DFMEA/PFMEA and SCCAF alignment
toniriazor
Hello everybody,
I work as a quality engineer for the past year and I am very much interested in DFMEA/PFMEA and SCCAF
The engineers where I work are unable to tell me the following:
1 ) should DFMEA and PFMEA be aligned in terms of SC and CC (Significant and Critical Characteristics). When I have in DFMEA SC or CC does it mean I should have them in PFMEA as well ?​
2 ) SCCAF (special characteristic communication and agreement form). Here is my biggest concern and I am not sure what is the correct way of work: Are all SC and CC in SCCAF taken from DFMEA and PFMEA or first we should identify them in SCCAF and from there to apply them in DFMEA/ PFMEA ?​
I hope my questions are clear to the point.
Thank you very much for the support.
Typically you identify potential SC/CCs in the DFMEA. When completing the PFMEA, you should review all potential SC/CCs and either confirm them as actual SC/CC or not.
toniriazor
Thank you all for answering.
to put it clear when SCCAF is created ? after DFMEA/PFMEA development and identifying all SC and CC or vice versa ? For me all output in DFMEA and PFMEA should be used as input for SCCAF but I might be wrong...
Thank you.
toniriazor
Is there a reason why you are not sharing your SCCAF form with us here so we know exactly what you are referring to?
yes this data is not available on my home pc - from where I am posting. Additionally is confidential and I will not share it since this is against company policy. Here is how it looks like in a different format.
YS means SC from DFMEA
SC
- from PFMEA
what is not clear for me is - SC in the PFMEA field does it come from PFMEA or first it should be indicated in SCCAF like the way it is shown on the picture and then put in PFMEA ?
Marc
Since your company's SCCAF process is not part of a recognized process, I can't help any more than Miner and I already have.
Sebastian
Everything starts from determination of requirements, identification of risks and evaluation of seriousness of risk consequences. These are purposes of DFMEA and PFMEA procedures and therefore these are only sources of special characteristics. When you get special characteristics list from your customer, it should be attached with fragments of risk analysis giving rationale why these characteristics were selected as special ones. Then you can transfer this knowledge to you PFMEA. Unfortunately, I do not know any customer who behaves so responsibly and shares it. In such case you are forced to put it inside your PFMEA and give yourself rationale why you put it there. Rationale "customer request it" is wrong.
Conclusion - DFMEA, PFMEA are initial documents where special characteristics are identified. All other documents listing special characteristics (including drawing) have only reproductive character.
GRP
SC
- from PFMEA
I´ll assume the terms YS, SC, SCCAF refer to Ford. In this case YS and YC are potential significant and critical characteristics. If you supply parts to the OEM or a tier 1 you will be handed the SCCAF document with a set of identified characteristics.
Probably you will find customer inputs on the left columns. On the right you´d expect to find the PFMEA columns, which are meant to be filled.
In concrete answer to your questions:
1) You have to address all special characteristics in the document. If confirmed as special characteristics, YS/YC in DFMEA (left) should be entered as SC/CC in PFMEA. The document itself should contain relevant information as to how to go about this confirmation
2) The YS and YC were identified during the DFMEA and were placed in the SCCAF. I assume you received the SCCAF from your customer, hence you just fill the supplier part as above.
Hope it helps, if not, let´s try again
toniriazor
Thank you for your thorough answer.
It makes sense what you said. If I understood well all YS/YC in DFMEA are listed in SCCAF. Then the tier 1 receives this document from FORD let's say and manufacturer should agree to enter those in PFMEA also as SC/CC only if recognized as such. Normally the plant recognizes YS from DFMEA as SC in SCCAF and PFMEA when the probability of occurence is more than 4 correct ?
Thanks for the good discussion.
