Dimensional change with PA raw material product
sadhusong
hello all
we have one product with a central hole was made by PA raw material!
i want to know after a long time storage, the diameter of central hole will how to change, because bigger or smaller as we know the product made of PA raw material will absorb moisture.
with best regards
sadhusong
Stijloor
hello all
We have one product with a central hole was made by PA raw material!
I want to know after a long time storage, the diameter of central hole will how to change, because bigger or smaller as we know the product made of PA raw material will absorb moisture.
With best regards
sadhusong
PA = Polyamide?
Stijloor.
bobdoering
Stop X-bar/R Madness!!
This is a question without a textbook answer.
Well, one textbook answer: "It depends."
It depends on the grade, the processing and on the lot consistency of the manufacturer. This is a question better left for actual experimentation (more than one lot) and some discussion with your supplier (who may have already done some experimentation.) :cool:
Scientific Molder
The "It Depends" is going to be as accurate response as you can expect. Was the PA (Polyamide ) PA6, PA6/6, PA46, PA11, PA12, PA6/12, PA6T, PA9T, well, you see where I'm going. They all will actively absorb and release moisture depending on their envirenment, but at different rates. And that's neat material, without influence of any fillers. As PA absorbs moisture, it will change dimensionally, oddly enough proportional to the % moisture absorbed.
Then, add the product geometry to the mix ! Wheee!
If you had a flat, round disc, with a center hole you can expect several different geomtry changes with regard to moisture level, depending on thickness. After moisturization, a very thin sample would tend to grow in the OD and the ID of the center hole a well. On a thicker sample, The OD would probably grow, and the ID of the center hole get smaller.
I would suggest taking your product, getting measurements at DAM conditions, and then in 24 hr increments being exposed to a 100% RH at 23 deg C untill weight / dimensions cease to move. With that, you should be able to extrapolate pretty well exactly what your specific part will do.
HTH, Alan
C PPAP etiquette - Full PPAP Requested for Minor Dimensional Change APQP and PPAP 15
G What information to put on measurement Dimensional Results APQP and PPAP 7
V Recording CMM dimensional results on CFG-1003 APQP and PPAP 3
N How to resolve discrepancies in Level 3 PPAP supplier dimensional reports? APQP and PPAP 11
K Guard-banding and relaxed acceptance for dimensional gauges General Measurement Device and Calibration Topics 1
N Dimensional Inspection - Symbology cheat sheet Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Calibration Laboratory Dimensional Temperature Question General Measurement Device and Calibration Topics 2
G Procedure Creation specifically for dimensional (caliper, micrometer, dti) Document Control Systems, Procedures, Forms and Templates 8
G Caliper or Micrometer's Dimensional Flatness General Measurement Device and Calibration Topics 5
G Looking for a Metrology Course preferably Dimensional and Electronics Training - Internal, External, Online and Distance Learning 5
B Is Gage R&R required on a 100% Dimensional Layout? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
G Out of Dimensional Tolerance - MRB Audit Issue Nonconformance and Corrective Action 11
T How to report Basic Dimensions on a Dimensional Report (ISIR) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
knightarmourus Initial Samples with dimensional deviation in Serial Production Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
V Ford Dimensional Tag Characteristics requirements APQP and PPAP 2
M How to calculate Cg and Cgk for a 2-Dimensional Area Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J Slotted Hole Dimensional Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
G MSA (Measurement System Analysis) and Dimensional Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Changing dimensional tolerances to approve rejected product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Dimensional Issues because of the last years FORD Recall Manufacturing and Related Processes 2
T Variable Dimensions / Part of Production / PPAP Dimensional Report Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
W Dimensional Calibration Training Class Training - Internal, External, Online and Distance Learning 2
C Building a Dimensional Metrology Laboratory to Inspect various Physical Measurements General Measurement Device and Calibration Topics 2
P Dimensional Mechanical Inspection only as a Service - ISO17025 or ISO17020 ISO 17025 related Discussions 5
J Equipment required for a Dimensional Calibration Laboratory Document Control Systems, Procedures, Forms and Templates 1
C Content of PPAP Dimensional Report APQP and PPAP 8
I Machine Capability Analysis in Multi-Dimensional Cases Capability, Accuracy and Stability - Processes, Machines, etc. 2
O Dimensional Results Requirements for PPAPs APQP and PPAP 6
R Environmental Controls Procedure for Calibration of Dimensional Gages General Measurement Device and Calibration Topics 3
H Dimensional Measurement Uncertainity - Inspection of a component Measurement Uncertainty (MU) 5
H Dimensional Inspection Procedure - Sample wanted Document Control Systems, Procedures, Forms and Templates 2
O The Layout of Dimensional Results and What to Provide the Customer APQP and PPAP 16
S Standard Equipment List for Stocking a Dimensional Metrology Laboratory General Measurement Device and Calibration Topics 8
A Criteria for taking Dimensional Measurements of a Painted Hole in a Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R Reference Standard for the Calibration of Dimensional Measuring Tools General Measurement Device and Calibration Topics 2
R Self Calibration of Dimensional Measuring Tools General Measurement Device and Calibration Topics 3
M Design Review/Dimensional Analysis feasibility program or spreadsheet? Design and Development of Products and Processes 1
N Design of Dimensional Measurement Gage for Bolt General Measurement Device and Calibration Topics 13
M How to define Dimensional Tolerances for Plastic Injection Molded Parts Service Industry Specific Topics 11
M Luer Taper Tolerances - 6% or otherwise - Dimensional Accuracy Other Medical Device Related Standards 23
D AIAG Level 3 PPAP (100% dimensional measurement or just significant characteristics)? APQP and PPAP 2
I Gage Error vs. Dimensional Tolerance - Accuracy needed for measurement equipment Measurement Uncertainty (MU) 10
K Inspection Dimensional Check Sheets - Over 500 part numbers Document Control Systems, Procedures, Forms and Templates 2
J PMA (Parts Manufacture Approval) Dimensional Inspections Federal Aviation Administration (FAA) Standards and Requirements 7
L Acceptance Activities-Dimensional Inspection was missed. Parts already assembled 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
K Dimensional Inspection of Molded Plastic Parts in Seoul, Korea Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Measurement Uncertainty Budget for Comparative Dimensional Measurements Measurement Uncertainty (MU) 8
I Contract Visual, Basic Dimensional Inspection Services Service Industry Specific Topics 2
K Documentation of Dimensional Results for Different Cavities and/or Molds - PPAP APQP and PPAP 12
