Dimension control on injection molding parts
Jafri
#11
So in the last few days, what I did was to contact the design group. They agreed to put critical dimensions on the print.
Plan is that once these do it then Quality will have a ground to require Cp done on those dimensions. I will give them no other option.
How they do it will be their concern. The only need to tell us their method. CMM or conventional inspection equipment.
If they disagree them I will simply refuse to approve their PPAP.
But hopefully, things won't get to that point. They will listen to us. Because I have asked designers to be on the meeting with suppliers as third party (they are consultants).
Currently, I am waiting for the marked print from the design team.
Golfman25
#12
So you're asking them to prove capability on critical dimensions after the fact and taking a hard line by not approving their PPAP?
Jafri
#13
So what are you suggesting? That we should accept FAI only and forget about any process capability, no matter how important the dimension?
What are our options?
you'll get much further working together.
Of course. The way I'm saying here will not be the way I will be talking to them. :)
This PPAP signing thing was just frustration. Probably.
I can't stop a supplier selected by the company and who has spent a lot of money developing the tool.
Marc
#14
I disagree. There are too many drawings these days drawn with zero thought on how to check the part in the real world. Everytime we ask the designer "how are we going to check that" we get a blank stare. They'll defer to their quality people who will respond "good question." Both sides need to be on the same page regarding measurement.
The problem is a very old one. I've had clients where I had to bring in a GD&T expert (who specialized in both making and marking prints correctly, and in "how to best measure") to guide the supplier in producing prints and the customer in reading them (as "best" measurement equipment / techniques. Essentially I set up meetings where the expert, the supplier and the customer were all in a meeting room and we went over prints and how to measure the various dimensions (as well as potential measurement fixtures).
There are many companies who have no GD&T and/or measurement techniques experts. I mention this because sometimes it takes more than simply supplier and customer "working together".
Wes Bucey
Prophet of Profit
#15
I wrote about our process a long time ago here in the Cove. If I have time, I'll research for the exact post, but, essentially, in our high tech precision machining business, we used a process similar to what Marc describes on EVERY product we made for customers as part of Contract Review. BEFORE we ever cut a chip off metal, we had the inspection plan agreed with all parties, assuring the proper instrumentation was available to check, with operators and inspectors trained and confirmed proficient on ability to deploy such instrumentation. It sure saved a lot of grief other machining companies had when customers rejected parts because of misunderstandings on critical dimensions and methods of inspection, including sampling plans.
Golfman25
#16
That's where it kind of is these days. But it is still a chore. You just pull the "grief" up to the beginning of the the process. Too many designers don't want to listen to what the process is capable of. Plus, you're usually in a rush to get things going -- somebody has sucked up all the lead time.
Wes Bucey
Prophet of Profit
#17
As I said, a long standing topic here on the Cove.
Here are some snippets from my posts over the years:
In 2015:
"Back in the day" when I owned and operated a precision contract machining company, we made "small" things for customers (nothing bigger than a human fist) and would ship BOTH First Article and our Inspection Report with space for customer to replicate the inspection with similar instruments as noted in the report. Oddly, after we incorporated that clause in our contracts, many of our customers welcomed the change and were very prompt in responding. (Part of the contract was approval of the exact inspection procedure and agreement both customer and supplier would use similar instruments and techniques.)
We were adamant, though, we would NOT ship without approval or written waiver. Often, we would not proceed with manufacture until the approval or waiver on any product which might have "subjective" attributes (color/finish/etc.) versus "objective" characteristics (dimension/hardness/chemical analysis.)
Every supplier must determine its "will not cross" lines. Ours were more like chasms that needed a bridge instead of a line that could easily be stepped over. We found it a commercial advantage in that customers valued the integrity.
In 2014:
As a supplier, I was obsessively customer-centric and did everything I could to make the customer's job of handling my products as trouble-free as possible. This obsession resulted in great customer loyalty. My goal was always to create a dock-to-stock mentality about our goods, by-passing incoming inspection if we possibly could.
