Difference between Repaired and Reworked
I
Internet-101
Would you tell me what is the difference between Repaired and Reworked in QS-9000 Language?
:bigwave: :bigwave:
Smile is good for your health!
Rework - Fixing a nonconformance such that it meets drawing requirements.
ex. Hole is undersize - - re-drill to correct size.
Repair (requires customer approval) - Fixing a nonconformance such that the repair is acceptable to the customer.
ex. Hole is oversize - fill with weld metal and re-drill to correct size.
SteelMaiden
For what it is worth....I haven't been in a QS company for a couple of years now....
I think that it would depend a lot on what you are producing. We were a commodity supplier, there was no repair, but if we could rework something it typically was to another similar product. i.e. we could grind it to a smaller size, it was no longer fit for the order that it was originated for, but the customer also ordered a smaller size, ground product.
But, I digress. I had always thought of it as if you had to repaint something because it was not up to par, it was reworked. If you had to weld it because it broke, it was repaired. If you had to grind off the finish on portions, and then repaint, it was repaired.
Like I said, I think it all depends on what industry you are in, if you are supplying a commodity (or raw material), and what it is you are doing to make the product fit for use.
How is that for a fence straddling answer? I have to be careful, cuz I might fall and come down on one side of the fence or the other!:vfunny:
Al Dyer
From an article in Quality Digest
* Repairing: This includes actions that make the product functional although it doesn't conform perfectly to the original requirements. Such a product may not carry the same warranty as first-quality products, for instance.
* Reworking: Actions that make the product conform to the original requirements. In the customers' eyes, this product is exactly the same as a first-quality conforming product.
I agree with the comments so far, the Glossary in QS9000 gives the definitions:
Repair (page 131) "Action taken on nonconforming product so that the product will fulfill the intended usage although the product may not conform to the original requirements." This would generally require a concession from the customer before shipping.
Rework (page 132) "Action taken on nonconforming product so that it will meet the specified requirements."
When writing procedures or work instructions careful consideration should be given before using the word repair. If an area is set aside for rework it should be called rework and not he repair area.
A The difference between ANOVA and Xbar-R studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
X Difference between the Figure J.6 and J.7 insulation examples IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
W Difference between Appliances and Parts according EASA EASA and JAA Aviation Standards and Requirements 0
A Difference between general PMCF and PMS EU Medical Device Regulations 3
F Difference between "misuse" and "off-label use" EU Medical Device Regulations 12
placebo_master What is the difference between "Fitness for Purpose" and "Calibration/Verification"? General Measurement Device and Calibration Topics 6
C Need to understand difference between an actual Calibration vs. a Calibration check General Measurement Device and Calibration Topics 3
H API monogram 4F, The difference between PSL-1 & PSL-2 Oil and Gas Industry Standards and Regulations 5
G What's the difference between 1.32 and 1.33 Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 18
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Terminal Lugs sizes - Difference between 225/24 vs. 275/24 lugs Manufacturing and Related Processes 2
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
D Difference between Test Method Validation and Gage R&R Qualification and Validation (including 21 CFR Part 11) 20
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 3
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
gramps What is the difference between discrete and continuous variables? Problem Solving, Root Cause Fault and Failure Analysis 3
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 4
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
P What is the exact difference between Risk and Opportunity in context of ISO 27001? IEC 27001 - Information Security Management Systems (ISMS) 7
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
O Air Flow - Which is the operational difference between LAF (vertical and horizontal) and RLAF? Manufacturing and Related Processes 2
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
S DO 178B - What is the difference between review and verification? Federal Aviation Administration (FAA) Standards and Requirements 1
T The difference between SOP and Kaizen Standardization Lean in Manufacturing and Service Industries 2
K Difference between intended purpose and intended use of the device EU Medical Device Regulations 9
S Difference between an Advisory Notice (ISO 13485) and a Field Safety Notice? ISO 13485:2016 - Medical Device Quality Management Systems 3
T Difference between "data analysis" and "management review" ISO 13485:2016 - Medical Device Quality Management Systems 4
qualprod What is the difference between 7.4.1 (2008) and 8.4.1 (2015)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
S The difference between a Medical Device Accessory and Component Canada Medical Device Regulations 2
S What is the difference between a service request and a complaint? ISO 13485:2016 - Medical Device Quality Management Systems 2
I What is the difference between OOS/OOT Imported Legacy Blogs 3
A Definition Difference between Quality System Procedure and Standard Operating Procedure (SOP) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
Q Difference between Monitor & Measurement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T QA vs. RA - The difference between QA and RA Coffee Break and Water Cooler Discussions 6
