hi
we got an infant incubator for safety testing as per IEC 60601-1. I am new to the testing field. So after reading the standard (which are a little bit difficult for me to interpret )and some old reports, I made these points on which HV test should be done.
Please check if I am doing it right or if I missed anything.
also, while reading other threads on this topic, people are suggesting not to do HV test on an assembled device(it is a class I device), then how should I do testing?
it will be very helpful to me in understanding things.
PS: The insulation diagram given by the manufacturer is attached.
1. between Line neutral shorted and earth
2. between line neutral shorted and the display panel (using metal foil)
3. between line neutral shorted and the applied part ( which is infant temperature sensor)
4. between line neutral shorted and the metallic enclosure.
the incubator has SMPS which is an approved component.Please check if I am doing it right or if I missed anything.
