Determining the Correct Sample Size when AQL points to two Sample Sizes
H
Hiccup
I need to know if the method I am using to select the sample size is correct. Is there a standardized method for these kind of situations?
Example:
I have a lot size of 100 units inspected at GII so I pull 20 samples (F). The AQL levels are 1.5 for major and 2.5 for minor. Following the arrow in the 1.5 column, the chart says the sample size size is actually 32 units. So what I do is pull 32 samples. I inspect 20 units for critical, major and minor defects. The last 12 units I only check for critical and major.
Is this the correct way? What if I run into two arrows pointing in opposite directions (sample size 50 at 0.5ma, 0.65mi), two arrows pointing down, two arrows pointing up, etc.
Your expertise is greatly appreciated.
E
Edward Huang
Example:
I don't know what you meant by "the chart says the sample size size is actually 32 unit"
100 units sample 20-----right!
1.5 for major------defection exceed 1 unit, reject
2.5 for minor------defection exceed 2 unit, reject
H
Hiccup
On a sample size of 20 at 1.5, you hit an arrow pointing down. According to the AQL chart "Use first sampling plan below the arrow". From my interpretation, this means you use the next sample size down which would be 32. So now I have the AQL chart telling me to pick two different sample sizes.
E
Edward Huang
Did you use MIL STD 105E AQL?
The arrow just tell you can use "0 1" as above for 1.5 major and "1 2" as below for 2.5 minor
H
Hiccup
We are using ANSI/ASQ Z1.4-2003 (pretty much the same as MIL STD 105E, yeah?)
Maybe I am understanding this wrong but in your suggestion, that would mean for major defects, the an AQL level of 1.5 has the same ac/re as an AQL level of 0.65 on a sample size of 20 units. That doesn't make sense to me.
E
Edward Huang
That actually mean it should be no major defects between 1.5 and 0.65 because batch sizes are too small.
acceptancenewbie
I think you are doing right
Major issue sampling: 32 (1,2)
Minor issue sampling: 20 (1.2)
You may decide to be conservative and do 32 (1,2) for all. Let me know what you decided?
Mike S.
Happy to be Alive
Example:
100 units, 1.5% AQL, sample size = 32 pieces
100 units, 2.5% AQL, sample size = 20 pieces
Follow the arrow. In any given row/column combination, there is only one arrow, but the table is small and sometimes you need a straightedge to align things.
There are also AQL "slide rules" to make it easier.
R Question on determining defective units - I am not recording fixture to part rejected Statistical Analysis Tools, Techniques and SPC 5
S Clause 8.2.2 Determining the requirements for products and services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Determining FDA 820 (registration) vs ISO 13485 - Supplier gives us the kit ISO 13485:2016 - Medical Device Quality Management Systems 1
J ISO 9001 8.4.1 - Determining controls applied to externally provided processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
E Determining what is good and what is bad can be subjective - when is it a quality issue? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
F Determining what type of scrap to include in my internal PPM calculation Quality Manager and Management Related Issues 5
M Determining number of employees within the "Scope" of the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Determining the Scope of the QMS during Stage 1? Registrars and Notified Bodies 11
W Minor Audit Nonconformance Against Determining the scope of QMS IATF 16949 - Automotive Quality Systems Standard 12
D Determining Critical Components for conformity with IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 21
Q ISO 9001, section 4.3 Determining the scope of our QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A What does 8.2.2.1, Determining the requirements related to products and services,mean IATF 16949 - Automotive Quality Systems Standard 1
A Determining Retention Period for Medical Device QMS documents Document Control Systems, Procedures, Forms and Templates 5
F ISO 9001:2015 4.3 - Determining the scope of the quality management system ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Standards Needed In House - Determining what standards are applicable Various Other Specifications, Standards, and related Requirements 3
W Determining Medical Device Classification in Mexico Other Medical Device Regulations World-Wide 5
K Determining Effect of Failure without a DFMEA (Design FMEA) FMEA and Control Plans 1
W Determining the Status and Importance of the Processes and Areas to be Audited Internal Auditing 7
T Determining Customer Requirements for the US Postal Service (USPS) IATF 16949 - Automotive Quality Systems Standard 4
Crimpshrine13 Rules of achieving and maintaining IATF recognition - Determining audit days IATF 16949 - Automotive Quality Systems Standard 2
R Developing procedure for Determining Company's Context And Interested Parties ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 53
W Determining Asset Life or Depreciation Life for M&TE General Measurement Device and Calibration Topics 1
N Reason for determining no adverse effect on reworked product ISO 13485:2016 - Medical Device Quality Management Systems 8
N Procedure for determining pinhole position in condom Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
alonFAI Determining PCBA Xray Test Sampling Size Statistical Analysis Tools, Techniques and SPC 1
R Determining the feasibility/scope for FDA IQ/OQ against a very simple application US Food and Drug Administration (FDA) 2
B Determining the "storage volume" (ISO 8536-8:2004 clause 6.14) Other Medical Device Related Standards 4
N Procedure/calculation for determining the foot pressure of dial thickness gauge General Measurement Device and Calibration Topics 11
