Device Master Record Requirements for Component Manufacturer
I
ISODOC
We recently had an ISO 13485 audit and was issued a non-conformance for not having a DMR. Do you need to have a DMR if you are only producing a component consisting of only one item?
Any help would be appreciated.
GStough
:bonk:
Does the terminology "DMR" has anything to do with ISO13485? :frust:
Cheers!
Not specifically, however, where notes in ISO 13485 refer to regional, national, international, etc. requirements, 21 CFR 820 QSR's requirements for having a DMR would be included here.
sagai
That's actually a fair comment I think for device manufacturers whereas the particular device is marketed on that particular market.
However I still have doubts having a read of the 21CFR820 if it could be considered as such for component developer as part of the ISO13485 audit.
Sec. 820.1 Scope
This regulation does not apply to manufacturers of components or parts of finished devices, but such manufacturers are encouraged to use appropriate provisions of this regulation as guidance.
Cheers!
MIREGMGR
Terminology aside, I assume that when you agreed with your NB that they would certify your QMS to ISO 13485, you provided them with some information on at least one medical device that you make, so that they and you could agree on a scope statement to go in the certificate. Is the product that you're describing that medical device?
If in fact you aren't currently producing any medical devices, and the product you're describing is in your view just a component for someone else's medical device, does the NB agree?
It sounds to me as if they think the product that you're describing as a component is in fact a medical device within the certificate scope. I'd think that issue would need to be sorted out between the NB and you.
I
ISODOC
Thank you for the feedback.
The component is a tube, which by itself cannot be used as a device.
We are now challenged with creating DMR's which is really a Component Master Record for our purpose.
The certification does not list devices only components.
Thank you!
Ronen E
Problem Solver
Moderator
Thank you!
I always found it quite pointless that companies manufacturing objects that are far from being conceived as medical devices (finished or not) -- a plain "raw" tube, foe instance -- are being certified to ISO 13485. I believe ISO 900x would have been more appropriate.
Anyway, since you're already at it, here's what ISO 13485 says ("DMR" terminology aside, in essence the topic is the same):
7.3.3 Design and development outputs
Design and development outputs shall
a) ...
b) provide appropriate information for purchasing, production and for service provision,
c) contain or reference product acceptance criteria, and
d) ...
If you didn't have a DMR (or its equivalent, any way you name it), I'd expect an ISO 13485 auditor to raise a NC against this "shall"; unless you excluded section 7.3 in whole and your exclusion was accepted by that auditor.
Cheers,
Ronen.
E Procedure ( SOP) for Device Master Record ( DMR ) and for Device History Record (DHR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
R No design history file or device master record ISO 13485:2016 - Medical Device Quality Management Systems 5
Sam Lazzara Medical Device File (MDF per 13485:2016 4.2.3) versus FDA Device Master Record (DMR) ISO 13485:2016 - Medical Device Quality Management Systems 3
R Are DMR (device master record) and DHR (device history record) inspected by FDA or audited by an NB ISO 13485:2016 - Medical Device Quality Management Systems 6
S Foreign Manufacturer and DMR - Who keeps the DMR (Device Master Record)? ISO 13485:2016 - Medical Device Quality Management Systems 2
S DMR (Device Master Record) for Medical Device Software IEC 62304 - Medical Device Software Life Cycle Processes 3
S DMR (Device Master Record) Management and Index questions Other US Medical Device Regulations 18
P DMR (Device Master Record) for Class I and Class II Dental Product 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
B DMR (Device Master Record) For Contract Manufacturers 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
C When to submit a 510(k)? After the DMR (Device Master Record) is finished? Other US Medical Device Regulations 4
J Contents of DMR (Device Master Record) when manufacturing is by 3rd party 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A DMR (Device Master Record): What is meant by these words - Software Specifications? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
D DMR (Device Master Record) Index as a Controlled Document 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
T Device Master Record For Medical Device Accessories ISO 13485:2016 - Medical Device Quality Management Systems 2
E Need help establishing a DMR (Device Master Record) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Q DMR-Device Master Record vs DHF-Design History File vs DHR-Device History Record 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 50
P Device Master Record requirements - wrong approach? ISO 13485:2016 - Medical Device Quality Management Systems 1
B Format of Device Master Record (DMR) for Combination Products 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Device Master Record (DMR) that was compiled by another company 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
W Update DHF (Device History Record) when DMR (Device Master Record) changes? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
W DMR (Device Master Record) Revision Requirements? FDA GMP Manual 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
S DMR Index - Can someone share their Device Master Record Index structure or format? ISO 13485:2016 - Medical Device Quality Management Systems 15
M Medical Device Master File - We are a contract manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 7
rob73 Digital DMF (Device Master File) Records EU Medical Device Regulations 3
I DMR (Device Master Records) and similar for standalone software device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Device Master Records for a Contract Manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
U What is a Medical Device "Master Item File"? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
T Japan Master Files for Device materials? Japan Medical Device Regulations 5
W Protecting Proprietary Information - Medical Device Master Files US Food and Drug Administration (FDA) 9
J Question regarding Device Master Records & Specification Developers 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M Contract Manufacturer - Technical/Device Master File Responsibility ISO 13485:2016 - Medical Device Quality Management Systems 10
C Is Site Master File necessary for a European Medical Device Manufacturer (class III)? ISO 13485:2016 - Medical Device Quality Management Systems 5
M DMR - Device Master Records - What is the best way to structure the DMR 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 55
B ISO 14971 replaces EN 1441 - Risk Analysis and Technical Files/Device Master Files ISO 14971 - Medical Device Risk Management 17
shimonv Clinical evaluation report for class I device EU Medical Device Regulations 2
P UDI-PI requirements on reusable surgical device, do we need serialisation? ISO 13485:2016 - Medical Device Quality Management Systems 0
M Medical device certificate in Australia - ARTG certificate Other Medical Device Regulations World-Wide 0
Q Software as a medical device vs software not sold as medical device: local regulations for sale? EU Medical Device Regulations 4
H Medical device Product Registration Registrars and Notified Bodies 2
A Can a power Supply be an accessory to a medical device, if it is an 'off-the-shelf' product. IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Medical device labelling Date of manufacture US Food and Drug Administration (FDA) 2
W Non Sterile Medical Device Environmental Tests Other Medical Device Related Standards 4
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
M Sample record for verification performed by importers before placing a device on the market EU Medical Device Regulations 0
S IVD Device History Record ISO 13485:2016 - Medical Device Quality Management Systems 3
K Relabeling an existing medical device in the field? Other US Medical Device Regulations 6
A Reliable sources for following EU medical device regulatory EU Medical Device Regulations 0
T IVDR Medical device software CE Marking (Conformité Européene) / CB Scheme 8
