Determining Sample Size and Method
I am new to this forum. I work for a dietary supplement manufacturing company. We primarily make powders that we fill in jars. We have a QA department and they do quality checks on the filling and bottling process hourly. QA will go into the room and randomly check jars for weight and seal compliance. There is no "set" number of how many jars are checked at this point. If no unsealed jars are found that hour , production continues. If unsealed jars ARE found, production stops and we adjust. Plain and simple. We are trying to advance our QA Program and want to implement a sampling plan that is more credible and valid. I realize that we need to calculate what a valid sample size would be. To go into further detail, we have been having issues finding jars that have not been properly sealed after the induction process. Currently if QA goes into do an hourly check and a bunch of jars are found to be not properly sealed, we stop the line and adjust whatever it is that we need to . Sometimes it is because the induction sealer got moved , sometimes it because the capper randomly decided to act up. That product is then reworked later and we continue as described...hourly checks...if we find jars to be unsealed we stop the line and adjust. What methods or sampling methods are out there that would help us determine how many jars we need to be checking an hour? Where do we start with not much data on the defect rates? I've looked up AQL but it doesn't seem to apply as we do hourly checks. I have also found calculators that tell you valid sample size and I have split that number by how many hours we are doing production. Nothing is really "making sense" for what type of sampling plan I need. Any suggestions would be greatly appreciated.
Depending on what we are making , I would say about 2000 units an hour average. We are just now starting to collect data on defects. Is that what you mean by reject rate? We are simply doing hourly checks and stopping the line if we are finding they are not sealed all the way , fixing the problem and running again. I would say in a typical run we could end up reworking about 200 jars for seals. We check boxes of sealed product and if 5 or more are found to be open we move the whole box aside to rework later. Boxes aren't very large. Really there is no ryhme or reason to how we are sampling. So far I collected data on one product and the defect rate in seals was 1.33%. This is what we found by random hourly sample checking as defective for seals. Not sure how to proceed with this information.
Beth Savage
Helping organizations optimize quality
PQ Systems
The frequency of sampling should occur at least as often as the process is expected to change. Examine all the factors that are expected to cause change (sealer, capper, etc.). To be effective, sampling must occur at least as often as the most frequently changing factor in the process. If it is not clear how frequently the process changes, then collect data often, examine the results, and set the frequency accordingly. It is better to start off sampling more often than may seem necessary, and reduce the frequency based on what you learn, than to sample too little.
Steve Prevette
Deming Disciple
This could actually be a very expensive and fruitless policy. Yes, plain and simple. but could be just simply wrong. Odd that I have another thread going on SPC limits, and invoking Dr. Deming's red bead experiment, and also we need to invoke the (lesser known) funnel experiment. If indeed there is a stable process creating unsealed jars, stopping the line after an individual result and searching for a unique answer COULD BE ineffectual, and worse, could be making the process worse (as predicted by the funnel experiment).
On the overall question of sample size, I'd suggest that the periodic results from whatever sample size you are currently using be plotted on a control chart, and see if the percent defective remains stable (and predictable) or if there are signals of special causes. The old MIL STD 105 did have some reasonable sample sizes for continuous processes, though you do have to declare a "batch size". A primary driver for sampling on a continuous process is to answer the question - how many defective product are you willing to make before you detect an issue?
Scanton
Wearer of many hats
I use (and have used for decades in various industries) an AQL sampling standard based on ISO 2859 for my final inspection. This isn't going to fix all your problems however it will allow you to quickly put something in place that will be more effective than random sample guesswork, and give you some sampling data to analyse.
Now I know I am probably going to get lambasted by more informed members of the forum by suggesting the use of a sampling standard without doing any initial analysis on the process, however my personal belief is that putting some structured sampling in place now and refining it when you understand more about the process would be better than waiting until that analysis is completed, to then take action.
I found this - Explaining Acceptance Quality Limit (AQL) for product inspection:
https://www.eurofins.com/assurance/consumer-products/resources/articles/explaining-acceptance-quality-limit-aql/
Ron Rompen
Scanton, I agree with you completely. Whether you choose ISO 2859 or MilStd 105 or some other sampling plan, at least it is a beginning. Choose SOME method of consistently sampling product, collect data, and then take action(s) that are appropriate - the PDCA cycle works for this as well as anything else.
rmyjq
There are so many pulibhsed theories and standards for sampling. ISO 2859 or MiStd 105 are so old and maybe fall behind the times.
There are many new sampling theories come into public awareness, for your production, ISO 28593: 2017 will be much suitable, you can calculate the sample size simply for any time period.
B Bayes Success-Run on Attribute Data - Determining Sample Size Statistical Analysis Tools, Techniques and SPC 2
A Determining Sample Size in Design V&V activities 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 44
G Determining Sample Size for Equipment Qualification Studies Qualification and Validation (including 21 CFR Part 11) 10
D Determining Sample Size for Capability in Six Sigma Project Six Sigma 5
H Determining the Correct Sample Size when AQL points to two Sample Sizes AQL - Acceptable Quality Level 7
L Determining Cpk based on a given Sample Size, Confidence Level, & Reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Determining Sample Size needed for Operational Qualification (OQ) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 24
T Determining the appropriate Sample Size using an AQL Table Inspection, Prints (Drawings), Testing, Sampling and Related Topics 31
J Functional Test Sampling - Determining Sample Size to eliminate 100% Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
W Sampling Plan problem - Determining Sample Size for both Attribute and Variables Data ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Determining the Total Sample Size using AQL - AQL Lot Quantity question AQL - Acceptable Quality Level 8
1 Determining AQL and Sample Plan - Batch size is from 1-500 AQL - Acceptable Quality Level 24
E Determining Sample Size for Design Verification and Design Validation Other Medical Device and Orthopedic Related Topics 20
N Auditing Proof of Delivery signed by the customer - Determining Sample Size General Auditing Discussions 6
P Determining Sample Size - Filling a bag with three different types of candy Inspection, Prints (Drawings), Testing, Sampling and Related Topics 31
Q Determining Sample Size for FDA Verification and Validation Activities Inspection, Prints (Drawings), Testing, Sampling and Related Topics 41
D Determining sample size required based on a 95% confidence level Reliability Analysis - Predictions, Testing and Standards 7
B Determining sample size for drop test and waterproof testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
T Determining Receiving Inspection Sample Size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
N Determining Sample Size for Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C Internal Audit Sampling Plans - Determining Internal Audit Sample Size Internal Auditing 45
Q Determining the Appropriate Sample Size for Process Validation/Qualification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
T Using Cpk for the purpose of determining sample size/frequencies Capability, Accuracy and Stability - Processes, Machines, etc. 2
G Determining Sample Size and Frequency for Features on Control Plans FMEA and Control Plans 8
U Determining population defect rate from sample defect rate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
R Determining Sample Sizes for Testing (Chemistry or Microbiology) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
B Selecting a Sample and Determining the Reference Value for a Bias Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Need help in determining applicable clause for an audit finding (based on AS9120B) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q Kap.4.3 Determining the scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T Determining FIPS 140-2 compliance in a medical device Medical Information Technology, Medical Software and Health Informatics 2
W Strategy for determining which components from a system should be "ME EQUIPMENT" -- home healthcare environment IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
J Process Capability - Determining the process capability of certain equipment Lean in Manufacturing and Service Industries 6
S Determining a device category according to the MDR EU Medical Device Regulations 3
