Being out of control may the data is not stable, and the Ppk and Cpk are used for continuous data and is based on several assumptions. Cpk and Ppk assumes that the process is statistically stable and that its data is approximately normally distributed. Cpk and Ppk assumes that data is approximately normally distributed. If the distribution of the data is very skewed, we should transform the data. Cpk and Ppk considers process centering ant the short-term variation in the process. However, it should not be used alone to describe process capability. It should be used in conjunction with Cp, which is the short-term process capability index, I suggest, first try to solve all your out of control points than get new data in order to use Cpk Ppk formulas
