Dial Gages of all types in company flood - How to recover them
U
Unregistered
We had severe rain leaks in the lab over the weekend. Dial gages, indicators, ring and pin gages...all under water in their job specific totes.
Don't want to blow on backs of dial gages to dry them because it pushes the water up to dial face area. Hundreds of production gages involved.
What do we do??? dip or spray with WD40? And then what?
bobdoering
Stop X-bar/R Madness!!
You might want to send this question to George Schuetz, the Director of Precision Gages, for Mahr Federal, Inc., of Providence, RI. He often answers questions like this as his role of "Ask an Expert" for Modern Machine Shop magazine. I would be anxious to hear his response. I have some ideas, but they would require some knowledge of tearing down an indicator, ultrasonic cleaner, a low-temp recirculating oven and a dessicator.
Marc
I agree with Bob, but I would do the following immediately:
1. Since you have an outside calibration source, I would call them immediately, explain the situation and ask their advice. This is assuming your outside calibration source does gage repair work.
2. I would call the manufacturer of one or more of the gages and do the same.
My advice is to do this *immediately*. It doesn't take long for oxidation to go to work (so to speak) on many metals, and the advice of one or more *experts* is needed fast.
Wes Bucey
I agree with Bob and Marc about immediate outside professional help. Oxidation can destroy many instruments in less than hours. Drying out can speed oxidation in many cases. I'm aware of one museum project which recovered artifacts from beneath the sea and keeps them stored under water to avoid oxidation and other deterioration while they prepare to get them ready for display and permanent storage.
As a guy who was once fiscally liable for EVERYTHING and therefore vitally interested in Risk Assessment and Management, I'd start examining my insurance policies - whether you replace or repair, it's going to be an expensive proposition.
U
Unregistered
Bob and Marc,
Thank you for the advice. I have contacted Mitutoyo because we have a few more Mitu than Mahr Federal. They suggested air drying and a low temp furnace if possible. They didn't feel that it shouldn't harm too much as long as dirt didn't ingress.
I have contacted George Schuetz and am waiting for a reply. We will see what happens.
Marc,
Please remove this as it is just for You and Bob.
U
Unregistered
I heard back from George Schuetz at Mahr Federal, Inc. His opinion was that if we emptied the water out of the gages and air dried them, then oil them lightly, we should be ok. I told him that some indicators are bore gages with long stems and he approved of the thought of taking the stems apart and dipping them in liquid WD-40. As long as just oil was in the indicator after it dried. We dipped everything that was not mechanical in a bucket of WD-40 after towel and air drying.
George then said to work the gages in their respective ring gages to be sure of full motion. Bottom line was that as long as things were opened up and allowed to dry, there shouldn't be a problem unless dirt got in. Because Mahr and Mitutoyo gages are made of stainless steel and copper there shouldn't be a great rust issue.
Finally, thanks to Wes Bucey for his suggestion to get insurance items in order.
Bob and Marc, thank you for your quick help and direction.
