DFMEA countermeasures in PFMEA
qusys
I was once told that a PFMEA should not be used to counter DFMEA items. Could I please receive your opinion on this?
Not always, in my opinion.
In fact, if you are only responsible of mfg process design and development and not of product design and development, your customer does the D-FMEA where some effects of potential failures could be mirrored in P-FMEA , causing, for example , potential issues of reliability of the product, ins pecific loops of the mfg process (from incoming to shipping through production , as per defined process flow). So, the link should exist.:bigwave:
Steve Moat
Thanks for your response.
If a suitable countermeasure cannot be determined for a DFMEA item, do you think it is correct to rely on a PFMEA detection method?
I've seen it a number of times, I'm just not sure how much reliance can be put on the PFMEA for something which should have been designed out:confused:
qusys
I see your point and agree. From the working experience many potential issue may derive from potential issue in design, but I think that p-FMEA can help in mitiganting risks. This is the power of FMEAs, both D and P.
However, another opportunity is to rely on controls inserted in the control plans, derived from special characteristics ( both customer's ones and organization's ones). Again , if reliabiity of the product can be an effect in D-FMEA, you could also insert controls in control plan such as testing of specific structures , linking them with special characteristics.:bigwave:
That is correct. DFMEA Severity and Occurrence can only be reduced through a design change. DFMEA Detection only refers to design verification or validation testing that occurs prior to engineering release. Process detection is too late. Process detection controls are rated at a 10 on the DFMEA Detection rating.
Remember that a DFMEA is intended to identify and mitigate design risks. Process controls do not mitigate design risk.
If this is true, and I believe it is, then the identification of special characteristics as DFMEA output is unnecessary.
Chennaiite
Never-say-die
What is the relevance between Special Characteristics identification as DFMEA output and the point of detection control in the product lifecycle. I am unable to understand.
O AIAG VDA DFMEA Template Required FMEA and Control Plans 2
P DFMEA - Machinery Design Best Practices FMEA and Control Plans 0
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
J Looking for a training organization that can provide in house DFMEA training FMEA and Control Plans 4
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
DuncanGibbons Best practice for identifying "items" of parts for DFMEA analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
M How to complete structure Analysis and Function analysis sections' columns of AIAG-VDA DFMEA form FMEA and Control Plans 0
Jimmy123 Handling nonfunctional requirements in DFMEA FMEA and Control Plans 5
Jimmy123 P-Diagram vs DFMEA FMEA and Control Plans 4
C Function definition for DFMEA FMEA and Control Plans 1
G DFMEA buy-in strategies for Design Engineers APQP and PPAP 22
optomist1 DFMEA - Real Life Drama FMEA and Control Plans 25
optomist1 Share a DFMEA template please Document Control Systems, Procedures, Forms and Templates 2
P Detection rating for a user (surgeon) related failure mode in DFMEA APQP and PPAP 3
Marc Definition DFMEA (Design FMEA) - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
S DFMEA when the supplier doesn't have design responsibility APQP and PPAP 15
T DFMEA/PFMEA and SCCAF alignment FMEA and Control Plans 19
C Design for Assembly in DFMEA - Failure Effect of Sub-System(s) FMEA and Control Plans 5
C Resource allocation problems in Software DFMEA FMEA and Control Plans 4
I Making a process PFMEA, no DFMEA (non-automotive toll manufacturer) FMEA and Control Plans 1
Proud Liberal DFMEA / PFMEA linkage - Where in the standards do I find it? FMEA and Control Plans 5
D Introducing an existing product into automotive context - DFMEA needed? IATF 16949 - Automotive Quality Systems Standard 8
N DFMEA, Drawings and PFMEA of an Assembly Process FMEA and Control Plans 12
N YS Class in DFMEA & Process Control Measures FMEA and Control Plans 1
R DFMEA Severity 9-10 with Occurrence 3 and Detection 3 - Actions FMEA and Control Plans 3
G Is it compulsory to make DFMEA for proto parts making organisation APQP and PPAP 1
K Determining Effect of Failure without a DFMEA (Design FMEA) FMEA and Control Plans 1
Stijloor DFMEA & DVP&R Training Providers FMEA and Control Plans 1
P Does anyone have a DFMEA process Interface Matrix .xls template FMEA and Control Plans 7
C DFMEA vs. PFMEA Relationship: The cause in DFMEA becomes Failure in the PFMEA FMEA and Control Plans 2
M Severity Reduction in a Design FMEA (DFMEA) FMEA and Control Plans 25
G How to identify Key Characteristics (KC) in a Design FMEA (DFMEA) FMEA and Control Plans 2
W 'Classification' column in DFMEA FMEA and Control Plans 3
N What is the relationship between a DFMEA and PFMEA? FMEA and Control Plans 1
M If I update a DFMEA do I need to submit to my Customer? FMEA and Control Plans 7
R DFMEA (Design FMEA) on Printed Circuit Boards (PCB's) FMEA and Control Plans 2
M How to identify CTQ / Critical Characteristics using the DFMEA approach. FMEA and Control Plans 3
P Removing Detection from DFMEA - Medical Device company using ISO 13485 FMEA and Control Plans 3
R Rear Axle Gear Group DFMEA (Design FMEA) - Example wanted FMEA and Control Plans 2
H DFMEA Severity Ranking of Non-Compliance to EMC Standards FMEA and Control Plans 2
V Simple Representation for Scope of DFMEA and PFMEA FMEA and Control Plans 4
R Risk Assessment Matrix Question - Inputs from the DFMEA, etc. FMEA and Control Plans 9
M ISO 14971 Risk Analysis and use of a DFMEA (Design FMEA) ISO 14971 - Medical Device Risk Management 8
E IQRM PFMEA/DFMEA Software FMEA and Control Plans 11
Chennaiite Vehicle and System DFMEA - Brainstorming to Draft Guidelines FMEA and Control Plans 3
Chennaiite DFMEA (Design FMEA) at Vehicle Level - Some inputs needed. FMEA and Control Plans 4
M DFMEA Detection Ranking in AIAG FMEA Manual 4th Ed. - Explanation wanted IATF 16949 - Automotive Quality Systems Standard 6
