Difference between a subcontractor and a supplier
Thomas Dorner
I am struggling with the definition of a subcontractor and a supplier. What is the difference.
ISO 9000 doesn't help in this matter.
I hope to get some answers from this forum, which helps clarifying this problem.
Thank you,
Thomas
Ninja
Looking for Reality
If it helps...I draw the line based on whether or not I direct what product is made.
If I buy a box of crayons, it's a supplier.
If I specify I want only black crayons and they specially box it for me...it's still a supplier.
If I have them make a new color just for me...it becomes a rather grey area.
If I specify size, shape, color and material...it's a subcontractor.
But that's me. As Jim said, it's context (not just yours, but your customer's opinion too).
If I stop making a part, and have someone else make it for me...no question, it's a subcontractor.
If I stop making a part because someone else already makes it...and I choose to buy from them, supplier.
John C. Abnet
Teacher, sensei, kennari
Good day @Thomas Dorner ;
You've received some good advice for considering how to identify each. As you can infer from the responses, while there may be "best"/most appropriate uses of each of the terms, it matters not so much how your organization defines the terms as long as they are applied CONSISTENTLY and commonly within your organization (to avoid confusion...not because of any requirement).
ISO 9000:2015 defines "Provider" (supplier) as follows...
"Organization that provides a product or service."
(pretty broad).
Within that definition it goes on to give examples and notes, which reference terms such as "Producer", "distributor", "retailer", "vendor", "contractor". Each have their ideal "best" application, but as mentioned prior, the ultimate determination of how /where to use any of these terms can be determined by your organization. (I would council that the dictionary may help you in that determination).
Hope this helps.
Be well.
Pancho
wikineer
Anyone retained under contract to perform work is a contractor. If the work to be performed is part of the buyer's fulfillment of another contract where they are the supplier, then the seller is a sub-contractor.
Since all buy-sell transactions have an implicit contract, then all suppliers are technically contractors. But contractor (and sub) is more often associated with at least some service components in the supply and some negotiation in the contract. Suppliers that are not usually thought of as contractors usually include little or no service components, or have non-negotiated supply agreements.
TL;DR terms overlap too much, so we don't worry about the distinction.
I always considered suppliers to be the providers of raw materials or component parts. Subcontractors were companies that we would send sub-assemblies out to perform work that we could not do internally such as plating. But, as Jim W said, it is context sensitive.
It would be good to hear from the OP as to why there's concern about the difference. If we follow Miner's model (which is a common way of looking at the question), all subcontractors are suppliers, but not all suppliers are subcontractors.
Ninja
Looking for Reality
Agreed. Is there a clause somewhere prescribing additional effort for one or the other?
Also agreed with this.
I wonder what the term in Miner's model would be if Process 1 were also outsourced...wouldn't Process 2 simply become Process 1, fed by Supplier?
Provider seems like a nice catch-all term.
H API monogram 4F, The difference between PSL-1 & PSL-2 Oil and Gas Industry Standards and Regulations 5
G What's the difference between 1.32 and 1.33 Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 18
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Terminal Lugs sizes - Difference between 225/24 vs. 275/24 lugs Manufacturing and Related Processes 2
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 3
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
gramps What is the difference between discrete and continuous variables? Problem Solving, Root Cause Fault and Failure Analysis 3
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 4
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
P What is the exact difference between Risk and Opportunity in context of ISO 27001? IEC 27001 - Information Security Management Systems (ISMS) 7
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
O Air Flow - Which is the operational difference between LAF (vertical and horizontal) and RLAF? Manufacturing and Related Processes 2
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
S DO 178B - What is the difference between review and verification? Federal Aviation Administration (FAA) Standards and Requirements 1
T The difference between SOP and Kaizen Standardization Lean in Manufacturing and Service Industries 2
K Difference between intended purpose and intended use of the device EU Medical Device Regulations 9
S Difference between an Advisory Notice (ISO 13485) and a Field Safety Notice? ISO 13485:2016 - Medical Device Quality Management Systems 3
T Difference between "data analysis" and "management review" ISO 13485:2016 - Medical Device Quality Management Systems 4
qualprod What is the difference between 7.4.1 (2008) and 8.4.1 (2015)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
S The difference between a Medical Device Accessory and Component Canada Medical Device Regulations 2
S What is the difference between a service request and a complaint? ISO 13485:2016 - Medical Device Quality Management Systems 2
I What is the difference between OOS/OOT Imported Legacy Blogs 3
A Definition Difference between Quality System Procedure and Standard Operating Procedure (SOP) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
Q Difference between Monitor & Measurement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T QA vs. RA - The difference between QA and RA Coffee Break and Water Cooler Discussions 6
A Difference between Discrimination and Least Count IATF 16949 - Automotive Quality Systems Standard 2
K Difference between Medical Electrical Equipment and Medical Equipment System IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Usability Standard - The difference between IEC 60601-1-6 to IEC 62336 Human Factors and Ergonomics in Engineering 1
S What is the difference between Verification and Validation of Test Reports? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
armani Difference between ISO 9001:2015 Clauses 8.1 and 8.5.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M IATF 16949 Cl. 8.4.2.2 vs 8.6.5 - Is there any difference between these clauses? IATF 16949 - Automotive Quality Systems Standard 7
C What is the difference between "Overall Risk" and "Risk"? (ISO 14971) ISO 14971 - Medical Device Risk Management 10
C The difference between a Critical Dimension vs. Critical Characteristic Misc. Quality Assurance and Business Systems Related Topics 2
