Digging Datums - Feature control frame (FCF) applied to a pipe I.D.
optomist1
A Sea of Statistics
Hi To All,
Searched but unable to find an answer, don't have drawing to post but here's the question. Given a cylindrical pipe with a mounting flange and a feature control frame (FCF) applied to the pipe I.D. , requiring a tolerance of position of 0.05(cylindrical tolerance zone), with Datum A (the pipe flange planar, normal to the pipe length) referenced and Datum B referenced. The problem, this FCS sets up or establishes Datum B an axis......a FCF that establishes a Datum and references the same datum.....is this acceptable?
Thanks,
Marty
Stijloor
Re: Digging Datums
Hi To All,
Thanks,
Marty
What are the primary and secondary datum features?
Stijloor.
optomist1
A Sea of Statistics
Hi Stijloor,
Primary Datum Feature A is the pipe mounting flange which is perpendicular or normal to the length of the pipe (there is a flatness control applied to this planar surface/datum), Secondary Datum Feature B is the I.D./FOS of the thin walled pipe.......
Thank you...
Marty
Stijloor
Hi Stijloor,
Thank you...
Marty
Marty,
I made a sketch using the information provided in your two posts (1 & 3).
The positional callout you described is incorrect because the secondary datum feature (of size) which is used to develop datum (axis) "B" is also the controlled feature. Does this appear on an actual drawing? :mg:
Now, if the design intent is to have the axis of the ID of the pipe perpendicular with the flange, then the position symbol must be replaced with the perpendicularity symbol.
The Feature Control Frame should then read: Perp at (dia) 0.05 to Datum A.
Just a few thoughts. Hope this helps.
Stijloor.
optomist1
A Sea of Statistics
Marty,
Stijloor.
Hi Stijloor,
yes, once again seeking "Stuart Smalley" affirmation....hopefully stating this correctly; one cannot use a FCF to among other things establish a Datum and reference the same Datum in the Datum portion of the same FCF. This is on a drawing that was used for quiz purposes so this GD&T trangression may have been part of the question.
Thanks again,
Marty
H Digging Up Bones - Inspector Retrieving Very Old Inspection Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
2 GDT of datums - Putting Datum C on a drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
O How to deal with Multiple Datums - Position with respect to Multiple Datum Feature Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J Position Tolerance Called to Datums with MMC Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M 4 Datums Referenced in a Print (Drawing) Feature Control Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
V GD&T Interpreting Datums in Two Single Segmented Position Tolerances Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Best Fit Alignment vs. Hard Datums Calibration and Metrology Software and Hardware 5
F Checking runout in reference to 2 datums Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
optomist1 Functional Datums - Advanced Concepts of GD&T 2nd edition by Alex K Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
CarolX GD&T Call Out - True Postion Call Out on Datums Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
Ron Rompen Location of features identified on Print - Feature out of location Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Ron Rompen Measurement Method Challenge - Measure feature #91 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
Marc Definition RFS - Regardless of Feature Size (GD&T) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
A Inform NB of change to Indications of Use, but change is not a medical feature CE Marking (Conformité Européene) / CB Scheme 1
Howard Atkins MSAs are now required on every feature of the control plan - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 13
B Counterbore - Hole or feature? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
U Control Charting a Feature with Bonus Tolerance Quality Tools, Improvement and Analysis 10
K Can a Surface of a profile be applied to a feature of size? GD&T questions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Using Minitab 17's Stepwise Regression to Predict Feature Using Minitab Software 2
R Rejecting a Part when Dimension Feature is Basic Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
P Measuring Feature Location from a Theoretical Centerline Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L ASME Y14.5 Coaxial Feature Toleranced with Position w/o Reference Datum Design and Development of Products and Processes 2
R Capability for CMM Scanned Profiles on a feature with a Bilateral Profile Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 26
B REACH & ROHS Declaration for Concrete Casting Water Feature RoHS, REACH, ELV, IMDS and Restricted Substances 3
C GR&R of a gauge to check a new feature of a new product Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
optomist1 GD&T - Indirect Straightness Control - The Size Dimension on a Feature of Size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
optomist1 Feature Control Frame is applied to the end of a Cylinder - Datum Dilemma Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M Machine Feature: Is it possible to consider it Error Proofing? FMEA and Control Plans 6
F CMM Scanning Feature Delays - Brown and Sharpe automatic CMM using PC-DMIS CAD 4.3 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
optomist1 GD&T - Bounded Feature or Bounded Feature of Size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C Reporting Profile of a Surface Results on an Internal Cylindrical Feature Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
B Capability Analysis of a Repeated Feature Quality Tools, Improvement and Analysis 9
optomist1 Coplanar Widths As Datum Feature Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
optomist1 Multiple Single Segment Feature Control Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
optomist1 Tolerance of Position - Pattern of Holes at MMC - Datum Feature Reference Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
optomist1 Size Dimension and Feature of Size - FOS as subset of a Size Dimension Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
H TC 176 Website - Request for an Interpretation Feature ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
I Can Training feature in a Process FMEA FMEA and Control Plans 12
Z MSA (Measurement System Analysis) for a .0003" tolerance feature Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
K What features (feature list) for free calibration software? Calibration and Metrology Software and Hardware 11
B Pointless GD&T Position Callout? Feature is labeled as a Key Characteristic Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
K Understanding True position - Drawing Feature Control Frames - ANSI Y14.5 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
L SC in a circle next to feature box - Is this "Statistical Control" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
S Feature perpendicularity dimension should be good up to how many decimal points? Manufacturing and Related Processes 8
Ajit Basrur Has anyone used the "Certification Totals" feature on ANAB Website ? Registrars and Notified Bodies 9
N Using the narration feature in powerpoint as a training tool Training - Internal, External, Online and Distance Learning 12
L What Standard Applies to This? Feature (or defects) not depicted on the print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Manix Feature Control Frame - Interpretation - Two Tolerances? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
M GD&T Q&A session - Interpreting FCF (Feature Control Frame) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 43
Q Use of OD Indicator Micrometers - Round Feature vs. Flat Surfaces Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
