Determining the "Detection" Number Component of the FMEA RPN
G
GoKats78
Here's the scenario...
Failure Mode: Cap Weld Bead Off Center
Effect of Failure: Damper Leak
Potential Cause: Torch Position Off Location
Prevention: Torch Position Check (at Start up and Re-Teach)
Detection: Leak Test
Visual Check of work piece (100%)
Tensile Strength Test (at Start up and Re-Teach)
Weld Penetration (at Start up and Re-Teach)
The Question is what is the "Detection" component of the RPN?
The are multiple checks for this cause...how do you determine the number when that is the case?
A typical approach is to determine the Detection rating of the most effective test and use that value. You must be careful to distinguish between Preventive tests and Detection tests. Preventive tests reduce the Occurrence rating while Detection tests change the Detection rating.
This is a good example of why I think that in most cases it's better to characterize the potential failure mode as the process failure and not the NC condition in the product:
Potential Process Failure Mode: Torch position off location
Potential Effect: Cap weld bead off-center
Potential Cause: ???
Look for what might cause the torch position to be wrong, and how to prevent that condition from happening. You can then have as many detection controls as you think might be appropriate, with the Detection RPN value simply reflecting the likelihood--given all of the detection controls--that a defective product will escape.
I
iamtroll
I think that you have to use common sense and look at all of the components of detection. Then using whatever system of detection levels evaluation you use apply a number. Remember, this is not science, this is a tool to establish a pareto of issues that need to be addressed so if your a little off, you may work on one issue before another issue. I have attached a FMEA RPN evaluation that I like to use, maybe it will help you.
Apoch
The detection should be rated based on the the capability of the control to detect the cause or the subsequent failure mode.
If the detection control is a mere visual inspection, then this should be rated as 8. If the error can be detected during setup, this is rated as 5 (gauging performed on setup or first-piece check).
I would recommend that you obtain the latest edition of the AIAG FMEA manual.
R Question on determining defective units - I am not recording fixture to part rejected Statistical Analysis Tools, Techniques and SPC 5
S Clause 8.2.2 Determining the requirements for products and services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Determining FDA 820 (registration) vs ISO 13485 - Supplier gives us the kit ISO 13485:2016 - Medical Device Quality Management Systems 1
J ISO 9001 8.4.1 - Determining controls applied to externally provided processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
E Determining what is good and what is bad can be subjective - when is it a quality issue? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
F Determining what type of scrap to include in my internal PPM calculation Quality Manager and Management Related Issues 5
M Determining number of employees within the "Scope" of the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Determining the Scope of the QMS during Stage 1? Registrars and Notified Bodies 11
W Minor Audit Nonconformance Against Determining the scope of QMS IATF 16949 - Automotive Quality Systems Standard 12
D Determining Critical Components for conformity with IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 21
Q ISO 9001, section 4.3 Determining the scope of our QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A What does 8.2.2.1, Determining the requirements related to products and services,mean IATF 16949 - Automotive Quality Systems Standard 1
A Determining Retention Period for Medical Device QMS documents Document Control Systems, Procedures, Forms and Templates 5
F ISO 9001:2015 4.3 - Determining the scope of the quality management system ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Standards Needed In House - Determining what standards are applicable Various Other Specifications, Standards, and related Requirements 3
W Determining Medical Device Classification in Mexico Other Medical Device Regulations World-Wide 5
K Determining Effect of Failure without a DFMEA (Design FMEA) FMEA and Control Plans 1
W Determining the Status and Importance of the Processes and Areas to be Audited Internal Auditing 7
T Determining Customer Requirements for the US Postal Service (USPS) IATF 16949 - Automotive Quality Systems Standard 4
Crimpshrine13 Rules of achieving and maintaining IATF recognition - Determining audit days IATF 16949 - Automotive Quality Systems Standard 2
R Developing procedure for Determining Company's Context And Interested Parties ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 53
W Determining Asset Life or Depreciation Life for M&TE General Measurement Device and Calibration Topics 1
N Reason for determining no adverse effect on reworked product ISO 13485:2016 - Medical Device Quality Management Systems 8
N Procedure for determining pinhole position in condom Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
alonFAI Determining PCBA Xray Test Sampling Size Statistical Analysis Tools, Techniques and SPC 1
R Determining the feasibility/scope for FDA IQ/OQ against a very simple application US Food and Drug Administration (FDA) 2
B Determining the "storage volume" (ISO 8536-8:2004 clause 6.14) Other Medical Device Related Standards 4
N Procedure/calculation for determining the foot pressure of dial thickness gauge General Measurement Device and Calibration Topics 11
