Difference a gage can detect - Similar Parts
K
Kelly2300
Oftentimes, after we have established a gage and completed a Gage R&R, a similar (but not the same part) is introduced either on the floor or on the machine. The question then becomes, is the Gage able to distinguish between the two. We would like to answer this question often before there are parts available. Is there a way to use Gage R&R results to do this?
John Nabors - 2009
Re: Difference a gage can detect
What sort of gage? What kind of features/characteristics does it check?
justncredible
Are the sizes of the parts that are measured close? Is the tol. of the said parts close? What is the NDC of the gage?
K
Kelly2300
It can vary what it is measuring. For the sake of discussion let's say it is length. The tolerances are usually close .7 mm is a good example. The NDC of the gage varies but it usually isn't far over the required 10.
justncredible
Call up the SQE and discuss it, I think they will accept it as good, the gage is proven for that range.
K
Kelly2300
I don't understand your last reply...it isn't a different part we are getting in by mistake, it is a "new design" that is entering production that we need to be able to distinguish...
It's not real clear what you want the gage to do. You have different-but-similar parts, and you want the gage to be able to tell the difference between part A and part B? Is this some sort of automated system? Is there potential for the parts to be mixed up, and you want the gage to "sort" them? Or do you just want to be able to use the same gage for both parts?
True Position
I'm having trouble following exactly what you are asking. Are you asking if you can use the same GRR for a group of similar parts instead of doing MSA studies on each?
K
Kelly2300
There are two close but different parts by design. The parts will be run on the same machine, we need to know whether the gage can catch the difference if they should happen to get mixed.
L What is the the difference between the Gage R&R Nested Anova and ISO/REMCO N263? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
V Difference between Gage R&R and Round Robin testing? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
M Correction for Part/Master material difference in gage block comparison testing General Measurement Device and Calibration Topics 2
R Definition GAGE vs. GAUGE - Difference between Gage and Gauge Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
P The difference between Gage Discrimination and Least Count Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Definition Gage and Gauge - Difference between the terms Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 45
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Terminal Lugs sizes - Difference between 225/24 vs. 275/24 lugs Manufacturing and Related Processes 2
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
Y Labeling difference for storage and operating conditions EU Medical Device Regulations 1
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 3
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
gramps What is the difference between discrete and continuous variables? Problem Solving, Root Cause Fault and Failure Analysis 3
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 4
Nicole Desouza The Difference of being AS 9100D Compliant vs.Certified AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
R The difference b/w FMEA & Risk analysis as per iso 14971 ISO 14971 - Medical Device Risk Management 8
P What is the exact difference between Risk and Opportunity in context of ISO 27001? IEC 27001 - Information Security Management Systems (ISMS) 7
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
O Air Flow - Which is the operational difference between LAF (vertical and horizontal) and RLAF? Manufacturing and Related Processes 2
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
S DO 178B - What is the difference between review and verification? Federal Aviation Administration (FAA) Standards and Requirements 1
T The difference between SOP and Kaizen Standardization Lean in Manufacturing and Service Industries 2
K Difference between intended purpose and intended use of the device EU Medical Device Regulations 9
S Difference between an Advisory Notice (ISO 13485) and a Field Safety Notice? ISO 13485:2016 - Medical Device Quality Management Systems 3
T Difference between "data analysis" and "management review" ISO 13485:2016 - Medical Device Quality Management Systems 4
qualprod What is the difference between 7.4.1 (2008) and 8.4.1 (2015)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Is there a difference in the process? Analyze residuals, construct interval estimate Using Minitab Software 2
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
S Certification Body, Registrar, Notified Body - What is the difference? Registrars and Notified Bodies 3
S The difference between a Medical Device Accessory and Component Canada Medical Device Regulations 2
S What is the difference between a service request and a complaint? ISO 13485:2016 - Medical Device Quality Management Systems 2
Q AS 9100 C and D Purchasing requirements difference AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R Difference Process Objective/Opportunity for improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
