Dial Bore Gage Contact Points leaving witness/burnish marks
cpbraun
Does any one have experience using alternative materials for dial bore gage contact points? The regular ones are leaving witness/burnish marks in our bores that require Ra8 or better finishes.
Any shared experiences/direction would be welcomed!:thanks:
ISOsandy
Re: Dial Bore Gages
:) is this Chris that used to work at Goodrich?
As far as the dial bore, we had to go to a large radius tip which helped, but then we have to continue to polish the tip to keep it from scratching the parts.
Sturmkind
Ceramic dial bore tips may help depending on the material you are measuring.
A better choice may be to consider an ID air gage probe formerly made by Federal Products and now owned by Marposs/Mahr.
Good luck!
cpbraun
Re: Dial Bore Gages
Hey! Yes it is! Left GR about 6 months ago.... We are looking at several options including air gaging, ceramic or nylon contact points etc.
bobdoering
Stop X-bar/R Madness!!
If you are looking for precision measurements, I would write off nylon tips. Air gaging is likely your best bet. You can also look at Western Gage air gages. They are also better at picking up out of round, and don't have the gage error that dial bore gages of being cocked off axis.
The closer to non-contact your method is, the less of a problem you will have.
K
kgriff
I agree that air gaging may be your best bet. We use extensive air gaging at the facility where I work. We have found it to be an excellent solution for many ID measurements, as well as OD, where necessary. The newer Marposs air gage setup is pretty nice.
sarasheed
I suggest you to use 3-Point Internal Micrometers supplied by M/s.TESA.This instruments are easy to operate and will not damage the surface finish of the part.
5
56flh
At one time we used a trimic to check bores but found that they will not pick up an out of round condition too easily, a two point bore gage does a much better job of this.
bobdoering
The key to that issue is whether you have tri-lobal or bi-lobal variation in your roundness.
G Uncertainty Budget Examples for Caliper, Micrometer and Dial Gauge Measurement Uncertainty (MU) 3
N Digital vs Dial Caliper Comparison Measurement Uncertainty (MU) 17
C ISO 9001:2008 Audit Major Finding - Dial Calipers not set to zero ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
N Procedure/calculation for determining the foot pressure of dial thickness gauge General Measurement Device and Calibration Topics 11
E How to perform Discrimination check for Dial Indicator? General Measurement Device and Calibration Topics 2
N Calibration Method of Dial Thermometer Gauges General Measurement Device and Calibration Topics 7
R Pressure Test Dial Gage Selection Quality Tools, Improvement and Analysis 1
S Interpreting the Calibration Report for my Dial Indicator General Measurement Device and Calibration Topics 3
D Calibration of a Dial Indicator only used to indicate 0 General Measurement Device and Calibration Topics 7
W Measuring the Dial Torque of Plastic Insulin Pen devices Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
F What are the Advantages of a Digital Caliper Compared with a Dial Caliper? General Measurement Device and Calibration Topics 8
G Dial Indicator Calibration Frequency - ASME/ANSI B89.1.10M-1987 Calibration Frequency (Interval) 4
J I'm looking for a Thin Drop Dial Indicator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
U Dial Gages of all types in company flood - How to recover them General Measurement Device and Calibration Topics 6
M Looking for a copy or template of a In House Calibration Report for a Dial Indicator General Measurement Device and Calibration Topics 1
Q Mitutoyo USB Cables for Variables Data Collection using a Dial Snap Gage Statistical Analysis Tools, Techniques and SPC 2
A Dial Test Indicator Repair Procedure General Measurement Device and Calibration Topics 3
A Magnification for One Stage Dial Gauge Mechanism General Measurement Device and Calibration Topics 1
J Performing Internal Calibrations - Dial gauges, micrometers, height gauges, calipers General Measurement Device and Calibration Topics 8
1 Acceptance criteria and related standard for 1 micron Lever Type dial Indicator General Measurement Device and Calibration Topics 5
L Calibration of Dial Thickness Gauge - What reference standard need I follow? General Measurement Device and Calibration Topics 5
Z Dial Test Indicator Flaw General Measurement Device and Calibration Topics 7
A Dial Test Indicator Design & Operation when Approach Angle is Different General Measurement Device and Calibration Topics 5
S Digital Dial Indicator Recommendation General Measurement Device and Calibration Topics 4
N Basic MSA - A simple way to complete an MSA study on Dial Calipers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Q Dial Indicator Verification Procedure - ANSI/ASME B89.1.10M-2001 General Measurement Device and Calibration Topics 13
D Calibration vs. Verification - Can we calibrate dial indicators in-house? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
apestate Etalon Dial Caliper Gage Information Needed General Measurement Device and Calibration Topics 2
R Validation of A Procedure for Calibrating Dial Calipers using Traceable Gauge Blocks General Measurement Device and Calibration Topics 6
C Verification vs. Calibration of Dial Weight Dynamometer General Measurement Device and Calibration Topics 4
L Best Caliper for Shop Use? Digital vs. Dial Caliper vs. Vernier-type General Measurement Device and Calibration Topics 53
J How to Calibrate a Digimatic Dial Indicator? General Measurement Device and Calibration Topics 5
D ANSI B89.1.10, AGD and Mil A-A-2348 Dial Indicator Standards Various Other Specifications, Standards, and related Requirements 2
T How to calibrate dial indicators, gauges and scales General Measurement Device and Calibration Topics 22
J Dial Caliper or Digital Caliper - Which is the best? General Measurement Device and Calibration Topics 27
I What is Gauge Capability? Dial Thickness Gage and Digital Vernier Calipers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
C Struggling to teach a co-worker how to read dial calipers, any advice? General Measurement Device and Calibration Topics 13
J Caliper repair procedure - I need a caliper repair procedure for dial calipers General Measurement Device and Calibration Topics 2
C What is the proper method for cleaning dial calipers? General Measurement Device and Calibration Topics 4
M Lever type dial gauge - Usage of a dimensional 'test indicator' for measurement General Measurement Device and Calibration Topics 10
apestate Calibrating .001" resolution Dial Calipers - Calibration and safeguarding procedure General Measurement Device and Calibration Topics 6
E What is the smallest graduation (resolution) available for a Dial Test Indicator? General Measurement Device and Calibration Topics 2
Q Calibration Wording for a Dial Indicator WI General Measurement Device and Calibration Topics 1
B How to Calibrate a Dial Indicator General Measurement Device and Calibration Topics 13
J Dial Calipers vs. Digital Calipers - Has anyone replaced all their dial indicators? General Measurement Device and Calibration Topics 5
P Dial Gauge (gage) Calibration Software Calibration and Metrology Software and Hardware 2
D Dial Indicator (Analogue) Calibration Work Instructions General Measurement Device and Calibration Topics 3
R Do Brands Matter When Purchasing Bore Gauge? General Measurement Device and Calibration Topics 2
GURU SDI Leak Testing - O-ring installation in the groove of Bore ID Problem Solving, Root Cause Fault and Failure Analysis 4