G Uncertainty Budget Examples for Caliper, Micrometer and Dial Gauge Measurement Uncertainty (MU) 3
N Digital vs Dial Caliper Comparison Measurement Uncertainty (MU) 17
C ISO 9001:2008 Audit Major Finding - Dial Calipers not set to zero ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
N Procedure/calculation for determining the foot pressure of dial thickness gauge General Measurement Device and Calibration Topics 11
E How to perform Discrimination check for Dial Indicator? General Measurement Device and Calibration Topics 2
N Calibration Method of Dial Thermometer Gauges General Measurement Device and Calibration Topics 7
R Pressure Test Dial Gage Selection Quality Tools, Improvement and Analysis 1
S Interpreting the Calibration Report for my Dial Indicator General Measurement Device and Calibration Topics 3
D Calibration of a Dial Indicator only used to indicate 0 General Measurement Device and Calibration Topics 7
W Measuring the Dial Torque of Plastic Insulin Pen devices Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
F What are the Advantages of a Digital Caliper Compared with a Dial Caliper? General Measurement Device and Calibration Topics 8
G Dial Indicator Calibration Frequency - ASME/ANSI B89.1.10M-1987 Calibration Frequency (Interval) 4
J I'm looking for a Thin Drop Dial Indicator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Looking for a copy or template of a In House Calibration Report for a Dial Indicator General Measurement Device and Calibration Topics 1
Q Mitutoyo USB Cables for Variables Data Collection using a Dial Snap Gage Statistical Analysis Tools, Techniques and SPC 2
A Dial Test Indicator Repair Procedure General Measurement Device and Calibration Topics 3
A Magnification for One Stage Dial Gauge Mechanism General Measurement Device and Calibration Topics 1
C Dial Bore Gage Contact Points leaving witness/burnish marks General Measurement Device and Calibration Topics 10
J Performing Internal Calibrations - Dial gauges, micrometers, height gauges, calipers General Measurement Device and Calibration Topics 8
1 Acceptance criteria and related standard for 1 micron Lever Type dial Indicator General Measurement Device and Calibration Topics 5
L Calibration of Dial Thickness Gauge - What reference standard need I follow? General Measurement Device and Calibration Topics 5
Z Dial Test Indicator Flaw General Measurement Device and Calibration Topics 7
A Dial Test Indicator Design & Operation when Approach Angle is Different General Measurement Device and Calibration Topics 5
S Digital Dial Indicator Recommendation General Measurement Device and Calibration Topics 4
N Basic MSA - A simple way to complete an MSA study on Dial Calipers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Q Dial Indicator Verification Procedure - ANSI/ASME B89.1.10M-2001 General Measurement Device and Calibration Topics 13
D Calibration vs. Verification - Can we calibrate dial indicators in-house? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
apestate Etalon Dial Caliper Gage Information Needed General Measurement Device and Calibration Topics 2
R Validation of A Procedure for Calibrating Dial Calipers using Traceable Gauge Blocks General Measurement Device and Calibration Topics 6
C Verification vs. Calibration of Dial Weight Dynamometer General Measurement Device and Calibration Topics 4
L Best Caliper for Shop Use? Digital vs. Dial Caliper vs. Vernier-type General Measurement Device and Calibration Topics 53
J How to Calibrate a Digimatic Dial Indicator? General Measurement Device and Calibration Topics 5
D ANSI B89.1.10, AGD and Mil A-A-2348 Dial Indicator Standards Various Other Specifications, Standards, and related Requirements 2
T How to calibrate dial indicators, gauges and scales General Measurement Device and Calibration Topics 22
J Dial Caliper or Digital Caliper - Which is the best? General Measurement Device and Calibration Topics 27
I What is Gauge Capability? Dial Thickness Gage and Digital Vernier Calipers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
C Struggling to teach a co-worker how to read dial calipers, any advice? General Measurement Device and Calibration Topics 13
J Caliper repair procedure - I need a caliper repair procedure for dial calipers General Measurement Device and Calibration Topics 2
C What is the proper method for cleaning dial calipers? General Measurement Device and Calibration Topics 4
M Lever type dial gauge - Usage of a dimensional 'test indicator' for measurement General Measurement Device and Calibration Topics 10
apestate Calibrating .001" resolution Dial Calipers - Calibration and safeguarding procedure General Measurement Device and Calibration Topics 6
E What is the smallest graduation (resolution) available for a Dial Test Indicator? General Measurement Device and Calibration Topics 2
Q Calibration Wording for a Dial Indicator WI General Measurement Device and Calibration Topics 1
B How to Calibrate a Dial Indicator General Measurement Device and Calibration Topics 13
J Dial Calipers vs. Digital Calipers - Has anyone replaced all their dial indicators? General Measurement Device and Calibration Topics 5
P Dial Gauge (gage) Calibration Software Calibration and Metrology Software and Hardware 2
D Dial Indicator (Analogue) Calibration Work Instructions General Measurement Device and Calibration Topics 3
S Formula for Calculating NoGo Major Diameter for UN gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
