Deviating from AQL in a small Retail Apparel Company
P
Perfectol
I am the QA manager for a small retail apparel company and everything that I'm learning is self taught OJT (which is not much at all) and need assistance calculating the following:
AQL
AOQ
AOQL
PROCESS AVERAGE
operating characteristic
Probability of accepting a lot
Manufacturing is farmed out. We don't build anything in house.
Inspection is only performed after the product is made and delivered to us. There is no inspection of components or du-pro inspection at this time.
We receive anywhere from 300 to 2000 units of any one style. Most of the time it is in the 500-600 units.
Based on a 500 unit delivery and a normal inspection level, we are to inspect 50 units. Sometimes, due to one reason or another out of my control, we only have time to inspect a portion of that amount. Do the formulas take into account this variable or must every unit be inspected (50 units)?
We have a visual pass/fail inspection and a measurement portion.
Statistical Steven
Statistician
AQL
AOQ
AOQL
PROCESS AVERAGE
You can calculate the AQL and LQ (LTPD) for any sample size with any number of acceptable defectives in the sample. If you are suppose to sample 50, but instead curtail the inspection once started, you can calculate the AQL, but keep in mind you have a bias in your sampling.
Steve - it might be helpful to provide those formulas since the OP is a 'newbie' to acceptance sampling. (finding them in jungle will be tough and deriving them even tougher for someoen as new as he is)
Perhaps just the set with a c=0 number? that is most likely to be what the OP's organization does...
Statistical Steven
Statistician
Here is an example of the calculations
JoeDM
If you're new to this stuff, I would suggest you use a standard sampling plan like MIL-STD-105, but consider two stage sampling. This avoids the mathematics, but can significantly reduce inspection.
The theory goes that product is either very good or very bad. If it is very good, you will accept the lot on the first sample (which is smaller that the sample size for a single sampling plan). If the product is very bad, you'll reject on the first sample. If you guessed wrong and the product quality is somewhere in between, then a second sample is required, and you end up doing more inspection than you would have with single sampling.
I used this technique with great success and rarely needed to go to a second sample. Using this technique, I took a department that never seemed to be able to inspect on time and turned it into one that was always on time.
Good luck! Hope this helps.
A Cost of Deviating Away From PPAP Requirements APQP and PPAP 3
V Deviating from USP Method for Microbiological Assay Qualification and Validation (including 21 CFR Part 11) 2
R AQL, Consumer Risk and MA Statistical Analysis Tools, Techniques and SPC 2
A AQL - How to count samples with defects for each defect class AQL - Acceptable Quality Level 17
S ARMY AQL - Requirements which don't have an AQL associated with them Manufacturing and Related Processes 2
M AQL table - I need to sample 1250pcs AQL - Acceptable Quality Level 3
Nicole Desouza Sampling plan for a customer who wants AQL 1.0 (per ANSI Z1.4) AQL - Acceptable Quality Level 5
V How to interpret AQL sampling tables AQL - Acceptable Quality Level 5
A AQL sampling bags of parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
I Sampling processes - Who must define the AQL level? AQL - Acceptable Quality Level 9
J AQL for Effectiveness Check - What AQL tiers to use on this type of sampling? Nonconformance and Corrective Action 9
S AQL Inspector's Rule - bring into CQE Exam? Professional Certifications and Degrees 5
N The question asks about sampling plans and AQL Reliability Analysis - Predictions, Testing and Standards 5
K Defining Acceptance Quality Level, I need clarity on AQL 1.5, 2.5, 4.0 AQL - Acceptable Quality Level 5
V Receiving Inspection AQL - Am I allowed to just pick a AQL? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
L Established a c=0 "AQL" or "RQL" table AQL - Acceptable Quality Level 5
A AQL Sampling Plan SOP / WI - Medical Device Industry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
C Example Work Instruction/Procedure for AQL (Acceptable Quality Level) AQL - Acceptable Quality Level 4
L How to calculate the Probability of Deficiency of the AQL of an Inspection AQL - Acceptable Quality Level 16
P Setting Acceptance Quality Limits (AQL) for New Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 4
K AQL for Sterile Product - Laminate Tubes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M How to Mathemetically Derive the AQL Tables given Lot Sizes AQL - Acceptable Quality Level 5
L AQL ANSI z1.4 & z1.9 - What are the differences between these 2 standards? AQL - Acceptable Quality Level 5
P RQL/AQL from Attribute Data Six Sigma 1
B Designing a Sampling Plan - AQL AQL - Acceptable Quality Level 19
V AQL for Component Level and Assembled Finished Product AQL - Acceptable Quality Level 1
alonFAI AQL and Sampling Size for Components Solderability Test Statistical Analysis Tools, Techniques and SPC 3
A Inspection Plans - How to choose AQL (MIL STD 105E) Excel .xls Spreadsheet Templates and Tools 1
U AQL, Lot Size vs Sampling Plans AQL - Acceptable Quality Level 8
R Formula to tie together - Confidence/Reliability Level AQL? LTPD? Reliability Analysis - Predictions, Testing and Standards 3
P Which Sampling Tables for AQL? Statistical Analysis Tools, Techniques and SPC 6
K Can I use ANSI/AQL for the Total Number of Containers for the entire Lot? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Determining c=0 AQL numbers Misc. Quality Assurance and Business Systems Related Topics 3
L Who and when to determine AQL for our product inspection AQL - Acceptable Quality Level 1
K Verification Sampling vs. AQL - Sampl Sizes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
E Translating AQL to a Production Line Inspection Plan AQL - Acceptable Quality Level 14
S Class III Sampling Plan - Explain AQL vs. 95%C & 90%R Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K Training the absolute beginner to understand AQL Training - Internal, External, Online and Distance Learning 1
S What are typical Acceptable Quality Levels (AQL) adopted in Food industry? Food Safety - ISO 22000, HACCP (21 CFR 120) 1
D What AQL level to use to test LEDs Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
B AQL Sampling Tables Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Constructing an AQL matrix for our QC operators in a flexographic printing outfit AQL - Acceptable Quality Level 4
N Visible particles inspection in powders for injections. Approaches to AQL level Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
S Justifying the AQL for a Zero (C=0) Acceptance Plan (Medical Device) AQL - Acceptable Quality Level 6
W Application of AQL (Acceptable Quality Level) Concept AQL - Acceptable Quality Level 15
M AQL (Acceptable Quality Level) for Mixed Part Defect IATF 16949 - Automotive Quality Systems Standard 1
S AQL (Acceptable Quality Level) Report Form example wanted AQL - Acceptable Quality Level 1
