Determining sample size for drop test and waterproof testing
belchar
A little background. We produce handheld devices and currently use the MIL-STD-105E for our lot check sampling, but there's some desire to start including some drop testing and waterproofing test in our tests (either at the factory level or at the acceptance level), but I'm hard pressed to find a resource to determine standard sample sizes for this type of testing. Preferably, this would be determined as a subset of our standard lot check sample, but I'm open to any and all info.
Any help?
Kurt
gpainter
Re: Help determining sample size for drop test and waterproof testing
On our drop testing we do 3 samples to drop and if pass send and additional to the lab for certification. I assume you mean package testing.
belchar
You use 3 regardless of production size or sample size? It's the handheld device itself that we're testing to ensure that drops don't break it, cause to cease functioning, etc.
Similarly, I'm looking for help with the waterproof testing (ours is an ipx7 rated device).
Kurt
belchar
Perhaps I've not been clear here. Lord knows that it happens often enough! :)
I'm looking for the sampling information for the device itself, not the package it comes in. Most of the packaging drop tests seem to refer to how well a device is holding up in the package it's shipped in, rather than the device itself (or I'm reading things incorrectly).
Kurt
G
gholland
Our sample sizes are developed through our quality manual based on Juran and other manuals.
For pass/fail test, the basic equation is [log(confidence level)/log (1-upper limit of population not containing defect)]. This is indepenant of lot size or any population sizes.
For example, if you want 95% confidence that 95% of your 'good' parts are actually good, you would test 59 parts with no failures. (log.95/log .95) = 58.44 rounded to 59. That's a common level for us. For greater confidence in your test or to ensure that a greater percentage of your 'good' parts are actually 'good' you would need to test many more.
For 'critical' parts we test several hundred parts. We're a medical device supplier for context.
:2cents:
S Determining Sample Size and Method Quality Tools, Improvement and Analysis 12
B Bayes Success-Run on Attribute Data - Determining Sample Size Statistical Analysis Tools, Techniques and SPC 2
A Determining Sample Size in Design V&V activities 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 44
G Determining Sample Size for Equipment Qualification Studies Qualification and Validation (including 21 CFR Part 11) 10
D Determining Sample Size for Capability in Six Sigma Project Six Sigma 5
H Determining the Correct Sample Size when AQL points to two Sample Sizes AQL - Acceptable Quality Level 7
L Determining Cpk based on a given Sample Size, Confidence Level, & Reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Determining Sample Size needed for Operational Qualification (OQ) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 24
T Determining the appropriate Sample Size using an AQL Table Inspection, Prints (Drawings), Testing, Sampling and Related Topics 31
J Functional Test Sampling - Determining Sample Size to eliminate 100% Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
W Sampling Plan problem - Determining Sample Size for both Attribute and Variables Data ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Determining the Total Sample Size using AQL - AQL Lot Quantity question AQL - Acceptable Quality Level 8
1 Determining AQL and Sample Plan - Batch size is from 1-500 AQL - Acceptable Quality Level 24
E Determining Sample Size for Design Verification and Design Validation Other Medical Device and Orthopedic Related Topics 20
N Auditing Proof of Delivery signed by the customer - Determining Sample Size General Auditing Discussions 6
P Determining Sample Size - Filling a bag with three different types of candy Inspection, Prints (Drawings), Testing, Sampling and Related Topics 31
Q Determining Sample Size for FDA Verification and Validation Activities Inspection, Prints (Drawings), Testing, Sampling and Related Topics 42
D Determining sample size required based on a 95% confidence level Reliability Analysis - Predictions, Testing and Standards 7
T Determining Receiving Inspection Sample Size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
N Determining Sample Size for Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C Internal Audit Sampling Plans - Determining Internal Audit Sample Size Internal Auditing 45
Q Determining the Appropriate Sample Size for Process Validation/Qualification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
T Using Cpk for the purpose of determining sample size/frequencies Capability, Accuracy and Stability - Processes, Machines, etc. 2
G Determining Sample Size and Frequency for Features on Control Plans FMEA and Control Plans 8
U Determining population defect rate from sample defect rate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
R Determining Sample Sizes for Testing (Chemistry or Microbiology) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
B Selecting a Sample and Determining the Reference Value for a Bias Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
L Determining effectiveness and efficiency Process Maps, Process Mapping and Turtle Diagrams 6
C Determining an as received OOT condition during calibration does not affect measurements taken prior to calibration. General Measurement Device and Calibration Topics 16
C Need help in determining applicable clause for an audit finding (based on AS9120B) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Kap.4.3 Determining the scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T Determining FIPS 140-2 compliance in a medical device Medical Information Technology, Medical Software and Health Informatics 2
W Strategy for determining which components from a system should be "ME EQUIPMENT" -- home healthcare environment IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
J Process Capability - Determining the process capability of certain equipment Lean in Manufacturing and Service Industries 6
S Determining a device category according to the MDR EU Medical Device Regulations 3
