Differences between Non-conforming Material vs. Nonconforming Product
METerry
My thanks in advance of what I know will be useful help from forum members. You patience and tolerance for ameteurish questions are greatly appreciated by this poster. Particularly useful is information from those who have 'been there and done that' - practical implementation.
I need some advice regarding treatment of non-conformances in incoming raw materials versus non-conformances in products. We have documented processes and work instructions for the creation of NCMRs for manufactured products including the disposition of the products. What we do not document is the process for handling non-conforming incoming raw materials. Can both not be addressed within with one Procedure and one Work Instruction?
What is the difference between a "Product" and a "Material"? My ISO guidance books generally define "Product" as the "result of a process". ISOs 8.3 does specifically say "Control of Product" and most discussions relate to disposition in terms of customer requirments as if raw materials are to be considered elsewhere. Are raw materials not also products (results of a process) whether we consider them to be results of a suppliers process or alternatively, results of our own Purchasing process? Why are they called NCMRs (non conforming materials reports) if they only consider Products? Why aren't they NCPRs (non-conforming Product reports)? Are we splitting hairs at this juncture (does it matter)?
Colin
Re: Non-conforming Material versus Product
Nonconforming product can be at any stage, be it at goods in (raw materials or parts), during production or finished product. What the standard requires is for us to control it as stated by clause 8.3. There does not need to be a distinction between parts and material.
1 procedure is fine, just make sure it covers all eventualities of nonconformance. Alternatively, you could describe in a procedure how to conduct a task (say goods in) and describe what to do when you get n/c material/product as part of that procedure.
I often don't have a separate procedure for n/c product, I include it in the procedure(s) that describes other activities such as goods in, production, packaging etc.
To take Colpart's good advice a step further, some companies use a single form and process to deal with all nonconforming conditions, even those that are not directly related to products/materials. It's possible to use the same form and process for documenting audit findings, for example.
METerry
Colpart,
Many thanks for your reply.
I'm still getting resistance and claims that raw materials are handled under 7.4.3. We do not investigate the nonconformity under 7.4.3.
METerry
Thanks for your input! I am being advised that 8.3 applies only to nonconforms in produced product and to nothing else.
Colin
7.4.3 does relate to the verification of purchased product so it does involve the receipt of raw materials (if that is what has been purchased). However, 7.4.3 does not tell us what to do if there is a problem so we need to go to 8.3. I can assure the doubters that 8.3 refers to all nonconforming product.
METerry
My understanding and interpretation is similar to yours. We even have a space on our bulk raw material inspection forms for "disposition" but we do not define who has the authority or responsibility to determine disposition. I suppose we will eventually come to understand our auditor's interpretation.
Thank you for your time and advice.
E
event
Does ISO 9001 require to document every nonconformity, however small it is?
I understadt that if You order a fan from your supplier and upon installing it you find out it has an imbalance, you should record this.
But if a small screw is bended and you just take a new one out of a 100 pieces box, should this be recorded too?
Is it ok to set some standards how the employees can differ between problems which should be documented and smaller problems which can be solved immediately?
Or are non conformities only problems you find at some kind of checkpoint/quality gate etc. ?
If thats the case, what about problems the employees run into while assembling parts?
ISO is looking primarily for how you control (prevent) the unintended use of nonconfomring product. This includes identifying it in some fashion.
Many companies have documented procedures that allow for immediate local control and disposition of 'low cost scrap' such as a bent screw that can be easily identified, replaced and dispositioned by throwing the thing in a trash can or specially marked bin for 'scrap' material. The thing is identified as nonconfomring by being in the bin. Sometimes these bins are 'locked' such that anyone can get things into it but not easily out of it (think of a lobster trap). Sometimes these bins are simply trash cans and the operators know - and you can demonstrate in some objective way - that they can't go 'dumpster diving' to reclaim parts. In these cases the 'tracking' of low cost scrap is typically done from an inventory consumption to yield comparison. The cost just doesn't justify an individual entry into some database or paper form...
now ISO does say that the records of the occurence of such events and theri disposition hsuold be maintained - but it doesn't specifically require you to record the events...I'm curious as to what some of our auditors have to say about this scenario...
That's the way I read it too.
