DFMEA (Design FMEA) - Document or Record?
rexlee
Does anybody can share the idea about DFMEA, will you treat it as document or record?
Per my understanding, DFMEA is product based, which should be a record only, becaue design only for "new", not like PFMEA, which is manufacturing process based.
bdetchevery
Where documents and records meet
If you use a template or WI for your FMEA that would be considered a document. (The blank form)
The calculation of RPN #'s creating recommended actions and recording results are all evidence of activities preformed and therefore I would classify this as a record. This is especially obvious if you have a place for sign-off on the FMEA itself.
Actually, In general any document that has one or more signatures on it I consider a record when I'm auditing. Prior to activities being preformed with the document then it's 'just a document'
Hope this helps,
Brad D.
Its a transitional document.
While actively assessing risks, driving corrective/preventive action/continual improvements and while linked to a control plan, it should be considered a controlled document. The test for the need for a controlled document would indicate that people may take incorrect action if they worked from an obsolete version of the FMEA document.
When all is complete and no more activity is occurring, an FMEA may become a record. However, FMEAs are typically considered a "living" document, so this may not occur until the product end-of-life.
You'll get confused if you try to decide whether or not something is a document instead of whether or not a document needs to be controlled. In this instance, both D- and P- FMEA documents are subject to change, so some form of revision control is necessary.
Marc Definition DFMEA (Design FMEA) - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
K Determining Effect of Failure without a DFMEA (Design FMEA) FMEA and Control Plans 1
M Severity Reduction in a Design FMEA (DFMEA) FMEA and Control Plans 25
G How to identify Key Characteristics (KC) in a Design FMEA (DFMEA) FMEA and Control Plans 2
R DFMEA (Design FMEA) on Printed Circuit Boards (PCB's) FMEA and Control Plans 2
R Rear Axle Gear Group DFMEA (Design FMEA) - Example wanted FMEA and Control Plans 2
M ISO 14971 Risk Analysis and use of a DFMEA (Design FMEA) ISO 14971 - Medical Device Risk Management 8
Chennaiite DFMEA (Design FMEA) at Vehicle Level - Some inputs needed. FMEA and Control Plans 4
P Design FMEA (DFMEA) Basics - Help needed IATF 16949 - Automotive Quality Systems Standard 3
S DFMEA (Design FMEA) for a New Line Operation of the Underground Operation FMEA and Control Plans 10
T Electronic Assembly Design FMEA (DFMEA) FMEA and Control Plans 6
michellemmm Reverse Engineering a Design FMEA using aerospace DFMEA guidelines FMEA and Control Plans 2
T DFMEA (Design FMEA) - We already have a PFMEA (Process FMEA) FMEA and Control Plans 5
P Design FMEA (DFMEA) required on all products and their parts? Design and Development of Products and Processes 5
R Can a DFMEA (Design FMEA) effectively analyse design modifications? FMEA and Control Plans 12
C DFMEA (Design FMEA) and PFMEA (Process FMEA) - Who should lead? FMEA and Control Plans 14
A DFMEA (Design FMEA) - Occurance and Detection Ratings FMEA and Control Plans 2
B How to fill s/c and c/c in DFMEA (Design FMEA)? Design and Development of Products and Processes 3
S DFMEA - Is a Design FMEA required? FMEA and Control Plans 3
M DFMEA (Design FMEA) for Trailers or any heavy vehicle design Design and Development of Products and Processes 1
N How to Calculate RPN in Design FMEA (DFMEA) vs. Process FMEA (PFMEA) FMEA and Control Plans 9
M When to start a DFMEA (Design FMEA)? APQP and PPAP 2
B What is the meaning of the Occurrence in the DFMEA (Design FMEA)? FMEA and Control Plans 8
W DFMEA (Design FMEA) for Bulk Material - Resin for Plastic Injection Moulding FMEA and Control Plans 1
K DFMEA (Design FMEA) - Plastic Injection Molding FMEA and Control Plans 2
T Ballpoint Pen DFMEA (Design FMEA) FMEA and Control Plans 13
L Special Characteristics in DFMEA (Design FMEA) - Carry over to PFMEA? FMEA and Control Plans 9
Y Design (DFMEA) and Process (PFMEA) FMEA Failure Mode Identification Design and Development of Products and Processes 8
S Control Plan and Design FMEA (DFMEA) Links FMEA and Control Plans 4
P DFMEA - Machinery Design Best Practices FMEA and Control Plans 0
G DFMEA buy-in strategies for Design Engineers APQP and PPAP 22
S DFMEA when the supplier doesn't have design responsibility APQP and PPAP 15
C Design for Assembly in DFMEA - Failure Effect of Sub-System(s) FMEA and Control Plans 5
M DFMEA and its linkage to Design Verification FMEA and Control Plans 1
J Selection Matrix for DFMEA Focus in New Product Design FMEA and Control Plans 7
T DME (design margin evaluation) vs. DFMEA Design and Development of Products and Processes 3
A Commerical off the shelf items (COTS) in DFMEA's (Design FMEAs) FMEA and Control Plans 5
M 7.3.2.2 - Process Design in Remanufacturing - Registration Finding for no DFMEA Design and Development of Products and Processes 8
G Detection Rating in Design FMEAs (DFMEA) FMEA and Control Plans 2
Casana DFMEA Design Control response FMEA and Control Plans 4
O AIAG VDA DFMEA Template Required FMEA and Control Plans 2
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
J Looking for a training organization that can provide in house DFMEA training FMEA and Control Plans 4
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
DuncanGibbons Best practice for identifying "items" of parts for DFMEA analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
M How to complete structure Analysis and Function analysis sections' columns of AIAG-VDA DFMEA form FMEA and Control Plans 0
Jimmy123 Handling nonfunctional requirements in DFMEA FMEA and Control Plans 5