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
I Making a process PFMEA, no DFMEA (non-automotive toll manufacturer) FMEA and Control Plans 1
Proud Liberal DFMEA / PFMEA linkage - Where in the standards do I find it? FMEA and Control Plans 5
N DFMEA, Drawings and PFMEA of an Assembly Process FMEA and Control Plans 12
C DFMEA vs. PFMEA Relationship: The cause in DFMEA becomes Failure in the PFMEA FMEA and Control Plans 2
N What is the relationship between a DFMEA and PFMEA? FMEA and Control Plans 1
S DFMEA countermeasures in PFMEA FMEA and Control Plans 18
V Simple Representation for Scope of DFMEA and PFMEA FMEA and Control Plans 4
E IQRM PFMEA/DFMEA Software FMEA and Control Plans 11
T DFMEA & PFMEA - Special Characteristics Identification FMEA and Control Plans 14
V Failure Modes & Causes in dFMEA & pFMEA FMEA and Control Plans 3
K DFMEA & PFMEA Lead Responsibility FMEA and Control Plans 10
T DFMEA (Design FMEA) - We already have a PFMEA (Process FMEA) FMEA and Control Plans 5
C Does the PFMEA Severity have to match the DFMEA Severity? FMEA and Control Plans 3
C DFMEA (Design FMEA) and PFMEA (Process FMEA) - Who should lead? FMEA and Control Plans 14
P DFMEA, PFMEA and Control Plan examples (e.g.: for a pen) wanted for training FMEA and Control Plans 2
U Example of DFMEA & PFMEA for a throttle body (Butterfly valve) FMEA and Control Plans 2
N How to Calculate RPN in Design FMEA (DFMEA) vs. Process FMEA (PFMEA) FMEA and Control Plans 9
A DFMEA, PFMEA and KCC's (Key Control Characteristics) Relationships FMEA and Control Plans 11
W Actual examples of FMEA (DFMEA, PFMEA) for Car Assembly Process IATF 16949 - Automotive Quality Systems Standard 5
G The difference between DFMEA and PFMEA FMEA and Control Plans 4
L Special Characteristics in DFMEA (Design FMEA) - Carry over to PFMEA? FMEA and Control Plans 9
Ron Rompen Development of the PFMEA - SEVERITY scores not derived from the DFMEA - Ford FMEA and Control Plans 13
M Connection between DFMEA and PFMEA - What must be transferred to the PFMEA? FMEA and Control Plans 9
Y Design (DFMEA) and Process (PFMEA) FMEA Failure Mode Identification Design and Development of Products and Processes 8
A PFMEA - Is having the DFMEA An Absolute Requirement when doing a PFMEA FMEA and Control Plans 19
O AIAG VDA DFMEA Template Required FMEA and Control Plans 2
P DFMEA - Machinery Design Best Practices FMEA and Control Plans 0
J Looking for a training organization that can provide in house DFMEA training FMEA and Control Plans 4
DuncanGibbons Best practice for identifying "items" of parts for DFMEA analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M How to complete structure Analysis and Function analysis sections' columns of AIAG-VDA DFMEA form FMEA and Control Plans 0
Jimmy123 Handling nonfunctional requirements in DFMEA FMEA and Control Plans 5
Jimmy123 P-Diagram vs DFMEA FMEA and Control Plans 4
C Function definition for DFMEA FMEA and Control Plans 1
G DFMEA buy-in strategies for Design Engineers APQP and PPAP 22
optomist1 DFMEA - Real Life Drama FMEA and Control Plans 25
optomist1 Share a DFMEA template please Document Control Systems, Procedures, Forms and Templates 2
P Detection rating for a user (surgeon) related failure mode in DFMEA APQP and PPAP 3
Marc Definition DFMEA (Design FMEA) - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
S DFMEA when the supplier doesn't have design responsibility APQP and PPAP 15
C Design for Assembly in DFMEA - Failure Effect of Sub-System(s) FMEA and Control Plans 5
C Resource allocation problems in Software DFMEA FMEA and Control Plans 4
D Introducing an existing product into automotive context - DFMEA needed? IATF 16949 - Automotive Quality Systems Standard 8
N YS Class in DFMEA & Process Control Measures FMEA and Control Plans 1
R DFMEA Severity 9-10 with Occurrence 3 and Detection 3 - Actions FMEA and Control Plans 3
G Is it compulsory to make DFMEA for proto parts making organisation APQP and PPAP 1