NOTE: all our products were custom-made to a customer's specifications (sometimes the specs and designs were changed as a result of our concurrent engineering - discussed in this post.
http://elsmar.com/Forums/showpost.ph...6&postcount=20
Thus, the following discussion is really only valid for custom-made products.)
As a consequence, we agreed, as part of Contract Review with the customer, on EXACTLY what we would inspect, with what instrument, in what order (feature numbers on engineering drawings) and would report those on a checklist with each shipment.
Usually, this resulted in a columned check sheet with each feature number listed, the instrument used, the result, and a column for the customer to fill in with HIS readings.
If we had a sufficiently large run using SPC, the exact samples would be numbered and attached to the check sheet. Obviously, if desired, the customer could pull his own samples from the shipment as well.
This obsession to detail and precision convinced almost all our customers to rank us as dock-to-stock suppliers, skipping incoming inspection.
We ALWAYS included the engineering drawing of the revision we followed, with the feature numbers, so there would be fewer chances of a receiving inspector, himself, using an obsolete version of the drawing. None of our customers thought it burdensome to comply with our request for collaboration on inspection procedures and reporting. In a converse situation, I don't foresee a supplier objecting with a customer's request for something similar.
View this post
http://elsmar.com/Forums/showthread....433#post558433
for links to a number of pertinent posts on inspection processes.
recapitulation of previous pertinent posts:
Over a number of years here in the Cove, I have written about my high tech contract machining business which I ran from 1990 to 2000. Since we may be shutting down the Cove in a few months, I offer you a last chance to review some of these to see if anything might be pertinent to YOUR situation, either as supplier or customer.
Regular Cove readers may be familiar with my frequent rants against Kwality Kops (those Keystone Kop types who relish their power to say gotcha when they detect a nonconformance.)
Ideally, there is no us versus them rivalry in the workplace. All should be happy to work toward a common goal of a more efficient, profitable environment.
I have written previously that our Quality guys did not perform routine inspections - they designed the inspection protocol for each part and trained operators, interfaced with customers and suppliers, and acted as court of last resort when issues arose.
In my own operation, I took the police action out of the quality function and had a much happier workforce. The following post is an overview description of what we did. Perhaps you might glean some insight into helping your organization work in cooperation instead of conflict.
http://elsmar.com/Forums/showpost.ph...21&postcount=9
I went into more detail in this series of posts: Wes Bucey on an efficient shop - empowerment (This is a single post (#18) in a longer thread - the url leads directly to the post - it is associated with a follow-up in post #20) http://elsmar.com/Forums/showpost.ph...9&postcount=18 Wes Bucey on quoting and empowerment (This is a single post (#20) in a longer thread - the url leads directly to the post) http://elsmar.com/Forums/showpost.ph...6&postcount=20
In process and final inspection: Re: Inspection Dimensional Check Sheets - Over 500 part numbers (http://elsmar.com/Forums/showthread....cle#post274032)
Who inspects? I, too, ran a shop where primary responsibility... (http://elsmar.com/Forums/showthread....cle#post150031)
Control Charts In my high tech machining business (1990 -2000),... (http://elsmar.com/Forums/showthread....icle#post97017)
What makes sense? In point of fact, I have seen several operations... (http://elsmar.com/Forums/showthread....icle#post85248)
Marc
#18
I apologise for getting this discussion off track. I've been known to do that...
Original Post (Key Question):
I am thinking what should I ask them to ensure that these dimensions stay in tolerance after some passage of time?
Should I ask them for yearly CMM check, even if from outside? Or do customers usually just don't ask for such verification?
*confused*.
So - year to year dimensions, and some type of plastic or rubber material (the expected life of which isn't an issue in PPAP documents(?)).
In this scenario yes - Good prints is Job #1, but measurement method/equipment is extremely significant since often the material properties do not allow for "normal" measurement instruments such as a caliper.
This came to mind as I spent some time in injection molding, another situation where I was doing problem solving as that's what my contracts were about. Dimensional measurement came into play a lot. Rubbers, plastics and such are far different animals to measure than metals.
