Difference between the terms Function & Process when used in Construction Management
theonlynelly
What's the difference beetwen Function and Process, in this regard relating to Construction Management area? Thank you in advance :)
qusys
Re: Function vs Process
Functional is only related to the area like a sort of sylos, while process approach is cross functional. For example, consider the part of supplier mgmt , cost and so on, not directly managed by function but where the"function" is account for, but done by other contributors to the process.
harry
Re: Difference between the terms Function & Process when used in Construction Managem
Welcome to the Cove.
1. I don't think these terms have any special meaning in Construction Management. Rather, they are general management terms whose meaning can be different if used in different situations.
2. If used to describe the structure of organizations, people perform specialized functions such as accounting, sales or machining within units termed departments.
3. As an example, the tendering or bidding process is a trans-departmental activity which involves people from various departments or function such as purchasing, costing and estimation, engineering and perhaps logistics (all dependent on the complexity and size of project).
I hope it is clear enough.
theonlynelly
Thank you for the response. I see.. Bt the way, what is sylos, anyway? :)
theonlynelly
I got it, thank you for the clear explanation :)
qusys
Thank you for the response. I see.. By the way, what is silos, anyway? :)
Sometimes in the literature there is written that the organization works with "silos" and not for "process" . This is a big issue for quality , not being followed process approach.
Silos is a long construction where it is contained the grain. It is a synonymous to say that each function works for itself, not included in a process.
theonlynelly
Thanks a lot for the explanation. It helps me a lot :)
jameswhite
Yeah i'm also agree with harry.
Function : Performance by the organization such as accounting, sales and other departments.
Process : Time consume for a specific task to complete.
john.b
It really has nothing to do with construction management but ITIL defines these for IT service management. They (ITIL) claim their set of best practices guidelines apply to service management in general, not just to IT, and maybe they could be useful in some other cases.
Function: A team or group of people and the tools or other resources they use to carry out one or more processes or activities ? for example, the service desk. The term also has two other meanings:
- An intended purpose of a configuration item, person, team, process or IT service. For example, one function of an email service may be to store and forward outgoing mails, while the function of a business process may be to dispatch goods to customers.
- To perform the intended purpose correctly, as in ?The computer is functioning.?
Process: A structured set of activities designed to accomplish a specific objective. A process takes one or more defined inputs and turns them into defined outputs. It may include any of the roles, responsibilities, tools and management controls required to reliably deliver the outputs. A process may define policies, standards, guidelines, activities and work instructions if they are needed.
The glossary is free, a reference they give out to induce interest in their courses and materials, found here:
http://www.itil-officialsite.com/InternationalActivities/ITILGlossaries_2.aspx
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
A Difference Between Complaints and Feedbacks in terms of Follow-Up Actions Needed Customer Complaints 3
B Definition Gage and Gauge - Difference between the terms Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 45
G What's the difference between 1.32 and 1.33 Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 18
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Terminal Lugs sizes - Difference between 225/24 vs. 275/24 lugs Manufacturing and Related Processes 2
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 3
gramps What is the difference between discrete and continuous variables? Problem Solving, Root Cause Fault and Failure Analysis 3
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 4
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
P What is the exact difference between Risk and Opportunity in context of ISO 27001? IEC 27001 - Information Security Management Systems (ISMS) 7
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
O Air Flow - Which is the operational difference between LAF (vertical and horizontal) and RLAF? Manufacturing and Related Processes 2
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
S DO 178B - What is the difference between review and verification? Federal Aviation Administration (FAA) Standards and Requirements 1
T The difference between SOP and Kaizen Standardization Lean in Manufacturing and Service Industries 2
K Difference between intended purpose and intended use of the device EU Medical Device Regulations 9
S Difference between an Advisory Notice (ISO 13485) and a Field Safety Notice? ISO 13485:2016 - Medical Device Quality Management Systems 3
T Difference between "data analysis" and "management review" ISO 13485:2016 - Medical Device Quality Management Systems 4
qualprod What is the difference between 7.4.1 (2008) and 8.4.1 (2015)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
S The difference between a Medical Device Accessory and Component Canada Medical Device Regulations 2
S What is the difference between a service request and a complaint? ISO 13485:2016 - Medical Device Quality Management Systems 2
I What is the difference between OOS/OOT Imported Legacy Blogs 3
A Definition Difference between Quality System Procedure and Standard Operating Procedure (SOP) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
Q Difference between Monitor & Measurement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T QA vs. RA - The difference between QA and RA Coffee Break and Water Cooler Discussions 6
A Difference between Discrimination and Least Count IATF 16949 - Automotive Quality Systems Standard 2
K Difference between Medical Electrical Equipment and Medical Equipment System IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Usability Standard - The difference between IEC 60601-1-6 to IEC 62336 Human Factors and Ergonomics in Engineering 1
S What is the difference between Verification and Validation of Test Reports? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A Difference between ISO 9001:2015 Clauses 8.1 and 8.5.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M IATF 16949 Cl. 8.4.2.2 vs 8.6.5 - Is there any difference between these clauses? IATF 16949 - Automotive Quality Systems Standard 7
