Developing a QMS Manual for AS9100 and ISO 9001
L
L7daddy0
We are currently ISO9001 registered and have recently purchased a plant that has no certification. It was determined that the new plant would need AS9100 registration/ certification due to their customer base. I modified my QMS (which has been audited 100+ times from 2nd/ 3rd party)to incorporate the clauses for AS9100 in bold italics, and when I submitted it for review, the person reviewing it said that I should address all clauses and sub clauses in the manual. I have designed my QMS on using the manual as a driving document, an overview. The procedures and work instructions are inputs, (where all clauses are defined and addressed), and appropriate parameter sheets and quality records (outputs) Should I move forward and submit it for the stage one, or do I need to address every sub-clause in the manual. Your collective feedback is greatly appreciated.
Welcome to the Cove! I'm sure that we've answered this type of question many times before! My take is that your quality manual as you describe has been adequate for use in the past and must, therefore, provide for something reasonable for AS9100 - as one of our contributors says "Show me the shall"!
On a side note, is the reviewer a consultant or auditor?
Big Jim
Neither ISO 9001:2008 or AS9100C require documented procedures for every shall. Whoever advised you of that is all wet. Throw him a towel.
This is old school thinking based on misconceptions from the early days of ISO 9001. Old misconceptions die hard.
Now ISO / TS 29001 (API Q1) is another matter. They require that your quality manual describes how you will address each shall. But you don't work in the Petroleum industry so you don't need to take that approach unless you want to.
DannyK
The requirements for the AS9100 quality manual are found in clause 4.2.2
The organization shall establish and maintain a quality manual that includes
a) the scope of the quality management system, including details of and justification for any exclusions (see 1.2),
b) the documented procedures established for the quality management system, or reference to them, and
c) a description of the interaction between the processes of the quality management system.
There are 6 documented procedures that are mandatory.
If you meet the above, there should be no issues.
dsanabria
The interesting part here is who is disproving your ISO / AS documentation. I believe that it is time to take shop around for competent individuals
List of procedure (based on size and exclusion) for AS9100 shop.
The list below.(if you do not take exclusions).
4.2.3 Control of Documents
4.2.4 Control of Records
7.1 Documented processes (aka - Quality Plan)
7.3.6.1. Test Procedures
7.4.2 Purchasing - (requirements for approval of product, procedures,
processes and equipment, and Qualification of personnel)
7.5.2 Special Process
7.5.1.4 Technical Documentation
8.2.2 Internal audits
8.3 Control of NCR
8.5.2 Corrective Actions
8.5.3 Preventive Actions
List of Records
4.2.4 records
5.6.1 Management Review records
6.2 Training Records
7.1 Plannning Realization records
7.2.2 Contract Review Records
7.3.1 Design and Development Review
7.3.2. Design Inputs
7.3.4 Records of results
7.3.5 Records of Verification
7.3.6 Records of Validation
7.3.6.1 Records of parameters
7.3.7 Records of ECN
7.4.1 Records of Evaluation
7.4.2 Records retention flown don to suppliers
7.4.3 Purchased /suppliers records (C of C, A of C)
7.5.2 Special Process Records
7.5.3 Traceability of Records
7.5.4 Customer Product records
7.6 Records of Validation
8.2.4 Records of Results of Production inspection
8.2.4 Release of product
8.3 Records of NCR
8.5.2 Corrective Actions records
8.5.3 Preventive Actions records
Big Jim
8.3 Control of NCR
List of Records
4.2.4 records
8.3 Records of NCR
That's a nice list, and many would find this to be a very useful set, but bear in mind that anything above What Danny K listed is above and beyond the requirements of either AS9100 or ISO 9001.
dsanabria
While there is no disagreement between experienced QMS individuals. New individuals developing or auditing might loose sight of the basic and take our statements as gospel.
We should not deviate from the concept of ISO definitions of documented procedures.
... and I quote
ANSI/ISO/ASQC Q 1 O0 13- 1995 - Guidelines for Developing Quality Manuals
4.1 Documented quality system procedures
Documented quality system procedures should form the basic documentation used for the overall planning and administration of activities which impact on quality.
In accordance with the IS0 9000 family, these documented procedures should cover all the applicable elements of the quality system standard.
They should describe (to the degree of detail required for adequate control of the activities concerned) the responsibilities, authorities, and interrelationships of the personnel who manage, perform, verify, or review work affecting quality, how the different activities are to be performed, the documentation to be used, and the controls to be applied.
Big Jim
... and I quote
I continue to agree. Please take special note "these documented procedures should cover all the applicable elements of the qualtiy system standard".
There is a difference between a "shall" (requirement) and a "should" (recommendation). An auditor cannot write a nonconformance for a "should".
dsanabria
I continue to agree. Please take special note "these documented procedures should cover all the applicable elements of the quality system standard".
There is a difference between a "shall" (requirement) and a "should" (recommendation). An auditor cannot write a non-conformance for a "should".
A most educational conversation... and in total agreement.:applause:
and while we agree that no one should be giving NCR on "should".... an experienced auditor will read section b) of clause 4.2.2
On a side note
(Don't want to mislead new people into reading "Documented Procedure" and stooping at that point).:popcorn:
4.2.2 Quality Manual
and the question will be...
show me where are the rest of the documented procedure for the QMS that are not in the Quality Manual (as shown in the hierarchy of documents).:confused:
and the hierarchy...