A lot of good posts. Excellent discussion! :agree1: In a way, Thanks for the memories!
Wes Bucey
Prophet of Profit
#19
This is about one of our suppliers who will be sending us injection molding parts.
They are going to do First Article Inspection on all dimensions in 3 samples initially. Some of these dimensions are difficult to check without CMM, which they don't possess. Nor do they have any checking fixture.
*confused*.
Thanks. :)
What's the real problem? You imply it is because supplier can't verify to the micron via CMM? Isn't the real problem essentially: Form, Fit, Function? As we learn later in this thread, Buyer doesn't have independent instrumentation to verify the dimensions either. This means buyer HAS to trust supplier or why is he doing business with him? Ultimately, buyer and supplier have to cooperate in finding a way to give assurance the mold and parts made from the mold remain stable over the term of the contract. FAI is useless if the instruments used to verify dimensions are incapable of accurately measuring the dimensions.
Do you have a CMM?
If you are specifically concerned with tool wear and dimensional creepage...can they send ahead first and last article for you to verify?
Just thinking out loud...
Yep. My first thought. too. As we see later, the deal is more muddy.
I think you both need to sit down and develop and agreed checking methodology. Gauging and fixturing may help.
Very sensible statement. It is easier when supplier and buy work as PARTNERS in produced an acceptable finished product.
No, we don't have CMM either.
Yes, I'm concerned about too wear, and how the supplier will be able to find out about it before it starts making bad parts.
The supplier will do FAI 100% once, but I don't understand what is last article?!
Ah, now we are beginning to see some light. It isn't common, but it happens from time to time that designers don't take into account that their organization isn't equipped to perform sophisticated tests to assure products they buy meet the specifications in the designs. In such cases, they do something to assure themselves the product reaches them in ready to use condition. Usually this means selecting a supplier who has the capability and capacity to do that and the buyer will contract with an independent service with similar or greater capability of measurement and test to act as a surrogate in verifying the work of the supplier. I did it all the time for tests like metallurgy, chemistry, heat treating, x-ray diffraction.
IN SUMMARY: Marc is correct. We, especially I, went far astray on this topic. (Typical Wes - tell you how to build a watch when all you want is the current time of day.) Simply, buyer and supplier need to sit down together and work out a way to assure themselves they make and use a product which meets all specifications to form, fit, and function. If this means contracting a trusted third party, that may be what's required. If it means buying proper instruments and getting trained people to operate them, that's an economic decision for each party to make.
Scanton
Wearer of many hats
#20
We used to get this from our bigger customers on a regular basis where we would receive a drawing to make a component, so we would make that component and then a second drawing would appear (with the same revision number) because they forgot a critical feature or two, and then another (with the same revision number) with a tighter tolerance that should have been on the drawing from the beginning. We would dutifully do the extra needed to satisfy the customers’ needs because they are a big customer and we need their business, and before you know it you are making a component “just for fun” for the next 5 to 7 years with any margin long gone through all the extra resources need to satisfy these “additional” requirements.
I recent years we have taken a much harder line with customers. If they change the drawing, we review this change and if it costs more to satisfy these changes because of additional resource or increased cycle time etc, then we re-quote at a higher price to pay for the additional resource required to make this component at this new revision level, simple. We also do not accept changes to a drawing without a change to revision level, you would be amazed how many times we have seen that from big business.
I agree with what many have said here, all of this should be sorted out at the beginning of the process, unfortunately it hasn’t been so you are going to have to work with your customer in order to get what you need at a reasonable price (or take your business elsewhere). If I was in their position and the job is high volume and running for years, I would requote the job at the latest revision drawing and amortize the cost of a CMM over the entire contract on X number of parts.
The biggest failure here has been your companies inability to communicate what it actually wants to its supplier, this should have been done at the quote stage.
