Difference between Document Review and Document Verification
P
paciffic
I am handling a lot of document regarding QC & QA.Now I want to know to know the difference between the document review and document verification. Is both are same. If not then what is the difference.
RoxaneB
Change Agent and Data Storyteller
Welcome to the Cove, paciffic. :bigwave:
What has prompted this question? At first glance, I am tempted to say that they are the same, but if people within your organization are using both terms, you should ask them what the steps are with "document review" and "document verification". There may be a difference between the two terms within your company.
Coury Ferguson
Moderator here to help
If you look at the wording: Document "review" would mean the initial review of the requirements, and document "verification" would be the act of verifying that the documents (completed) are accurate. I believe and in my opinion.
Coury Ferguson
RoxaneB
Very good point Coury. In my site, however, the two are the same...but I can see what you mean.
O
Old Quality Gal
Difference between Doc Review and Doc Verification
I actually do see a subtle but important difference. When a document is created or changed I would consider that verification. Is it right for its intended use, "The right tool for the right job". I ask everyone that creates a controlled document in our organization or at one of our clients "What is this document supposed to do? Is it worth the cost of maintaining that document and peoples proficiency using that document? and don't kid yourself every document you maintain has a cost and that cost can skyrocket if you don't maintain the document or verify it is really needed.
After initial release I consider review to be a periodic review by a responsible party to see if the tool ( the document) is still needed and doing the job it was created to do.
If it isn't being used lose it or find out why it isn't being used. That means don't just read it, compare it to the process and ask the people impacted by the document if it still makes sense and is useful. If the answer is no then change it or obsolete it.
I think these are two different tasks performed for different reason's at different times and both can add value.
I personally think most companies way over document everything. That just puts them in a box in some situations where they feel artificially constrained from changing and improving or they worse case stare at some forgotten never used document when the auditor waves it under their nose. Ewww!
It is like packing for vacation take out half the clothes and double the money you were going to take and it should be about right!
S What is the difference between record and document? Document Control Systems, Procedures, Forms and Templates 14
T Is there a difference between form control and document control ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
D The difference between a Document and a Record? IATF 16949 - Automotive Quality Systems Standard 6
D The Difference between a Document and a Record - Training Plan Document Control Systems, Procedures, Forms and Templates 11
X The Difference between a Document and a Record Document Control Systems, Procedures, Forms and Templates 5
J What is the difference between a controlled document and an uncontrolled document? Document Control Systems, Procedures, Forms and Templates 10
G What's the difference between 1.32 and 1.33 Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 18
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Terminal Lugs sizes - Difference between 225/24 vs. 275/24 lugs Manufacturing and Related Processes 2
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 3
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
gramps What is the difference between discrete and continuous variables? Problem Solving, Root Cause Fault and Failure Analysis 3
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 4
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
P What is the exact difference between Risk and Opportunity in context of ISO 27001? IEC 27001 - Information Security Management Systems (ISMS) 7
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
O Air Flow - Which is the operational difference between LAF (vertical and horizontal) and RLAF? Manufacturing and Related Processes 2
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
S DO 178B - What is the difference between review and verification? Federal Aviation Administration (FAA) Standards and Requirements 1
T The difference between SOP and Kaizen Standardization Lean in Manufacturing and Service Industries 2
K Difference between intended purpose and intended use of the device EU Medical Device Regulations 9
S Difference between an Advisory Notice (ISO 13485) and a Field Safety Notice? ISO 13485:2016 - Medical Device Quality Management Systems 3
T Difference between "data analysis" and "management review" ISO 13485:2016 - Medical Device Quality Management Systems 4
qualprod What is the difference between 7.4.1 (2008) and 8.4.1 (2015)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
S The difference between a Medical Device Accessory and Component Canada Medical Device Regulations 2
S What is the difference between a service request and a complaint? ISO 13485:2016 - Medical Device Quality Management Systems 2
I What is the difference between OOS/OOT Imported Legacy Blogs 3
A Definition Difference between Quality System Procedure and Standard Operating Procedure (SOP) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
Q Difference between Monitor & Measurement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T QA vs. RA - The difference between QA and RA Coffee Break and Water Cooler Discussions 6
A Difference between Discrimination and Least Count IATF 16949 - Automotive Quality Systems Standard 2
K Difference between Medical Electrical Equipment and Medical Equipment System IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
