expectations (of customer or the business) and 2) new situations, such as new customers/requirements, new suppliers, new processes, equipment etc.
New = risky, generally speaking.
The aim of the audit is to let management know what the status of the process is, during this risky time. Management is likely to appreciate the results of the audit much more, than if there is a 'random' reason for the internal audit being scheduled.
So, although the TS requirement sounds like you need to have all this planned out in advance, I've had success in choosing a frequency of 'monthly' and defining the 'scope' and 'criteria' of the audit 30 days before doing the audit, based on status and importance, and of course any previous audit findings........
Andy
I always use this method to define audit frequency:
Your comments would be appreciated.
It's an interesting idea. I think it may make setting a frequency too complicated and doesn't take into consideration other factors which might influence the decision to perform an audit.
As mentioned in my previous post, when something is changed or it is new, then it's a good opportunity to use the audit to discover how the management system is performing. My suggestion is that a frequency of (say) a month is selected, and then based on various factors, the focus of the audit is chosen during the days/weeks before the next audit is scheduled. You can also perform more, but at least you'll have a minimum frequency of audits to prevent being writen an NC by a registrar.
Instead of using a 'grading' system, ask your management team what they would select to audit. That's almost what it says in ISO 9004..........
Andy
brahmaiah
Dear every body,
When you are on a job of maintaining ISO9001 OR TS16949 OR ISO14001 OR for that matter any other standard system,donot mix up requirement of one standard with another.This happens often when you deal with
ISO 9001and TS16949.
ISO 9004 is a very good standard. But my advise to all is not to read it more than once in their lifetime.Because you tend to mix up 9004 requirements with other living systems.ISO 9004 is a perfect system but impossible to executive in your bussiness and still make profits.
some of the obsolete requirements of good old iso9000-1974 or is it 1984 are still haunting me during carrying out an audit
Forgive me if I sound imperfect!
Good luck!
V.J.Brahmaiah:agree:
Jen Kirley
Quality and Auditing Expert
This is a sound method for starters, but I wouldn't audit a process more than once per year unless there was a problem with it. Some processes can be audited more than one year apart.
Speaking of problems, I will add to the schedule an audit with a process that has undergone work recently, especially if it had a significant corrective action. So, per this theory (time frames are largely your choice within the registrar's requirement) a process that would have skipped a year might be audited once per year until satisfied it is stable.
Likes: db
V
Voodoo Queen
The entire system must be audited each year. I agree with AndyN's approach, although I prefer a quarterly schedule. If I find a major discrepancy I'll return to that area with my next go-around.
Thanks for the comment, but where do you find that you have to do the whole system each year? Does your CB require this?
A Determining the number of Internal Audit Man-Days Internal Auditing 15
C Internal Audit Sampling Plans - Determining Internal Audit Sample Size Internal Auditing 45
F Determining what type of scrap to include in my internal PPM calculation Quality Manager and Management Related Issues 5
R Question on determining defective units - I am not recording fixture to part rejected Statistical Analysis Tools, Techniques and SPC 5
S Clause 8.2.2 Determining the requirements for products and services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Determining FDA 820 (registration) vs ISO 13485 - Supplier gives us the kit ISO 13485:2016 - Medical Device Quality Management Systems 1
J ISO 9001 8.4.1 - Determining controls applied to externally provided processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
E Determining what is good and what is bad can be subjective - when is it a quality issue? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Determining number of employees within the "Scope" of the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Determining the Scope of the QMS during Stage 1? Registrars and Notified Bodies 11
W Minor Audit Nonconformance Against Determining the scope of QMS IATF 16949 - Automotive Quality Systems Standard 12
D Determining Critical Components for conformity with IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 21
Q ISO 9001, section 4.3 Determining the scope of our QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A What does 8.2.2.1, Determining the requirements related to products and services,mean IATF 16949 - Automotive Quality Systems Standard 1
A Determining Retention Period for Medical Device QMS documents Document Control Systems, Procedures, Forms and Templates 5
F ISO 9001:2015 4.3 - Determining the scope of the quality management system ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Standards Needed In House - Determining what standards are applicable Various Other Specifications, Standards, and related Requirements 3
W Determining Medical Device Classification in Mexico Other Medical Device Regulations World-Wide 5
K Determining Effect of Failure without a DFMEA (Design FMEA) FMEA and Control Plans 1
W Determining the Status and Importance of the Processes and Areas to be Audited Internal Auditing 7
T Determining Customer Requirements for the US Postal Service (USPS) IATF 16949 - Automotive Quality Systems Standard 4
Crimpshrine13 Rules of achieving and maintaining IATF recognition - Determining audit days IATF 16949 - Automotive Quality Systems Standard 2
R Developing procedure for Determining Company's Context And Interested Parties ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 53
W Determining Asset Life or Depreciation Life for M&TE General Measurement Device and Calibration Topics 1
N Reason for determining no adverse effect on reworked product ISO 13485:2016 - Medical Device Quality Management Systems 8
N Procedure for determining pinhole position in condom Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
alonFAI Determining PCBA Xray Test Sampling Size Statistical Analysis Tools, Techniques and SPC 1
R Determining the feasibility/scope for FDA IQ/OQ against a very simple application US Food and Drug Administration (FDA) 2
