Determining the Appropriate Sample Size for Process Validation/Qualification
jameswalsh
#11
In my company we use 99% reliability with 95% confidence for high risk (patient safety), 95% reliability with 95% confidence for medium risk (functional defects) and 90% reliability with 90% confidence for low risk (cosmetic defects).
I found some very useful Beta tables in a book called Reliability Statistics by Robert A. Dovich. These tables allow you to calculate the reliability of a process (at a given confidence level) if you know the number of samples taken and the number of failures.
While these tables are very useful, I would love to know the mathematical formula behind them. Does anyone know it?
Regards,
James
rangerboat72
#12
The purpose of a machine acceptance study is to have confidence that the process can produce product at an acceptable quality level. Any short term study that you perform, whether it is 30 parts or 300 parts, will see variation in the results (Ppk) when replicated many times. There will be an upper and lower 95% or 99% confidence interval for the result. In the automotive industry, the PPAP process defaults to an initial process study comprising of 100 parts from a 300 piece production run (unless a different amount is agreed to by the customer). A typical OEM requirement is 1.67 Ppk with a 100 part study. The lower 99% confidence boundary is approximately 1.40 Ppk. If this is set as the minimum for acceptance, then as your sample size decreases, the acceptance limit will increase. For example, if you choose a sample size of 30 parts, to insure an equivalent capability of 1.67 Ppk with a sample size of 100 parts, the 30 part sample must achieve a 2.07 Ppk or higher. I have attached a chart taken from the Ford machine acceptance specification to show this in more detail.
Do you have any idea why Ford now requires their suppliers to do a 125 piece capability study?
#13
It has to do with the level of confidence around the capability indices. When you take a sample, there is a confidence interval around both the mean and the standard deviation. A Cp or Cpk index uses BOTH the mean and the standard deviation with their associated confidence intervals. Therefore the capability index has even wider confidence intervals.
Increasing the sample size reduces the width of the confidence intervals.
Romvill2002
#14
I have the same issue, Trying to validate a process change and came across on what sample size would fit the test(life cycle test). I found out that my monthly average production for the medical device averaging 61. Im trying to find formula that will link confidence and reliability and how it affect AQL and LTPD. I know there is link to these four parameters - need help share me the formula of each above parameters and i will just link them mathematically.
Formula for AQL, how we the 1.0, 1.5 ...
Formula for LTPD?
Formula for Confidence level ?
Formula for reliability level?
sample:
TypeParametersAQLLTPD0.1Singlen=15, a=00.34%15%Singlen=25, a=11.44%15%
How to derive these values?
T Determining the appropriate Sample Size using an AQL Table Inspection, Prints (Drawings), Testing, Sampling and Related Topics 29
J Determining the Appropriate Sampling Regime when Assigning Values to an IVD Device Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Z Determining the Appropriate Measuring Device with respect to Accuracy - Poster? General Measurement Device and Calibration Topics 16
R Question on determining defective units - I am not recording fixture to part rejected Statistical Analysis Tools, Techniques and SPC 5
S Clause 8.2.2 Determining the requirements for products and services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Determining FDA 820 (registration) vs ISO 13485 - Supplier gives us the kit ISO 13485:2016 - Medical Device Quality Management Systems 1
J ISO 9001 8.4.1 - Determining controls applied to externally provided processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
E Determining what is good and what is bad can be subjective - when is it a quality issue? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
F Determining what type of scrap to include in my internal PPM calculation Quality Manager and Management Related Issues 5
M Determining number of employees within the "Scope" of the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Determining the Scope of the QMS during Stage 1? Registrars and Notified Bodies 11
W Minor Audit Nonconformance Against Determining the scope of QMS IATF 16949 - Automotive Quality Systems Standard 12
D Determining Critical Components for conformity with IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 21
Q ISO 9001, section 4.3 Determining the scope of our QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A What does 8.2.2.1, Determining the requirements related to products and services,mean IATF 16949 - Automotive Quality Systems Standard 1
A Determining Retention Period for Medical Device QMS documents Document Control Systems, Procedures, Forms and Templates 5
F ISO 9001:2015 4.3 - Determining the scope of the quality management system ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Standards Needed In House - Determining what standards are applicable Various Other Specifications, Standards, and related Requirements 3
W Determining Medical Device Classification in Mexico Other Medical Device Regulations World-Wide 5
K Determining Effect of Failure without a DFMEA (Design FMEA) FMEA and Control Plans 1
W Determining the Status and Importance of the Processes and Areas to be Audited Internal Auditing 7
T Determining Customer Requirements for the US Postal Service (USPS) IATF 16949 - Automotive Quality Systems Standard 4
Crimpshrine13 Rules of achieving and maintaining IATF recognition - Determining audit days IATF 16949 - Automotive Quality Systems Standard 2
R Developing procedure for Determining Company's Context And Interested Parties ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 53
W Determining Asset Life or Depreciation Life for M&TE General Measurement Device and Calibration Topics 1
N Reason for determining no adverse effect on reworked product ISO 13485:2016 - Medical Device Quality Management Systems 8
N Procedure for determining pinhole position in condom Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
alonFAI Determining PCBA Xray Test Sampling Size Statistical Analysis Tools, Techniques and SPC 1
