Difference between Calibration, Verification and Adjust (Adjustment)
L
landy
Hi all,
Who can help me to explain the difference between "calibration","verification","adjust"? Can you give me a example?Thanks
harry
Re: Difference between calibration, verification and adjust
Hi all,
Huan Ying (Welcome) Landy,
We had extensive discussions on these terms over here. If you do a search, you'll find many related threads including the following:
Calibration vs. Verification of Calibration vs. Verification - Definitions
Calibration? Verification? Is this a calibration?
Calibration vs. Verification - Definition of
I find the definitions in this attached document to be acceptable also.
Marc
Thanks, Harry. BTW - I changed the document name to Calibration Definitions.pdf so it shows up alphabetically with respect to Calibration in the Attachments Listing. I apologise for nit picking the name... But, you know me! ;)
Marc
I thought about this a bit, and I thought Adjustment isn't brought up a lot. The things to remember about adjustment are whether the instrument was Out of Tolerance or not when the device (gage, instrument, etc.) is adjusted. Often, the device is within tolerance, but has to be adjusted to be 'centered' upon a specific measurement unit.
harry
Not at all, Marc. For the benefit of those who do not understand what we are talking about, Marc is particular about all these little details and spends time taking care of it in the interest of facilitating searches by users of the forum.
BradM
Yes! Adjustment is not discussed a lot, but is important. Different calibration entities have different policies about adjustment. For example, many make adjustments (wherever possible) if it is 50% of allowed tolerance. Many places only adjust if it is out of tolerance. Some places always adjust regardless of the percent deviation.
Assuming you have someone competent calibrating your equipment, two things to me are worth the money: 1) obtaining as-found data, and 2) having equipment adjusted for maximum accuracy. By always having the instrument adjusted, error creep can be minimized and reducing calibration failures due to accumulated error over time.
By analyzing the data one can make informed decisions about adjusting the calibration interval, granting cost savings that will exceed the data/adjustment extra charge.
Not forgetting, too, that some equipment can be calibrated, but not adjusted - like plain/thread plug/pin gauges, ring gauges, snap (aka 'Jo' blocks), slip, end/length and other similar 'fixed' gauging.
B Difference between Calibration & Verification and How to calibrate Go/No Go gauge? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Difference between Calibration, Testing and Inspection Laboratories? General Measurement Device and Calibration Topics 6
K What is the difference between in house calibration and verification? General Measurement Device and Calibration Topics 10
S What is the difference between Bias and Calibration? General Measurement Device and Calibration Topics 5
T Difference between written calibration procedures and calibration work instructions? General Measurement Device and Calibration Topics 8
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Terminal Lugs sizes - Difference between 225/24 vs. 275/24 lugs Manufacturing and Related Processes 2
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 3
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
gramps What is the difference between discrete and continuous variables? Problem Solving, Root Cause Fault and Failure Analysis 3
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 4
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
P What is the exact difference between Risk and Opportunity in context of ISO 27001? IEC 27001 - Information Security Management Systems (ISMS) 7
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
O Air Flow - Which is the operational difference between LAF (vertical and horizontal) and RLAF? Manufacturing and Related Processes 2
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
S DO 178B - What is the difference between review and verification? Federal Aviation Administration (FAA) Standards and Requirements 1
T The difference between SOP and Kaizen Standardization Lean in Manufacturing and Service Industries 2
K Difference between intended purpose and intended use of the device EU Medical Device Regulations 9
S Difference between an Advisory Notice (ISO 13485) and a Field Safety Notice? ISO 13485:2016 - Medical Device Quality Management Systems 3
T Difference between "data analysis" and "management review" ISO 13485:2016 - Medical Device Quality Management Systems 4
qualprod What is the difference between 7.4.1 (2008) and 8.4.1 (2015)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
S The difference between a Medical Device Accessory and Component Canada Medical Device Regulations 2
S What is the difference between a service request and a complaint? ISO 13485:2016 - Medical Device Quality Management Systems 2
I What is the difference between OOS/OOT Imported Legacy Blogs 3
A Definition Difference between Quality System Procedure and Standard Operating Procedure (SOP) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
Q Difference between Monitor & Measurement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T QA vs. RA - The difference between QA and RA Coffee Break and Water Cooler Discussions 6
A Difference between Discrimination and Least Count IATF 16949 - Automotive Quality Systems Standard 2
K Difference between Medical Electrical Equipment and Medical Equipment System IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Usability Standard - The difference between IEC 60601-1-6 to IEC 62336 Human Factors and Ergonomics in Engineering 1
S What is the difference between Verification and Validation of Test Reports? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
