I'm working on IVDR. gone through Annex-XIII, in which it is mentioned that "specification of the intended purpose of the device; and specification of the intended use of the device" to be mentioned in performance evaluation.
Whether intended purpose and intended use is different?? Previously i worked assuming both are same.
kindly help me to find out the difference between both the terms.
Thank you
The source for the confusion is the European Commission itself.
There is no definition of 'intended use' in MDD 93/42, including the 2007/47 amendments.
“Intended purpose” is defined in Article 1 paragraph 2(g), as follows
“(g) ‘
intended purpose’ means the use for which the device is intended according to the data supplied by the manufacturer on the labelling, in the instructions and/or in promotional materials;”.
This is also true for AIMDD Art. 1.2.f
Now have a look at this:
MEDDEV 2. 1/ 2.1 of February 1998 states the following in the Background section:
"Definition of "intended use" (EC Directive 93/42/EEC): "The intended use means the use for which the device is intended according to the data supplied by the manufacturer on the labelling, in the instructions and/or promotional materials".
How about that?
Regulation
2017/745 defines “
intended purpose” (Article 2 paragraph 12):
(12) ‘intended purpose’ means the use for which a device is intended according to the data supplied by the manufacturer on the label, in the instructions for use or in promotional or sales materials or statements and as specified by the manufacturer in the clinical evaluation;”
Appendix 3 of the 2.7/1 rev.4 guidance provides the list of the subsections/paragraphs/sections that should be defined under "intended purpose", and I really have a hard time to see the difference between that and the translation of what the German RA are currently considering the definition of "intended use".
We can continue with the fact that
GHTF/SC/N4:2012 (Edition 2) defines the following:
Intended Purpose: The use for which the device is intended according to the data supplied by the manufacturer on the labelling, in the instructions and/or in promotional materials.
GHTF/SG2/N54R8:2006
Intended Use / Purpose: The objective intent of the manufacturer regarding the use of a product, process or service as reflected in the specifications, instructions and information provided by the manufacturer.
GHTF/SG1/N045:2008 / GHTF/SG1/N68:2012 / GHTF/SG1/N70:2011 / GHTF/SG1/N77:2012
GHTF/SG5/N6:2012
But the ugly truth is that the
intended use thingy probably is an implant from the US FDA 21 CFR 801.4, amended back in 2017, which actually uses this term.
Sec. 801.4 Meaning of intended uses.
The words intended uses or words of similar import in 801.5, 801.119, and 801.122 refer to the objective intent of the persons legally responsible for the labeling of devices. The intent is determined by such persons' expressions or may be shown by the circumstances surrounding the distribution of the article. This objective intent may, for example, be shown by labeling claims, advertising matter, or oral or written statements by such persons or their representatives. It may be shown by the circumstances that the article is, with the knowledge of such persons or their representatives, offered and used for a purpose for which it is neither labeled nor advertised. The intended uses of an article may change after it has been introduced into interstate commerce by its manufacturer. If, for example, a packer, distributor, or seller intends an article for different uses than those intended by the person from whom he received the devices, such packer, distributor, or seller is required to supply adequate labeling in accordance with the new intended uses. But if a manufacturer knows, or has knowledge of facts that would give him notice that a device introduced into interstate commerce by him is to be used for conditions, purposes, or uses other than the ones for which he offers it, he is required to provide adequate labeling for such a device which accords with such other uses to which the article is to be put.
So, good luck with thinking it over
