Difference between Monitor & Measurement
Q
qcstar
Hello Members
Just a basic question. What is the difference between Monitor and Measure ? We regularly use terms like monitoring & measurement of processe, monitoring frequency, measuring frequency etc..
What is the best example to understand the basic difference between these terms?
The basic difference is the time element of the action.
A measurement is a single act that quantifies an attribute of a part, equipment, service or process (Length, color, speed, temperature, etc.)
Monitoring is to ‘watch’ or ‘observe’ those measurements over time to detect trends. Are things getting better or worse or cycling, etc. Behaviors and actions can also be monitored without a ‘measurement’.
Does this help?
During driving, you measure speed and monitor your fuel. Speed is a factor you need to know how you are doing measured against a standard (speed limit) and with fuel, you monitor the gauge to give you an idea of when you might need to fill up for the next trip.
Q
qcstar
Thanks. ISO 9001 require an organization to monitor,measure. For a process like purchase, How can we apply those terms to the process ?
The most common method is the use of key performance indicators (KPI). In the ISO world it seems that they are often called key process indicators. What you call them doesn't matter but the term came from the business world where they are called key performance indicators.
For purchasing a common KPI is supplier performance which is measure as supplier on-time delivery and/or supplier rejects. So if you have determined that supplier on-time delivery is the bigger concern of the two, you determine how the suppliers are performing, set a goal, measure how they are doing on a month to month (or whatever time period makes the most sense) then monitor the monthly score and the month to month trend.
Most ERP systems can help you capture that metric. If not, it can be handled with a receiving log.
H API monogram 4F, The difference between PSL-1 & PSL-2 Oil and Gas Industry Standards and Regulations 5
G What's the difference between 1.32 and 1.33 Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 18
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Terminal Lugs sizes - Difference between 225/24 vs. 275/24 lugs Manufacturing and Related Processes 2
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 3
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
gramps What is the difference between discrete and continuous variables? Problem Solving, Root Cause Fault and Failure Analysis 3
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 4
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
P What is the exact difference between Risk and Opportunity in context of ISO 27001? IEC 27001 - Information Security Management Systems (ISMS) 7
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
O Air Flow - Which is the operational difference between LAF (vertical and horizontal) and RLAF? Manufacturing and Related Processes 2
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
S DO 178B - What is the difference between review and verification? Federal Aviation Administration (FAA) Standards and Requirements 1
T The difference between SOP and Kaizen Standardization Lean in Manufacturing and Service Industries 2
K Difference between intended purpose and intended use of the device EU Medical Device Regulations 9
S Difference between an Advisory Notice (ISO 13485) and a Field Safety Notice? ISO 13485:2016 - Medical Device Quality Management Systems 3
T Difference between "data analysis" and "management review" ISO 13485:2016 - Medical Device Quality Management Systems 4
qualprod What is the difference between 7.4.1 (2008) and 8.4.1 (2015)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
S The difference between a Medical Device Accessory and Component Canada Medical Device Regulations 2
S What is the difference between a service request and a complaint? ISO 13485:2016 - Medical Device Quality Management Systems 2
I What is the difference between OOS/OOT Imported Legacy Blogs 3
A Definition Difference between Quality System Procedure and Standard Operating Procedure (SOP) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
T QA vs. RA - The difference between QA and RA Coffee Break and Water Cooler Discussions 6
A Difference between Discrimination and Least Count IATF 16949 - Automotive Quality Systems Standard 2
K Difference between Medical Electrical Equipment and Medical Equipment System IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Usability Standard - The difference between IEC 60601-1-6 to IEC 62336 Human Factors and Ergonomics in Engineering 1
S What is the difference between Verification and Validation of Test Reports? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
armani Difference between ISO 9001:2015 Clauses 8.1 and 8.5.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M IATF 16949 Cl. 8.4.2.2 vs 8.6.5 - Is there any difference between these clauses? IATF 16949 - Automotive Quality Systems Standard 7
C What is the difference between "Overall Risk" and "Risk"? (ISO 14971) ISO 14971 - Medical Device Risk Management 10
C The difference between a Critical Dimension vs. Critical Characteristic Misc. Quality Assurance and Business Systems Related Topics 2