ANNEX A (INFORMATIVE) Typical quality system document hierarchy
ANSI/ISO/ASQC 010013-1995
Document contents
Quality manual - (Level A) - Documented quality system procedures
Describes the quality system in accordance with the stated quality policy and objectives and the applicable standard. Describes the activities of individual functional units needed to implement the quality system elements
(Level B) - Describes the activities of individual functional units needed to implement the quality system elements
(Level C) - Other quality documents (work instructions, forms, reports, etc.) Consists of detailed work documents
NOfE 7 Any document level in this hierarchy may be separate, used with references, or combined.
O Developing a QMS for biomedical start up company which only does R&D? ISO 13485:2016 - Medical Device Quality Management Systems 5
I Developing Quality Objectives for a Quality Management System (QMS) Quality Manager and Management Related Issues 7
Q Developing a QMS in line with ISO 9001:2000 Document Control Systems, Procedures, Forms and Templates 6
G Developing a QMS in accordance with ISO 29001 for Oil & Gas Other ISO and International Standards and European Regulations 23
Proud Liberal Developing QMS (Quality Management System) Measurables Preventive Action and Continuous Improvement 17
Q Storing and developing SAMD (Software as a Medical Device) in the Cloud IEC 62304 - Medical Device Software Life Cycle Processes 3
T Ideas for developing a Supplier Quality Management System, non automotive ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Quality Assurance in China - Developing a quality management system for a California company Misc. Quality Assurance and Business Systems Related Topics 9
D Co-developing a new medical device ISO 13485:2016 - Medical Device Quality Management Systems 2
S Root cause analysis - The system of developing a work instruction is not effective Problem Solving, Root Cause Fault and Failure Analysis 1
L Problems while documenting the SOUPs used for the software we are developing IEC 62304 - Medical Device Software Life Cycle Processes 4
A Developing a ISO 9001:2015 Internal Audit Plan and Schedule Internal Auditing 40
D Developing an Umbrella Management System Quality Management System (QMS) Manuals 2
R Developing procedure for Determining Company's Context And Interested Parties ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 53
Richard Regalado Sample Plan for Developing an ISO 22301 Business Continuity Management System (BCMS) Business Continuity & Resiliency Planning (BCRP) 3
D Developing a Supplier Risk Matrix Supplier Quality Assurance and other Supplier Issues 4
M Developing a new Plating Vendor - What software to track certifications Software Quality Assurance 2
T Need help developing an ECO (Engineering Change order) procedure Document Control Systems, Procedures, Forms and Templates 3
T Developing an AS9100 Internal Auditor Training Program AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
AnaMariaVR2 Developing Innovative Ideas for New Companies: free course Training - Internal, External, Online and Distance Learning 0
F Developing a Robust MSA Program - over 35,000 gages in 1 million square ft. facility Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T Developing Reward Programs for Employees Quality Manager and Management Related Issues 4
H Identifying Potential Automotive Suppliers before Developing New Products Supplier Quality Assurance and other Supplier Issues 2
S Developing Documentation and Defining Processes as Subcontractor IATF 16949 - Automotive Quality Systems Standard 6
A Developing Technology and Equipment to Manufacture Clients Product - Can exclude 7.3? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
B Developing a Segment-Based Customer Service Benchmarking 6
B Developing a Queue Management Procedure - Need some help writing a Proposal Quality Manager and Management Related Issues 2
Sidney Vianna ISO 9001 - Its Relevance and Impact in Asian Developing Economies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
R Developing a c = 0 Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
AnaMariaVR2 Preparing for the RAC Examination -- Developing an RAC Study Plan Professional Certifications and Degrees 1
P Developing a Counterfeit Parts Prevention Program AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Q Developing a Sampling Plan for a New Product Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
L Developing an Access ECO Tracking Database - Need help Document Control Systems, Procedures, Forms and Templates 8
P Developing Performance Standards - ISO 14630:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
P Developing a SOW for Entire Site Calibration Requirements General Measurement Device and Calibration Topics 3
J Developing Plans for Corrective Actions for Audit Non-Conformities ISO 13485:2016 - Medical Device Quality Management Systems 5
M Developing a Career Plan Career and Occupation Discussions 5
A Policy for Suppliers - Developing a Supplier Policy Document ISO 13485:2016 - Medical Device Quality Management Systems 3
M Developing your own personal "Body of Knowledge" document. Professional Certifications and Degrees 3
K Developing an TL 9000 Audit Checklist - Help required TL 9000 Telecommunications Standard and QuEST 2
E Developing the Essential Requirements Checklist - Identifying Requirements Other US Medical Device Regulations 3
N ISO 9001 and the HR Function - Developing a Total Quality Management System for HR ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
B ISO Clause Reference for Developing Common Customer Service Standards ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Developing a CPI for First Pass Yield Final Inspection - Need help Quality Tools, Improvement and Analysis 7
M Developing a Medical Device Audit Checklist 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
A Developing HR (Human Resources) Policies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A Developing a Position Grade for Employee Suggestions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Developing In-House Calibration Capacities General Measurement Device and Calibration Topics 5
S Developing Petrochemical Company Processes - Help needed Process Maps, Process Mapping and Turtle Diagrams 1
S I need help in developing a Center of Excellence Misc. Quality Assurance and Business Systems Related Topics 5