P Print Control Box - What does this dimension say? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M What is the difference between Critical Dimension and Control Dimension Misc. Quality Assurance and Business Systems Related Topics 7
optomist1 GD&T - Indirect Straightness Control - The Size Dimension on a Feature of Size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G How to ensure dimension of tapping hole before plating is correct? Manufacturing and Related Processes 2
6 MSA for Calculated Clearance Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O Dimension Measurement Tool Recommendation General Measurement Device and Calibration Topics 21
P AS9102 Form 3 Dimension Results Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J How to measure a Critical Characteristic that is a Basic Dimension Misc. Quality Assurance and Business Systems Related Topics 6
F Conversion of coordinate dimension holes to position dimension Design and Development of Products and Processes 3
G Customer complaint over a Reference Dimension Manufacturing and Related Processes 9
Prashant G MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension Reliability Analysis - Predictions, Testing and Standards 4
Q How do you interpret this dimension in my drawing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B 7.1.5.1.1 MSA for inline dimension vision inspection equipment IATF 16949 - Automotive Quality Systems Standard 5
S Basic Dimension W/O using FCF Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
O Start Up Approval Dimension Records IATF 16949 - Automotive Quality Systems Standard 5
C The difference between a Critical Dimension vs. Critical Characteristic Misc. Quality Assurance and Business Systems Related Topics 2
C MSA (Measurement System Analysis) - Dimension Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Z Is PPAP Re-qualification needed in case of not quoted dimension change? APQP and PPAP 4
APHX02 AS9102 FAI Requirements that pertain to a Dimension 'delta' AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
T PPAP - Complaint from a Tier One customer concerning Product Dimension IATF 16949 - Automotive Quality Systems Standard 26
M SPC with many data points from one dimension Statistical Analysis Tools, Techniques and SPC 16
S Using Calibrated OD mic over non-Calibrated ID mic for final dimension Manufacturing and Related Processes 17
V Dimension marked with "frame" on 2D drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S Labeling Symbols for EU - E.g. EN980 - Dimension, color, font, etc. Other ISO and International Standards and European Regulations 6
P The correct way to do a Linearity and Stability Study on a Critical Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
J Hole Form Dimension - Shaft dimension which is +-.015 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
E Callout of a length dimension and then P.I at the end - What does that mean? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R Rejecting a Part when Dimension Feature is Basic Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M Dimension Report Formula .xlsx Editable Spreadsheet Form Excel .xls Spreadsheet Templates and Tools 24
I Hole dimension out VS in tolerance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
D Profile of a Line of a radius of 25mm basic dimension - Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
S PPAP - How to calculate tolerance on basic dimension APQP and PPAP 5
R German Customer with a Dimension format I have not seen before Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
V Out of Tolerance on Non Critical Dimension (PPAP) APQP and PPAP 8
J Basic Dimension Chaining - Second hole has a basic dimension from the first hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D Hole Limit Dimension Values Placement - Smaller Limit On Top? Manufacturing and Related Processes 3
L When and how to apply Bonus Tolerance MMC - Hole Dimension Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
optomist1 Size Dimension and Feature of Size - FOS as subset of a Size Dimension Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Customer wants each dimension, including reference, in PFMEA FMEA and Control Plans 6
O Capability Study on Continual Arbitrary Dimension Capability, Accuracy and Stability - Processes, Machines, etc. 11
P (Acme) 29deg stub thread 9TPI - Thread dimensions & tolerancing and root dimension General Measurement Device and Calibration Topics 8
J Calibration Requirement for Virtek Laser Dimension machine Calibration Frequency (Interval) 1
J Angularity - When angularity is called out should it be to a basic dimension Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Measurements (Dimension) Data Anaylsis - Methods to determine trends Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Problem with Cpk calculation of dimension with nominal at the top limit. Statistical Analysis Tools, Techniques and SPC 6
B Calculating Capability on a One-Sided Tolerance Dimension Capability, Accuracy and Stability - Processes, Machines, etc. 12
S Using the results from GR&R (Gage R&R) Analysis - One sided dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 25
D How to set my quality dimension yearly target based on prior years data? Statistical Analysis Tools, Techniques and SPC 3
D Definition Prints that have a dimension and immediately after it the letters "N. T. S." Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 15
T Use of the tilde symbol below a dimension indicated it was out of scale? Manufacturing and Related Processes 4
