Determining Sample Size - Filling a bag with three different types of candy
P
PerfettiFUN
i work in a candy factory that makes airheads candy and currently we use a vertical form fill bagger to fill a bag with three different types of airheads (normally cherry, blue raspberry, watermelon). our biggest complaint always seems to be that someone "only got two reds!" in their bag or something similar.
on our machine 3 hoppers are filled with different colors that are vibrated to fill the bucket conveyor up which then dumps into the actual bagger at the top.
what i am planning on doing is taking a number of bags, counting them up, and seeing what kind of ratio we are really getting. then i want to see if i take a large box with all three colors and mix them up really good before they go into the conveyor if it is improved at all. i think with current hopper system with 1 color in each it may be putting out waves of each color causing the bags to be skewed. what my boss said he wants to know is if mixing them more gives us a better ratio of colors in the bags.
what i am wondering is how i would calculate my sample size for this?
i know it is discrete data so i will need a TON of data to statistically prove anything. i am guessing more than is really feasible in this case.
any of you statistics gurus out there that can give me some help on this it would be very much appreciated. its been a while since statistics class so the methods for sample size determination aren't too fresh in my head :lol:
also any other kind of insight into this problem would be very much appreciated.
Tim Folkerts
Re: Determining sample size
I would suggest doing this theoretically rather than experimentally.
For example, if the ideal mix is 1/3 red, 1/3 blue, and 1/3 yellow, it would be relatively straightforward to calculate the expected number (and the spread) if you truly had a random sample of 2000 candies.
I don't have time right now, but I might be able to help you with the problem later today (or others might jump in quicker).
Tim
howste
Thaumaturge
Maybe I'm naive, but couldn't you just use three bag fillers and put a set quantity (or weight) of one type of candy in at each station? This would eliminate the random chance of having too few red ones in any bag.
P
PerfettiFUN
i could definitely do it theoretically instead of mixing a bunch by hand then running it but i think that i would still want to do an analysis on the current state and compare it to a theoretically random sample. pretty much i am trying to prove whether we are or aren't getting a normal distribution of colors in each bag and what kind of standard deviation we are getting. i am just not sure what kind of sample size i need to find this out with the kind of data i am collecting.
also the way i would want to look at the data is by bag not by bar. for example i want to be able to make a histogram when i am done and put # of each color per bag.
also the bag size i am looking at is 30 pieces.
P
PerfettiFUN
that is definitely possible to do but we are trying to see if we can get "close enough" without spending a lot of money on totally redoing the machine. that is why i am collecting the data to see how good we can get and whether it is worth it to spend the extra money or not.
howste
Thaumaturge
Typically initial process capability studies use at least 50 samples. I'd say that 30 samples would be the absolute fewest you would want to use.
um. that is a good rule of thumb for continuous data capability studies that are randomly sampled. but since this is categorical data and the subgrouping is by bag, we'd have to look at how many bags we'd need.
I like the idea of knowing the theoretical distribution of randomly filling 3 different colors in a bag, then sampling actual bags to determine if you are at the theoretical distribution first. If you are, then further randomization of the candy prior to the current process won't help. If you aren't then further randomization might help.
I'll try to run the theoretical later. Maybe Tim will get back before I do...
P
PerfettiFUN
oh ok, so there isn't any set formula i should be using to calculate out a statistically significant sample size for something like this?
what i am thinking i am going to do with my data right now is make a histogram for each color showing the number of occurrences of that color in the bags i sampled.
then once i do that i will find out my standard deviation and figure out what % of the time i will get a bag with less than say 6 of any color.
M Komarmy - 2012
If I understand the problem correctly, you are filling a bag with 30 pieces of candy. there are three different colors and you wish to have 10 of each in the bag.
I would not make this very complicated. Run 30 to 50 bags with the current process and count how many of each color are in the bags. Record the data. Repeat the run after making your proposed change (another 30 to 50 bags). Record the data.
You can evaluate the means and variances for each color for both studies and see if there was an improvement (means closer to target and less variation).
Yes - there are set formulas for both the theoretical distribution of colors and what sample size you will need.
B Bayes Success-Run on Attribute Data - Determining Sample Size Statistical Analysis Tools, Techniques and SPC 2
A Determining Sample Size in Design V&V activities 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 44
G Determining Sample Size for Equipment Qualification Studies Qualification and Validation (including 21 CFR Part 11) 10
D Determining Sample Size for Capability in Six Sigma Project Six Sigma 5
H Determining the Correct Sample Size when AQL points to two Sample Sizes AQL - Acceptable Quality Level 7
L Determining Cpk based on a given Sample Size, Confidence Level, & Reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Determining Sample Size needed for Operational Qualification (OQ) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 24
T Determining the appropriate Sample Size using an AQL Table Inspection, Prints (Drawings), Testing, Sampling and Related Topics 29
J Functional Test Sampling - Determining Sample Size to eliminate 100% Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
W Sampling Plan problem - Determining Sample Size for both Attribute and Variables Data ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Determining the Total Sample Size using AQL - AQL Lot Quantity question AQL - Acceptable Quality Level 8
1 Determining AQL and Sample Plan - Batch size is from 1-500 AQL - Acceptable Quality Level 24
E Determining Sample Size for Design Verification and Design Validation Other Medical Device and Orthopedic Related Topics 20
N Auditing Proof of Delivery signed by the customer - Determining Sample Size General Auditing Discussions 6
Q Determining Sample Size for FDA Verification and Validation Activities Inspection, Prints (Drawings), Testing, Sampling and Related Topics 41
D Determining sample size required based on a 95% confidence level Reliability Analysis - Predictions, Testing and Standards 7
B Determining sample size for drop test and waterproof testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
T Determining Receiving Inspection Sample Size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
N Determining Sample Size for Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C Internal Audit Sampling Plans - Determining Internal Audit Sample Size Internal Auditing 45
Q Determining the Appropriate Sample Size for Process Validation/Qualification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
T Using Cpk for the purpose of determining sample size/frequencies Capability, Accuracy and Stability - Processes, Machines, etc. 2
G Determining Sample Size and Frequency for Features on Control Plans FMEA and Control Plans 8
R Determining Sample Sizes for Testing (Chemistry or Microbiology) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
B Selecting a Sample and Determining the Reference Value for a Bias Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Question on determining defective units - I am not recording fixture to part rejected Statistical Analysis Tools, Techniques and SPC 5
S Clause 8.2.2 Determining the requirements for products and services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Determining FDA 820 (registration) vs ISO 13485 - Supplier gives us the kit ISO 13485:2016 - Medical Device Quality Management Systems 1
