Difference between Process Verification vs. Process Validation in APQP?
Y
Yew Jin
Re: Process Verification & Process Validation
From ASQ Quality Glossary
Validation: The act of confirming a product or service meets the requirements for which it was intended.
Verification: The act of determining whether products and services conform to specific requirements.
mustafa siddiqui
Verification is normally to see if the process in place is absolutely followed or not, more specific to Process Audit. It makes sure that the multiple operations that need need to be performed are in correct sequence.
Example: If your final product has the following processes that need to be accomplished,
Work station 100:sand blasting,
Work station 106: Nitriding,
work station 101: Machining,
Work station 102: broaching,
Work station 103: assembly,
Work station 104: washing,
Work Station 105: final test.
Now in the verification you make sure the process at each place are followed correctly in the same sequence.
Process validation is more of developmental stage where you are more open to making changes/ validate your process. You are making sure that the process you intend to apply is delivering the desired product as per the design/ functional specification. It is an attempt to assure that the sequence of operations that are performed on the product are correct or not.
In the above example, if doing the process validation , it fails as the operation of machining is immediately after the sand blasting and nitrading operation. If machining is done at this point then the operations prior to this are rendered useless. The suggestions from this validation would be that the machining operation would supercede all other operations.
Hope you would understand this more clearly.
Mustafa Siddiqui
Duke Okes
What is the difference between Process Verification & Process Validation in APQP? Thanks for the help:confused:
The difference between verification & validation is about the same regardless of application.
Verification is more intangible (e.g., a 2nd party looks at what someone has done and says, yes, it looks correct; a computer simulation is done to see how the system performs, etc.).
Validation is as close as one can get to testing the item (product, process) in the real world. Actually run/use it and see if it performs as it was designed to perform.
S What is the difference between Process Capability and Machine Capabilty Capability, Accuracy and Stability - Processes, Machines, etc. 13
T What is the difference between Supplier and Outsourced Process? Supplier Quality Assurance and other Supplier Issues 8
T Difference between the terms Function & Process when used in Construction Management Business Continuity & Resiliency Planning (BCRP) 12
B What is the difference between Process and Compliance Audit? Internal Auditing 21
J Difference between Outsourced Process and Support Service? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V What is the difference between a System and a Process? US Food and Drug Administration (FDA) 30
H What is the difference between Process Variation and Product Tolerance for GR&R? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A What is the difference between Process Objectives & Criteria for Effectiveness? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
R What's the difference between Engineering (ECN) and Process (PCN) Change Notes? FMEA and Control Plans 4
M The Difference between Process Audits and Layered Audits General Auditing Discussions 5
N What is the difference between Process, Procedure and Work Instructions Document Control Systems, Procedures, Forms and Templates 2
H Clarify the Difference between Activity and Process - What is Data Analysis IATF 16949 - Automotive Quality Systems Standard 9
S Difference between SPC (process control) and SQC (quality control) Statistical Analysis Tools, Techniques and SPC 12
S What is the difference between the quality process and quality procedure? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
D TS 16949 - Is there a difference between a process and an activity? IATF 16949 - Automotive Quality Systems Standard 5
M What is the difference between process documents vs. Work Instructions? Document Control Systems, Procedures, Forms and Templates 2
R What's the difference between using PPM or Defect Rate in a process? Quality Tools, Improvement and Analysis 1
X Difference between the Figure J.6 and J.7 insulation examples IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
W Difference between Appliances and Parts according EASA EASA and JAA Aviation Standards and Requirements 0
A Difference between general PMCF and PMS EU Medical Device Regulations 3
F Difference between "misuse" and "off-label use" EU Medical Device Regulations 12
placebo_master What is the difference between "Fitness for Purpose" and "Calibration/Verification"? General Measurement Device and Calibration Topics 6
C Need to understand difference between an actual Calibration vs. a Calibration check General Measurement Device and Calibration Topics 3
H API monogram 4F, The difference between PSL-1 & PSL-2 Oil and Gas Industry Standards and Regulations 5
G What's the difference between 1.32 and 1.33 Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 18
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Terminal Lugs sizes - Difference between 225/24 vs. 275/24 lugs Manufacturing and Related Processes 2
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
D Difference between Test Method Validation and Gage R&R Qualification and Validation (including 21 CFR Part 11) 20
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 3
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
gramps What is the difference between discrete and continuous variables? Problem Solving, Root Cause Fault and Failure Analysis 3
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 4
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
P What is the exact difference between Risk and Opportunity in context of ISO 27001? IEC 27001 - Information Security Management Systems (ISMS) 7
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
O Air Flow - Which is the operational difference between LAF (vertical and horizontal) and RLAF? Manufacturing and Related Processes 2
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
