Differences between international and regional standards (EN, AAMI, CSA...)
mr.mike
Given the many regional versions (EN, AAMI, CSA...) of international standards (IEC, ISO..) is there a means to find out what the differences are, rather than having to purchase copies of each?
As far as I gather, the differences are often few, or sometimes none at all...?
TPMB4
Very good question I think.
Anyone from a National standards body around the forum? Or from ISO?
FWIW my take on it is a lot of standards are the same. I'm from the UK and I've seen standards referred as ISO BS XXXXXX or ISO EN XXXXXX or ISO DIN XXXXXX. In those cases I've always thought they are all the same if the numbers that replace the XXXXXX are the same. It is just a case of the national bodies publishing it for ISO but could be wrong.
BTW being from the EU as well as UK (well they are still part of it despite the Euro election success of euro-sceptic parties) standards from one national standards agency have to match those in another I believe. We share standards as part of the uniformity of being a member of such a grouping of states. Not that all nations follow them all and on top of that some nations add extra requirements I think through their own national standards (IIRC Germany often have stricter standards than most euro states).
This is just my take on it and probably not 100%. I have no idea how to find out about equivalent standards and their differences though outside of EU's community wide EN standard system. Although ISO is about international standardization and with trade being global these days a lot of companies will work to one of the more commonly accepted national standards. Over here we often refer to US and German DIN standards for the likes of steel grades as an example.
mr.mike
It's too bad the regional groups (AAMI, EN...) don't just release addenda documents, rather then replicate the standards in their entirety with only minor (if any) changes.
That way it'd be perfectly clear what the differences are, and it wouldn't be such a burden to have to maintain and parse multiple copies of lengthy documents (to say nothing of having to purchase them!).
Hershal
Metrologist-Auditor
I work with this often. Generally Mr.Mike is correct, the differences are usually National differences, but generally are otherwise harmonized. Once in awhile, technical details may change due to considerations. For example, in Europe, standard voltage is 220-230 at 50Hz, in North America 115 at 60Hz, in Japan 100 at 50Hz, and so some details then may need to change.
So, if I get an ISO/IEC/UL/CSA/SASO 61010 standard, it is going to be almost perfectly identical. Still, for an accreditation certificate for a lab, customers or regulators may want to see their version listed.
Usually the biggest difference I see in the US version is spelling of certain words to the US spelling.
Hope this helps.
mr.mike
Although the differences are apparently most often minor, my concern is when they are not (i.e. there are specific regional deviations that need to be considered).
I'm curious what other companies do.
Do you:
a) Purchase just the international standard and assume regional deviations are minor?
b) Purchase a copy of each just in case there are differences worth considering?
c) Have some other means of determining differences without having to purchase copies of each and compare them all?
N R&R for Differences between 2 measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
DuncanGibbons Clear differences between ISO 13485 and AS 9100D requirements ISO 13485:2016 - Medical Device Quality Management Systems 10
K Differences between Manufacturing Process Audit & Layered Process Audit Lean in Manufacturing and Service Industries 4
S Differences in CB expectations between the US and Europe Registrars and Notified Bodies 3
M What are the differences between "Process Flowchart form" and "Process Flow Diagram form"? IATF 16949 - Automotive Quality Systems Standard 4
K Differences between EN ISO 11607-1:2009 vs. 2017 Other Medical Device Related Standards 1
M What are the differences between TIR 13004:2013 and TIR 33? Other Medical Device Related Standards 2
H Differences between CQI 15 and CQI 17 IATF 16949 - Automotive Quality Systems Standard 0
A ISO 13485:2003 vs ISO 13485:2016 - What are the differences between the two? ISO 13485:2016 - Medical Device Quality Management Systems 1
C Differences between IATF 16949 and AS9100 IATF 16949 - Automotive Quality Systems Standard 13
T PPAP differences between TS16949 and VDA APQP and PPAP 1
E Differences between IEC 60601-1-11:2015 and 2010 Other US Medical Device Regulations 0
J Differences between a Risk Management Plan vs. Production Part Approval Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Y Differences between the Classic 7 QC Tools and New QC Tools Quality Tools, Improvement and Analysis 3
C Differences between IATF 16949:2016 vs ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 13
L Differences in the requirements between IEC 60601-1 3rd ed. and EN 60601-1:2006 IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
Q What are the differences between ISO 13485 vs. AS9100C ISO 13485:2016 - Medical Device Quality Management Systems 3
L AQL ANSI z1.4 & z1.9 - What are the differences between these 2 standards? AQL - Acceptable Quality Level 5
V Differences between ISO 13485 & FDA Requirements ISO 13485:2016 - Medical Device Quality Management Systems 6
Q Differences between Clauses 7.5, 8.2.3 and 8.2.4 of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
V Statistics - Designs - Differences between Orthogonality and Confounding Using Minitab Software 5
K Differences between ISO 9001 and API Q1. Other ISO and International Standards and European Regulations 1
C Control of Records - Differences between Controlled Documents and Controlled Records Records and Data - Quality, Legal and Other Evidence 18
S What are the differences between Traditional 510(k) and a PMA to meet 21 CFR 814.20 ? Other US Medical Device Regulations 3
O Differences between EN 61326-1:2006 and EN 61326-1:2013 CE Marking (Conformité Européene) / CB Scheme 2
K The differences between ISO 9001 vs a QMS (Quality Management System) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Y Differences between Top Management, Management & Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
W Differences between VDA 6.3 and ISO 9001 VDA Standards - Germany's Automotive Standards 2
G Differences between Quality Objectives and Business KPI's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
P Differences between an NCR and CAR Internal Auditing 9
M Differences between High, Medium, Low Risk Suppliers Supplier Quality Assurance and other Supplier Issues 5
G Differences between Design, Development, and Production Misc. Quality Assurance and Business Systems Related Topics 4
C Differences between ISO 9001:2008 and AS9100 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Differences between Conductive vs. Dissipative ESD Flooring Manufacturing and Related Processes 3
D Quality Management Systems - Differences between ISO 13485, 21 CFR Part 820 & ICH Q10 Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
D Differences between (c)GMP for Drugs and Medical Devices Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
A EN 60601-2-51 - Differences between the 2003 and the 2005 edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C What are the differences between Medical and Non Medical Grade Adhesives 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
V Differences between Business Process Reengineering (BPR) and Total Quality Management Quality Manager and Management Related Issues 3
V Differences between Quality Tools and Quality Concepts? Quality Tools, Improvement and Analysis 4
G What are the differences between US and EU Pharmacopeias? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 11
N Differences between a Safety Nonconformance and a Quality Nonconformance Nonconformance and Corrective Action 14
F Differences between ISO 9001 and ISO 9004 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Defining the differences between Prototype vs. Production Guidelines? Contract Review Process 5
S Differences between the SAE AS9100C and BS EN AS 9100:2009 versions of the standard AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
V Similarities and Differences between EU & US GMPs (Good Manufacturng Processes) Document Control Systems, Procedures, Forms and Templates 8
J Definition Servicing circuit boards - Differences between Rework and Repair Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
M Differences between ISO 9004:2000, Baldrige National Quality Progr ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Differences Between TS16949 and 13485 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Q Differences Between TS16949 and ISO 13485 IATF 16949 - Automotive Quality Systems Standard 16
