Difference between a subcontractor and a supplier
#11
@Ninja I've had that scenario also where we had a supplier ship parts to a plater who then shipped them to us for further processing. In that case we called them both suppliers. The only time we used subcontracting is where we initially had product in house then sent it out for processing then received it back in house. Again, that is just the way we handled it.
#12
An OEM might arrange to purchase an assembly from a single supplier. That supplier might opt to subcontract certain components of the assembly, and in some instances all of the components. Thus for a single-sourced assembly there might be several subcontractors. The prime supplier of the assembly is responsible to its customer--the OEM-- for all of the specifications and requirements for each component as well as the finished assembly. In reality, supply chains can branch out all over the place. For example, a subcontractor as defined above might in turn "farm out" part of the work to its own subcontractor. There are no simple answers to the question.
Ninja
Looking for Reality
#13
Just to add a new wrinkle for the heck of it...
An OEM buys a part from me...as sole supplier...
I don't make it, any part of it...I buy it, make sure it looks pretty, remove the label, put my own label on it.
What am I (other than a guy who sees a great opportunity when he sees one)?
More to the point, is my supplier a contractor? Subcontractor? manufacturer?
And who is my provider to the OEM?
Agreed, context and complexity.
#14
My current company also does some of this. We call it brand labeling (except we have them put our label on it) and we call them "factored product suppliers" as in factor = agent. This is probably unique to my company.
Big Jim
#15
The terms are interchangeable. Just like trying to determine a difference between a vendor and a supplier your knocking your heads against the wall.
Vendor is defined as an entity that sells things. Supplier is defined as someone that provides things. So technically if you can find a provider that doesn't charge you for it that entity would not be a vendor. In business that is not sustainable.
Was sub-contractor is a term left over from the 1994 version?
ISO 9001:1994 used the term "supplier" for the subject of the standard, and it was replaced by "organization" in the 2000 version. So if the "organization" used to be called the "supplier", what would you call the entity that the "supplier" bought from?
Cari Spears
#16
We decided to define the difference because we have different expectations from a supplier that's picking off the shelf, and a subcontractor that is doing work to print. Subcontractors have all kinds of requirements that we do not expect material and component suppliers to have.
Define your suppliers however it makes sense.
Big Jim
#17
Absolutely you can define them any way you want internally. It would be wise to not forget that it doesn't necessarily apply to other organizations you interface with. That's where it gets confusing.
Ed Panek
QA RA Small Med Dev Company
#18
If you train and sign off to our SOPs and forms (QMS) you are considered a contractor. If you are evaluated without training to our QMS you are a supplier.
Cari Spears
#20
Why not use the term "external provider" for both?
In our case, we created two different categories because we have different requirements and extent of control of each category.
Distributors simply go straight on the list and we monitor their order accuracy and on-time delivery. Subcontractors may have to undergo on-site audits for particular processes; they may need to be approved to our customers' standards for things like DPD and welding; they might need certified personnel to perform particular processes; etc.
They're all suppliers, or vendors, or external providers - whatever you choose to call them. We chose to define the two categories because it makes sense for us.
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Terminal Lugs sizes - Difference between 225/24 vs. 275/24 lugs Manufacturing and Related Processes 2
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 3
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
gramps What is the difference between discrete and continuous variables? Problem Solving, Root Cause Fault and Failure Analysis 3
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 4
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
P What is the exact difference between Risk and Opportunity in context of ISO 27001? IEC 27001 - Information Security Management Systems (ISMS) 7
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
O Air Flow - Which is the operational difference between LAF (vertical and horizontal) and RLAF? Manufacturing and Related Processes 2
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
S DO 178B - What is the difference between review and verification? Federal Aviation Administration (FAA) Standards and Requirements 1
T The difference between SOP and Kaizen Standardization Lean in Manufacturing and Service Industries 2
K Difference between intended purpose and intended use of the device EU Medical Device Regulations 9
S Difference between an Advisory Notice (ISO 13485) and a Field Safety Notice? ISO 13485:2016 - Medical Device Quality Management Systems 3
T Difference between "data analysis" and "management review" ISO 13485:2016 - Medical Device Quality Management Systems 4
qualprod What is the difference between 7.4.1 (2008) and 8.4.1 (2015)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
S The difference between a Medical Device Accessory and Component Canada Medical Device Regulations 2
S What is the difference between a service request and a complaint? ISO 13485:2016 - Medical Device Quality Management Systems 2
I What is the difference between OOS/OOT Imported Legacy Blogs 3
A Definition Difference between Quality System Procedure and Standard Operating Procedure (SOP) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
Q Difference between Monitor & Measurement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T QA vs. RA - The difference between QA and RA Coffee Break and Water Cooler Discussions 6
A Difference between Discrimination and Least Count IATF 16949 - Automotive Quality Systems Standard 2
K Difference between Medical Electrical Equipment and Medical Equipment System IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Usability Standard - The difference between IEC 60601-1-6 to IEC 62336 Human Factors and Ergonomics in Engineering 1
S What is the difference between Verification and Validation of Test Reports? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A Difference between ISO 9001:2015 Clauses 8.1 and 8.5.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M IATF 16949 Cl. 8.4.2.2 vs 8.6.5 - Is there any difference between these clauses? IATF 16949 - Automotive Quality Systems Standard 7
C What is the difference between "Overall Risk" and "Risk"? (ISO 14971) ISO 14971 - Medical Device Risk Management 10
C The difference between a Critical Dimension vs. Critical Characteristic Misc. Quality Assurance and Business Systems Related Topics 2
A ISO 9001:2015 - The difference between 6.1.1b and 6.1.1d - IMHO, d) implies b) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A Difference between requirement for 4.4.1a (inputs) and 4.4.1d (resources needed)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