C What are the differences between Medical and Non Medical Grade Adhesives 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
B For professionals from an amateur: What are the differences between some plans and procedures? EU Medical Device Regulations 5
U How to pick between ANSI Z1.4 vs. ISO2859-1 for AQL Inspection? What are the major differences? AQL - Acceptable Quality Level 4
N R&R for Differences between 2 measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
DuncanGibbons Clear differences between ISO 13485 and AS 9100D requirements ISO 13485:2016 - Medical Device Quality Management Systems 10
K Differences between Manufacturing Process Audit & Layered Process Audit Lean in Manufacturing and Service Industries 4
S Differences in CB expectations between the US and Europe Registrars and Notified Bodies 3
M What are the differences between "Process Flowchart form" and "Process Flow Diagram form"? IATF 16949 - Automotive Quality Systems Standard 5
K Differences between EN ISO 11607-1:2009 vs. 2017 Other Medical Device Related Standards 1
M What are the differences between TIR 13004:2013 and TIR 33? Other Medical Device Related Standards 2
H Differences between CQI 15 and CQI 17 IATF 16949 - Automotive Quality Systems Standard 0
A ISO 13485:2003 vs ISO 13485:2016 - What are the differences between the two? ISO 13485:2016 - Medical Device Quality Management Systems 1
C Differences between IATF 16949 and AS9100 IATF 16949 - Automotive Quality Systems Standard 13
T PPAP differences between TS16949 and VDA APQP and PPAP 1
E Differences between IEC 60601-1-11:2015 and 2010 Other US Medical Device Regulations 0
J Differences between a Risk Management Plan vs. Production Part Approval Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Y Differences between the Classic 7 QC Tools and New QC Tools Quality Tools, Improvement and Analysis 3
C Differences between IATF 16949:2016 vs ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 13
L Differences in the requirements between IEC 60601-1 3rd ed. and EN 60601-1:2006 IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
Q What are the differences between ISO 13485 vs. AS9100C ISO 13485:2016 - Medical Device Quality Management Systems 3
L AQL ANSI z1.4 & z1.9 - What are the differences between these 2 standards? AQL - Acceptable Quality Level 5
V Differences between ISO 13485 & FDA Requirements ISO 13485:2016 - Medical Device Quality Management Systems 6
Q Differences between Clauses 7.5, 8.2.3 and 8.2.4 of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
V Statistics - Designs - Differences between Orthogonality and Confounding Using Minitab Software 5
K Differences between ISO 9001 and API Q1. Other ISO and International Standards and European Regulations 1
M Differences between international and regional standards (EN, AAMI, CSA...) Other Medical Device Related Standards 6
C Control of Records - Differences between Controlled Documents and Controlled Records Records and Data - Quality, Legal and Other Evidence 18
S What are the differences between Traditional 510(k) and a PMA to meet 21 CFR 814.20 ? Other US Medical Device Regulations 3
O Differences between EN 61326-1:2006 and EN 61326-1:2013 CE Marking (Conformité Européene) / CB Scheme 2
K The differences between ISO 9001 vs a QMS (Quality Management System) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Y Differences between Top Management, Management & Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
W Differences between VDA 6.3 and ISO 9001 VDA Standards - Germany's Automotive Standards 2
G Differences between Quality Objectives and Business KPI's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
P Differences between an NCR and CAR Internal Auditing 35
M Differences between High, Medium, Low Risk Suppliers Supplier Quality Assurance and other Supplier Issues 5
G Differences between Design, Development, and Production Misc. Quality Assurance and Business Systems Related Topics 4
C Differences between ISO 9001:2008 and AS9100 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Differences between Conductive vs. Dissipative ESD Flooring Manufacturing and Related Processes 3
D Quality Management Systems - Differences between ISO 13485, 21 CFR Part 820 & ICH Q10 Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
D Differences between (c)GMP for Drugs and Medical Devices Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
A EN 60601-2-51 - Differences between the 2003 and the 2005 edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
V Differences between Business Process Reengineering (BPR) and Total Quality Management Quality Manager and Management Related Issues 3
V Differences between Quality Tools and Quality Concepts? Quality Tools, Improvement and Analysis 4
G What are the differences between US and EU Pharmacopeias? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 11
N Differences between a Safety Nonconformance and a Quality Nonconformance Nonconformance and Corrective Action 14
F Differences between ISO 9001 and ISO 9004 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Defining the differences between Prototype vs. Production Guidelines? Contract Review Process 5
S Differences between the SAE AS9100C and BS EN AS 9100:2009 versions of the standard AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
V Similarities and Differences between EU & US GMPs (Good Manufacturng Processes) Document Control Systems, Procedures, Forms and Templates 8
J Definition Servicing circuit boards - Differences between Rework and Repair Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
