Difference between Gage R&R and Round Robin testing?
Hershal
Metrologist-Auditor
#11
As I am given to understand, a GR&R is internal, whether you have 1 or 100 people and 1 or 100 machines.....
However, Round Robin, aka inter-laboratory comparison (ILC) or proficiency test (PT), is between different organizations.....it needs to be noted that PT/ILC may often have a level of rigor not normally considered to be associated with Round Robins, to include a report detailing Z-Score (test) or En Score (calibration).....
U
Umang Vidyarthi
#12
Miner has given the correct distinction between the two.
Let me elaborate further. The term "Round Robin" is usually associated with sports, and in the school/college days we use to play "Round Robin" tourneys, in which all the teams/participants are pitted against each other i.e. every one plays against every one else; in order to bring forth the best. This is different from the knock-out system, which does not 'always' bring out the best.
Similarly, "Round Robin Test/Analysis" is performed severally, involving multiple appraisers, equipments and methods, pitting them against each other using all the permutations & combinations, to bring out the best of the results.BTW the "Round Robin" is of french origin 'ruban rond' meaning- round ribbon.
Umang :D
IMO it is not correct to associate 'Round Robin test', as between different organisations alone. As I have elaborated in my post ibid, appraisers-methods-equipments are vollyed against each other (irrespective of being internal/external) to bring out 'reproducibility.
The major difference between the two is, that the "The Round Robin test", be it 'internal' or 'external', brings out 'reproducibility' alone; whereas 'Gauge R&R' brings out both - repeatability as well as reproducibility. Since 'Repeatability is the variation in measurement taken by a single person or instrument on the same item under the same condition', it is rendered out of Round Robin's scope.
In other words, you may say that, one part of the Gauge R&R conducts Round Robin test. Hope this brings more clarity.
Umang :D
Hershal
Metrologist-Auditor
#13
Which then makes it different still than PT/ILC/ which also requires all the Type B influences, besides the repeatability and reproducibility.....
mboucher
#14
Do anyone know who sells round robin services? I've heard of of several companies that have certified artifacts and do the correlation but cannot find any on the web.
Mark
K
Kevin H
#15
Mark, a lot depends on what product/tests you want to participate. For Metal Powder tsts, MPIF sponsors an interlaboratory program. When I managed a mechanical testing lab for flat rolled stainless steel we found a service for tensile testing, Rockwell hardness, etc. through A2LA, our accreditation service for ISO Guide 25. The one we used offered other tests and services as well as the ones we used, and no unfortunately I do not remember their name - that was 8 years ago.
In searching for one, I'd contact industry or trade organizations, and organizations accrediting labs to ISO 17025.
V
Voyteck79
#16
Hi all
Round Robin came back like round robin :) I want to do intralaboratory (insiade), not inter :)
So, if i do Gage RR in Minitab 3 operators 5 measueremnts and 3 trials. What will be the result?
Process tolerance = 1
Study Var %Study Var %Tolerance
Source StdDev (SD) (6 * SD) (%SV) (SV/Toler)
Total Gage R&R 0,0921058 0,552635 100,00 55,26
Repeatability 0,0781778 0,469067 84,88 46,91
Reproducibility 0,0487003 0,292202 52,87 29,22
operator 0,0487003 0,292202 52,87 29,22
Part-To-Part 0,0000000 0,000000 0,00 0,00
Total Variation 0,0921058 0,552635 100,00 55,26
I think that will be: Productability operator SV/Toler. is it OK?
Maybe someone have example form?
I'll be greatfull.
Regards!
#17
Please clarify your question. We are not certain what you are asking.
If you are looking for an MSA form, see the file attached to this blog entry.
Hershal
Metrologist-Auditor
#18
A couple of organizations that provide PT including
MeasurePT and NAPT, among others.
ABs under APLAC and ILAC protocols can - EITHER - offer PT themselves or through APLAC/ILAC - OR - accredit PT providers, but are not allowed to do both.
A2LA accredits PT providers. You can check at www.a2la.org
Other ABs tend to offer PT directly or through APLAC/ILAC.
Hope this helps.
V
Voyteck79
#19
I whant to do RR for hardness testing. 5 operators, 1 machine, 2 trial. I have 36HRC test block.
My question is can i do GRR? what results for this will be % of RR.
Second question is from were is 95% of 36HRC ?
thanks.
L What is the the difference between the Gage R&R Nested Anova and ISO/REMCO N263? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Definition GAGE vs. GAUGE - Difference between Gage and Gauge Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
P The difference between Gage Discrimination and Least Count Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Definition Gage and Gauge - Difference between the terms Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 45
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Terminal Lugs sizes - Difference between 225/24 vs. 275/24 lugs Manufacturing and Related Processes 2
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 3
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
gramps What is the difference between discrete and continuous variables? Problem Solving, Root Cause Fault and Failure Analysis 3
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 4
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
P What is the exact difference between Risk and Opportunity in context of ISO 27001? IEC 27001 - Information Security Management Systems (ISMS) 7
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
O Air Flow - Which is the operational difference between LAF (vertical and horizontal) and RLAF? Manufacturing and Related Processes 2
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
S DO 178B - What is the difference between review and verification? Federal Aviation Administration (FAA) Standards and Requirements 1
T The difference between SOP and Kaizen Standardization Lean in Manufacturing and Service Industries 2
K Difference between intended purpose and intended use of the device EU Medical Device Regulations 9
S Difference between an Advisory Notice (ISO 13485) and a Field Safety Notice? ISO 13485:2016 - Medical Device Quality Management Systems 3
T Difference between "data analysis" and "management review" ISO 13485:2016 - Medical Device Quality Management Systems 4
qualprod What is the difference between 7.4.1 (2008) and 8.4.1 (2015)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
S The difference between a Medical Device Accessory and Component Canada Medical Device Regulations 2
S What is the difference between a service request and a complaint? ISO 13485:2016 - Medical Device Quality Management Systems 2
I What is the difference between OOS/OOT Imported Legacy Blogs 3
A Definition Difference between Quality System Procedure and Standard Operating Procedure (SOP) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
Q Difference between Monitor & Measurement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T QA vs. RA - The difference between QA and RA Coffee Break and Water Cooler Discussions 6
A Difference between Discrimination and Least Count IATF 16949 - Automotive Quality Systems Standard 2
K Difference between Medical Electrical Equipment and Medical Equipment System IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Usability Standard - The difference between IEC 60601-1-6 to IEC 62336 Human Factors and Ergonomics in Engineering 1
S What is the difference between Verification and Validation of Test Reports? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A Difference between ISO 9001:2015 Clauses 8.1 and 8.5.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
