Difference in Line Graph and Scatter Plot
v9991
i tried to fit a data in both line graph and scatter plot.
then generated a trend line., but both of them are giving different values for slope, r-sq, etc.,
why do i see such difference?
t.PoN
the line graph is usually used for non-numeric x-values.
the scatter graph is used for numeric x values (it uses linear regression). the difference is in calculating the error.
To explain it:
the line graph will try to fit each point on the line.
but the scatter will try to find a correlation between the whole set of data (you may find a point outside the line but the correlation will fit better for the whole set of points.
i suggest you stick with scatter formula
v9991
sorry, I missed to mention that, we were trying to assess the linearity. and assess the R-sq. as an acceptance criteria.
Linearity of what? What are you measuring? what is th input (x axis value) and the output (Y axis value)
also you have very few data points so the R squared value may be artificially way to high...
I assume the line chart uses the 'trend line' option? in any case I would never that use option for anything...
I woule go with the scatter plot / standard linear regression approach at least to start. but you really need more data
You need to choose the correct graph
If you want to show data trends, with only one set of numeric data, then choose the line graph. The line graph uses values on the vertical axis against categories on the horizontal
If you want to show a comparison of values, then choose the scatter graph. This graph shows values on both axes
v9991
i understand/understood the application for specific purposes, BUT, i had a academic/curious question, that why is there such a difference, for same set of data. what/how does excel give two different formula?
is it that, excel treats x-axis of line graph as some coded values 1-2-3-4-etc.,
and in scatter plot, it actually accounts for exact values of the graph variables.
You hit upon the correct answer. Substitute the integers 1 through 6 into the formula for the line graph, and the equation provides the corresponding y-values on the line graph.
T What is the difference between Solid-Line Manager and Dotted Line Manager Career and Occupation Discussions 5
Y Labeling difference for storage and operating conditions EU Medical Device Regulations 1
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 2
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
G What is the difference between discrete and continuous variables? Problem Solving, Root Cause Fault and Failure Analysis 5
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 2
Nicole Desouza The Difference of being AS 9100D Compliant vs.Certified AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 13
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 5
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 7
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
R The difference b/w FMEA & Risk analysis as per iso 14971 ISO 14971 - Medical Device Risk Management 8
P What is the exact difference between Risk and Opportunity in context of ISO 27001? IEC 27001 - Information Security Management Systems (ISMS) 7
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
O Air Flow - Which is the operational difference between LAF (vertical and horizontal) and RLAF? Manufacturing and Related Processes 2
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
S DO 178B - What is the difference between review and verification? Federal Aviation Administration (FAA) Standards and Requirements 1
T The difference between SOP and Kaizen Standardization Lean in Manufacturing and Service Industries 2
K Difference between intended purpose and intended use of the device EU Medical Device Regulations 9
S Difference between an Advisory Notice (ISO 13485) and a Field Safety Notice? ISO 13485:2016 - Medical Device Quality Management Systems 3
T Difference between "data analysis" and "management review" ISO 13485:2016 - Medical Device Quality Management Systems 4
Q What is the difference between 7.4.1 (2008) and 8.4.1 (2015)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Is there a difference in the process? Analyze residuals, construct interval estimate Using Minitab Software 2
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
S Certification Body, Registrar, Notified Body - What is the difference? Registrars and Notified Bodies 3
S The difference between a Medical Device Accessory and Component Canada Medical Device Regulations 2
S What is the difference between a service request and a complaint? ISO 13485:2016 - Medical Device Quality Management Systems 2
Q AS 9100 C and D Purchasing requirements difference AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
R Difference Process Objective/Opportunity for improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
I What is the difference between OOS/OOT Imported Legacy Blogs 3
A Definition Difference between Quality System Procedure and Standard Operating Procedure (SOP) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
O Difference in 60601-1-2 3rd and 4th ed separation RF portable equipment CE Marking (Conformité Européene) / CB Scheme 1
Q Difference between Monitor & Measurement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T QA vs. RA - The difference between QA and RA Coffee Break and Water Cooler Discussions 6
A Difference between Discrimination and Least Count IATF 16949 - Automotive Quality Systems Standard 2
K Difference between Medical Electrical Equipment and Medical Equipment System IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M Usability Standard - The difference between IEC 60601-1-6 to IEC 62336 Human Factors and Ergonomics in Engineering 1
S What is the difference between Verification and Validation of Test Reports? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
A Difference between ISO 9001:2015 Clauses 8.1 and 8.5.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M IATF 16949 Cl. 8.4.2.2 vs 8.6.5 - Is there any difference between these clauses? IATF 16949 - Automotive Quality Systems Standard 7
