Dielectric Strength of Triple Insulated Wire to comply with 2MOPP
Roland chung
Hello all,
As we know, Annex L of IEC 60601-1:2005 is derived from Annex U of IEC 60950. After reading the Annex L closely, I found it is really difficult to find a triple insulated wire (TIW) to comply with 2MOPP since the test voltage of TIW for 2MOPP is too high.
For example, the max.measured voltage between HF transformer is 590 Vpeak. According to Table 6, the test voltage for 2MOPP is 4664 Vrms. So the test voltage for TIW is 9328 Vrms based on the L.3 (i.e. The test voltage is at least twice the appropriate voltage in Table 6 and Table 7).
Any thoughts?
Thanks and regards,
Roland
Peter Selvey
This is an issue (problem) at a couple of points where IEC 60601 has adopted IEC 60950 tests without careful consideration. For example, Clause 8.9.3.3 (cemented joints) requires test voltage to be increased by a factor of 1.6. And Annex L requires double.
For IEC 60950 with moderate starting point in test voltages, this is not as big an issue (e.g. 1kV/3kV basic/double).
However, for medical the standard values of 1.5 / 4kV (and higher with even switching peaks) factors of 1.6 and 2.0 put us in an impractical region.
The 1.6 factor has already caused problems with diagnostic ultrasounds, as they often rely on cemented joints at the probe. Endoscopic type probes, designed with space constraints, can pass 1.5kV but breakdown at 2.4kV. Already 1.5kV was overkill, but 2.4kV is getting crazy.
For Annex L, at high voltages there will be a large amount of corona discharge, especially for thin insulation like triple insulated wire. Corona discharge is not a failure, but it does cause heating. I would guess that at 9.2kVrms (peak around 13kV) the corona based heating would be enough to destroy the insulation.
Of course, one solution is to treat the insulation as 2MOOP, which brings everything back to IEC 60950 requirement. In such a case, it would be necessary to have 1MOPP somewhere else in the equipment.
Roland chung
Thank you very much for your input.
Actually, the SMPS has been approved per iec 60601-1:1988/A2. And 60950 compliant TIW (6 kV) is fine for 2nd edition.
The SMPS is now applying for iec 60601-1:2005 approval. I was told that the TIW can not meet the requirements of Annex L based on the review of TIW certificate and data sheet.
The TIW supplier told us that there is no a TIW having electric strength higher than 8 kV in the market. Even the TIW is 60601-1 compliant, the test voltage for TIW is 8 kV only since the working voltage is on the basis of 250V.
It seems we have to degrade the SMPS to 2MOOP unless both primary and secondary windings are TIW.
B IEC 61010-1 - Voltage / Dielectric strength tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A IEC 60601-1 Dielectric Strength test for battery operated devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
K Dielectric strength test as per IEC 60601-1 -Infant incubator IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B Operator protection - When to apply table 7, Dielectric strength test voltage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
O Is it mandatory for Medical Devices to work properly after dielectric strength tests? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
B Standard for Dielectric Strength Test IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E IEC 61010-1 Dielectric strength test of inner power supply Other ISO and International Standards and European Regulations 0
S IEC 60601-1 Electrical safety testing - Dielectric Strength Test - 8.8.3 IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S Leakage Current test and Dielectric strength for Battery operated ECG device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
M HF/RF Generator for dielectric strength IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R Dielectric Strength of Electroshock - IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P Humidity Pre-Conditioning before leakage current and dielectric strength tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
S Input to Ouput Dielectric Strength PSU IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
C INMETRO 350 Dielectric Strength Test to IEC 60601-1 clauses 18, 19 and 20 Other Medical Device Regulations World-Wide 5
S Issues with Dielectric Strength Testing - IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
R Current Limit in IEC 60601 Dielectric Strength Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A Internally Powered Medical Device and Dielectric Strength IEC 60601 - Medical Electrical Equipment Safety Standards Series 17
E Routine production tests - dielectric voltage withstand test IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J Production Line Test Brasil - High Voltage Dielectric Strenght Test Other Medical Device Regulations World-Wide 5
T Tests IEC 60601-1 - Grounding Resistance, Leakage Current and Dielectric Rigidity in an automated way IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B Dielectric Test of Battery Powered Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
J Transformer Compliance Testing, overheat then humidity treat, then dielectric test? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R Dielectric Test for Ambulatory ECG Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
I Dielectric Test for HF Surgical Equipment (IEC 60601-2-2 clause 201.8.5.1.2) IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D IEC 60601-2-37 - No Dielectric testing specifications? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
P Average Peel Strength - Interpretation of BS EN 868-5:2018 and ASTM F0088/F0088M Other Medical Device Related Standards 2
M Testing Tensile Strength of Materials AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
P Test Method Validation for Tensile Strength Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Tensile Strength Testing of Rubber Underwear Manufacturing and Related Processes 2
D What is your Sterile Medical Device Pouch Peel Strength Spec? Other Medical Device Related Standards 3
N Strength verification of surgical instruments ISO 13485:2016 - Medical Device Quality Management Systems 5
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
D Hot Plate Welded Plastic Strength Validation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S GRR (Gage Repeatability and Reproducibility) for Material Strength Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
triathlonx13 Rubber - Tear and Adhesion Strength Peel Cross Head Speed Design and Development of Products and Processes 3
R How to Inspect the Weld Strength of High Pressure Vessel & Oil Pipe Line Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
E Laser Marking effects on the Fatigue Strength of Alloys CE Marking (Conformité Européene) / CB Scheme 6
B Management Tool - Does each of them have their STRENGTH and WEAKNESSES? Misc. Quality Assurance and Business Systems Related Topics 10
A Sample Size Selection for Peel Strength for Variable Data using a 95%/99% Confidence Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
7 Data Analysis of Tensile Strength Test - Graphical Presentation of Results Statistical Analysis Tools, Techniques and SPC 2
B Laser Weld Strength - Laser Welding Medical Instruments Reliability Analysis - Predictions, Testing and Standards 8
G Tensile Strength Distribution - Why a Weibull distribution is used? Reliability Analysis - Predictions, Testing and Standards 6
J Flexural Strength Testing - Analytical Laboratory recommendations for Testing Alumina Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
7 SPC Monitoring for Pouches Manufactured Last Year - Tensile Strength Statistical Analysis Tools, Techniques and SPC 8
M HSLA100 (High Strength Low Alloy Steel) Welding Procedure and Consumables Manufacturing and Related Processes 3
D ESD Quantification - Standalone instrument that can log ESD field strength ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N ISO 34: Rubber, vulcanized or thermoplastic - Determination of tear strength Other ISO and International Standards and European Regulations 1
H Testing the Durability and Strength of Copper Wire Manufacturing and Related Processes 2
M ASTM F88 Standard Test Method for Seal Strength - Designation F88-09/M88-09 ver 15.1 Reliability Analysis - Predictions, Testing and Standards 6
