Does ISO 9001 require to document every nonconformity, however small it is?
I understadt that if You order a fan from your supplier and upon installing it you find out it has an imbalance, you should record this.
But if a small screw is bended and you just take a new one out of a 100 pieces box, should this be recorded too?
Is it ok to set some standards how the employees can differ between problems which should be documented and smaller problems which can be solved immediately?
Or are non conformities only problems you find at some kind of checkpoint/quality gate etc. ?
If thats the case, what about problems the employees run into while assembling parts?
If you were to attempt to perform corrective action on every nonconformance you would have little time for anything else. You are permitted to determine what nonconformances require only correction and which ones require corrective action.
Your system should have a robust method of both identifying the ones you can and effectively resolving them though.
