Diameter Measurement advice requested
pyroracing85
I am currently having an argument on a diameter call out. The diameter is 83mm +-.3mm. However their arguement that is on an AVERAGE basis... They are saying that on a a point to point I can be measured out but as an average as long as they are in it is good. THey do have another callout that their min/max is +-.5mm. So as to not exceed a .5 from one high to a low.
I always thought that on any point to point measurement the diameter HAD to ALWAYS be in spec. Also, the circulaty of a diameter was always written out as not to exceed the overall tolerance which in this case is .6mm (+-.3mm)
Any thoughts would GREATLY help.
We see this all the time as everything we do is round. I have seen it done your way, and argued about it. I don't know what the "official" requirement is, but in my world all dia. call outs are via an average. If we put it on our cmm, that what it give us. If you want to address roundness, etc. their are separate call out for those. Good luck.
So how did we do it before CMMs? If I were taking a say micrometer do I just keep measuring and compile all my readings until I hope to get an average reading?
I mean CMMs weren't around forever doing the calculations for us...
It REALLY depends on the use. But in general it should never be an average reading. There is an old saying that the Mississippi River is on average deep enough for a boat to get through. But the edges will ground any boat.
I like that saying...
Now, do we know of any GD&T law that states this? We can argue for days if it isn't documented...
multiple readings with a caliper (or whatever gage you use), then average them together. Did it for years before we got the cmm.
Below is Grok’s answer:
You’re correct in your understanding – and the way you’re thinking is the standard, correct interpretation in almost all precision machining and GD&T-based engineering drawings (ASME Y14.5 or ISO 1101/8015). Let’s break this down clearly so you can win the argument with facts.
1. What a diameter tolerance of Ø83 ±0.3 mm actually means
  • Rule: At every cross-section along the length of the cylinder, the local (point-to-point) diameters measured with a micrometer, CMM, bore gage, etc. must fall between 82.7 and 83.3 mm.
  • This is called the Rule of Local Size (ASME Y14.5) or the Principle of Independency (ISO).
    → The feature must respect the ±0.3 mm tolerance everywhere, not just “on average”.
What they are claiming (“as long as the average is good”) is not acceptable unless the drawing explicitly says something like “average diameter” or uses a special note (extremely rare on real production drawings).
2. The extra “±0.5 mm min/max” callout they mentioned
That is almost certainly a separate straightness or profile tolerance on the surface or axis, or perhaps a runout/taper requirement.
Typical wording you see:
  • “Surface must lie within Ø0.5 mm envelope”
  • “Max difference between any two diameters ≤ 1.0 mm” (which would be ±0.5 from nominal)
  • Profile of a surface | tol 1.0 (or 0.5 A/B depending on datum)
That ±0.5 mm callout is an additional form/orientation constraint. It does not relax the basic diameter tolerance from ±0.3 to ±0.5.
In fact, it’s the opposite: the tighter ±0.3 mm local size still applies, and the ±0.5 mm just puts an extra limit on taper, barreling, etc.
3. Circularity (roundness) and its relationship to diameter tolerance
You are again 100% correct: Per ASME Y14.5 and ISO 1101, circularity tolerance can never exceed the size tolerance (the “Envelope Principle” or Rule #1).
So if size is ±0.3 mm (total tolerance zone 0.6 mm), the maximum allowable circularity is 0.6 mm (in practice usually much tighter, e.g. 0.05–0.15 mm).
If someone is trying to say “it’s out of round by 0.8 mm but the average diameter is still 83 mm so it’s okay” → that is rejected parts, period.
Summary – how to shut the argument down
Tell them (politely but firmly):
“The diameter callout Ø83 ±0.3 requires every measured two-point diameter to be between 82.700 and 83.300 mm at every cross-section. ‘Average diameter’ is not a valid acceptance criterion unless the drawing explicitly states it (which it doesn’t). The additional ±0.5 mm min/max callout is a form/orientation control (probably profile or straightness of the surface) and does not override or relax the basic size tolerance. This is per ASME Y14.5 Rule #1 and ISO 1101 independency principle.”
If they still push back, ask them to show you exactly where on the drawing it says “average diameter” is acceptable. They won’t find it.
You’re right. They’re wrong. Parts that are locally outside 82.7–83.3 mm are scrap or need a concession/deviation.
That’s it in long form…with the receipts.
People who want to use the average want to pass anything.
That's great. But be careful what you wish for. Better know the end use and the need for precision because you now may need to get our your drawings and modify every one. In our case, you just blew our capabilities out of the water. Would be physically impossible to meet the print, 100s of them -- yes the physics gods won't allow it. Customer would need to "redesign" hundreds of prints from designs that have been working for 50+ years. In our case is, for our products, it's not vital as the parts will take the proper shape when assembled.
And make no mistake. Today, that is a very difficult task. We have had engineers "give up" when redrawing a print as the cad software has difficulty representing the actual part vs. the theoretical part. Fun times indeed.
