Dimension Measurement Tool Recommendation
OneMoreCouch
Hello all,
I am information systems manager that has been newly tasked with overseeing the Quality Control team next month and I'm trying to learn as much as I can.
I wanted to quickly ask what is our best option on which measurement device to use for our QC team - currently they are using calipers.
Our factory makes Ferrite EMI cores that come in rod shapes or core shapes (circular or block) some photos for reference. Our volume is at about 500k piece (in combination of different products) per day.
The factory is very old fashion and the Quality control team currently takes samples from our carts after sintering and brings it back to their desk for measuring. They then document their measurements on a paper in preparation to be inputted into excel. I see a few risks and inefficiencies here that I'm hoping to find answers to here.
1. Measuring with a Caliper is slow and accuracy is dependent on the operator. An example of one of our stricter tolerance is 3mm x 16mm+- 0.005cm
2. Using the Caliper seems tiring to me for a QC operator to do all day. Fatigue will lower their accuracy and with the volume that we have I find it very risky.
3. Redundancy of operator writing down measurements and then inputting into a computer in a separate step
I feel like our quality control is really limited to the sample size due to the inefficiencies of what's listed above. To help us improve, we must increase efficiency so we can sample more products (in ratio to our production amount) From a quality control novice, I believe there must be a better way to provide the team to measure these products in bulk. Is there anything that is laser based to measure our products in bulk?
Any ideas or suggestions will be greatly appreciated.
dwperron
A few questions:
How many pieces are measured each day.
What is the size range.
What are you measuring, outside diameter, inside diameter, length...
What kind of accuracy do you need for the measurements
Michael_M
On a generic level, most companies have a 10 to 1 rule. The device used to measure should be 10x more accurate than the listed tolerance. In some very rare cases, this might need to be reduced to a 4 to 1 rule depending on the actual tolerance level (Imperial ±.0003 inch for example--sorry, not very good at metric). In this case, I do not believe the calipers are accurate enough for this measurement.
I know that Mitutoyo (no affiliation) had a software that allowed for direct 'SPC' input that would sit at the machine or travel with the inspector and digitally record the measurement. I used this system about 15 years ago so they probably have something much better now.
OneMoreCouch
A few questions:
Sorry for the late reply:
1. Currently we are employing S3 inspection level so I believe its about 32 per 150K
2. Size Range is about <0.15 mm
3. For cylindrical product, we measure length, diameter. Other products we measure length, height, outside diameter and inside diameter.
4. The finest accuracy required is about 0.01 mm but it is less common. Products with scale, we have tolerance of about 0.03mm
I hope my answers make sense as I'm still new to this. Please let me know if I can bring any more information to you guys.
dwperron
I believe this is incorrect, the 2 drawings you attached show sizes of 15 and 30 mm.
Knowing how large these parts are will help determine appropriate equipment to make the measurements.
Golfman25
Ask the inspectors. A caliper could be just fine. Or you could spend lots of money on fancy machines. It all depends what you need.
OneMoreCouch
Sorry, I thought you meant the range of our max and min products from this product spec. What I meant was 0.15mm is usually the largest range between the largest product and the smallest product.
The product I posted specifically was 3mm x 15mm +- 0.1mm
OneMoreCouch
What I would like is having the ability for us to measure most if not all of the products. WIth our volume, using a caliper is not possible (unless we hire a lot more people). I also want to be able to measure all products to collect the data on the size to see how our production people are doing.
Fancy machine or not, how can one go about achieving being able to measure out the dimensions of a product? This specific product (the one i posted) is at around 150k-200k piece manufactured per day.
