MedtechQuality
Hello all,
I am currently handling an NCMR where a part failed during one of the testing procedures. However, the NC originator did not clearly describe the findings in the NC description. The information provided was subjective and open-ended.
After discussing the issue with the NC originator, we were still unable to arrive at a clear understanding of the findings. We eventually agreed that the testing would be demonstrated to help explain the issue. Based on that agreement, I removed the parts from the cage and took them for re-testing, which led to the identification of the actual findings. I made the operator to correct the findings per GDP. Further, I attached this updated document and updated the NC description.
However, I now realize that removing the component from the cage and performing re-testing should have been done following proper documented instructions or authorization, which I did not obtain beforehand.
I would like to understand how this situation should be addressed systematically and documented appropriately. Could you please advise on the proper course of action in this case?
Thank you for your support.
