Difference between "Pass/Fail Testing" "Test To Failure" "Degradation Test"
Carmine
What is the difference between "pass/fail testing" "test to failure" "degradation test" in the detection ranking of Design FMEA?
Z
Zbigniew Huber
1. "pass/fail testing"
It is a functional test of a prototype, where functionality is verified without any extensive testing. If the prototype passed test then it is PASS if failed then FAIL.
This test is very weak with detection of defects related to "worn out" issues, material overstress issues, degradation etc.
2. "test to failure"
The prototype is subjected to testing several times and the test is stopped when the prototype fails. Then the failure is investigated for root cause and if necessary the design is improved to eliminate the cause. Example tests are: ALT (accelerated life test), HALT (highly accelerated life test). ALT may detect worn-out mechanisms. HALT may detect design issues where "margins" are too small, weak components etc.
3. "degradation test"
The prototype is subjected to tests for some time (or cycles) and specified key characteristics are measured, then the test continues and again after some time (or test cycles) same characteristics are measured again and so on. It allows to see how the key characteristics change over time/cycles - this is the "degradation". This detection method is ranked better than previous two, because it detects characteristics changes prior prototype functional failure.
I How to understand the difference between 7.2.1,7.2.2 and 7.3.3 from 13485 ISO 13485:2016 - Medical Device Quality Management Systems 3
A The difference between ANOVA and Xbar-R studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
X Difference between the Figure J.6 and J.7 insulation examples IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
W Difference between Appliances and Parts according EASA EASA and JAA Aviation Standards and Requirements 0
A Difference between general PMCF and PMS EU Medical Device Regulations 3
FoGia Difference between "misuse" and "off-label use" EU Medical Device Regulations 12
placebo_master What is the difference between "Fitness for Purpose" and "Calibration/Verification"? General Measurement Device and Calibration Topics 6
C Need to understand difference between an actual Calibration vs. a Calibration check General Measurement Device and Calibration Topics 3
H API monogram 4F, The difference between PSL-1 & PSL-2 Oil and Gas Industry Standards and Regulations 5
G What's the difference between 1.32 and 1.33 Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 18
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Terminal Lugs sizes - Difference between 225/24 vs. 275/24 lugs Manufacturing and Related Processes 2
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
D Difference between Test Method Validation and Gage R&R Qualification and Validation (including 21 CFR Part 11) 20
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 3
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
gramps What is the difference between discrete and continuous variables? Problem Solving, Root Cause Fault and Failure Analysis 3
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 4
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
P What is the exact difference between Risk and Opportunity in context of ISO 27001? IEC 27001 - Information Security Management Systems (ISMS) 7
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
O Air Flow - Which is the operational difference between LAF (vertical and horizontal) and RLAF? Manufacturing and Related Processes 2
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
S DO 178B - What is the difference between review and verification? Federal Aviation Administration (FAA) Standards and Requirements 1
TarKEpa The difference between SOP and Kaizen Standardization Lean in Manufacturing and Service Industries 2
K Difference between intended purpose and intended use of the device EU Medical Device Regulations 9
S Difference between an Advisory Notice (ISO 13485) and a Field Safety Notice? ISO 13485:2016 - Medical Device Quality Management Systems 3
T Difference between "data analysis" and "management review" ISO 13485:2016 - Medical Device Quality Management Systems 4
qualprod What is the difference between 7.4.1 (2008) and 8.4.1 (2015)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
S The difference between a Medical Device Accessory and Component Canada Medical Device Regulations 2
S What is the difference between a service request and a complaint? ISO 13485:2016 - Medical Device Quality Management Systems 2
I What is the difference between OOS/OOT Imported Legacy Blogs 3
A Definition Difference between Quality System Procedure and Standard Operating Procedure (SOP) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
Q Difference between Monitor & Measurement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