C MSA (Measurement System Analysis) - Dimension Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Spur Gear DOP (Dimension Over Pins) Measurement - 2 or 3 Pins? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
G How to ensure dimension of tapping hole before plating is correct? Manufacturing and Related Processes 2
6 MSA for Calculated Clearance Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P AS9102 Form 3 Dimension Results Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J How to measure a Critical Characteristic that is a Basic Dimension Misc. Quality Assurance and Business Systems Related Topics 6
F Conversion of coordinate dimension holes to position dimension Design and Development of Products and Processes 3
G Customer complaint over a Reference Dimension Manufacturing and Related Processes 9
P Print Control Box - What does this dimension say? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Prashant G MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension Reliability Analysis - Predictions, Testing and Standards 4
Q How do you interpret this dimension in my drawing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B 7.1.5.1.1 MSA for inline dimension vision inspection equipment IATF 16949 - Automotive Quality Systems Standard 5
J Dimension control on injection molding parts Manufacturing and Related Processes 19
S Basic Dimension W/O using FCF Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
O Start Up Approval Dimension Records IATF 16949 - Automotive Quality Systems Standard 5
C The difference between a Critical Dimension vs. Critical Characteristic Misc. Quality Assurance and Business Systems Related Topics 2
Z Is PPAP Re-qualification needed in case of not quoted dimension change? APQP and PPAP 4
APHX02 AS9102 FAI Requirements that pertain to a Dimension 'delta' AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
T PPAP - Complaint from a Tier One customer concerning Product Dimension IATF 16949 - Automotive Quality Systems Standard 26
M SPC with many data points from one dimension Statistical Analysis Tools, Techniques and SPC 16
S Using Calibrated OD mic over non-Calibrated ID mic for final dimension Manufacturing and Related Processes 17
V Dimension marked with "frame" on 2D drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S Labeling Symbols for EU - E.g. EN980 - Dimension, color, font, etc. Other ISO and International Standards and European Regulations 6
P The correct way to do a Linearity and Stability Study on a Critical Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
M What is the difference between Critical Dimension and Control Dimension Misc. Quality Assurance and Business Systems Related Topics 7
J Hole Form Dimension - Shaft dimension which is +-.015 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
E Callout of a length dimension and then P.I at the end - What does that mean? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R Rejecting a Part when Dimension Feature is Basic Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M Dimension Report Formula .xlsx Editable Spreadsheet Form Excel .xls Spreadsheet Templates and Tools 24
I Hole dimension out VS in tolerance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
D Profile of a Line of a radius of 25mm basic dimension - Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
S PPAP - How to calculate tolerance on basic dimension APQP and PPAP 5
R German Customer with a Dimension format I have not seen before Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
optomist1 GD&T - Indirect Straightness Control - The Size Dimension on a Feature of Size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
V Out of Tolerance on Non Critical Dimension (PPAP) APQP and PPAP 8
J Basic Dimension Chaining - Second hole has a basic dimension from the first hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D Hole Limit Dimension Values Placement - Smaller Limit On Top? Manufacturing and Related Processes 3
L When and how to apply Bonus Tolerance MMC - Hole Dimension Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
optomist1 Size Dimension and Feature of Size - FOS as subset of a Size Dimension Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Customer wants each dimension, including reference, in PFMEA FMEA and Control Plans 6
O Capability Study on Continual Arbitrary Dimension Capability, Accuracy and Stability - Processes, Machines, etc. 11
P (Acme) 29deg stub thread 9TPI - Thread dimensions & tolerancing and root dimension General Measurement Device and Calibration Topics 8
J Calibration Requirement for Virtek Laser Dimension machine Calibration Frequency (Interval) 1
J Angularity - When angularity is called out should it be to a basic dimension Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Measurements (Dimension) Data Anaylsis - Methods to determine trends Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Problem with Cpk calculation of dimension with nominal at the top limit. Statistical Analysis Tools, Techniques and SPC 6
B Calculating Capability on a One-Sided Tolerance Dimension Capability, Accuracy and Stability - Processes, Machines, etc. 12
S Using the results from GR&R (Gage R&R) Analysis - One sided dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 25
D How to set my quality dimension yearly target based on prior years data? Statistical Analysis Tools, Techniques and SPC 3
D Definition Prints that have a dimension and immediately after it the letters "N. T. S." Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 15
