Dimensional Inspection Technique for a small Silicone Part
smimatt
Does anybody have any good techniques for inspecting some small, flimsy silicone gaskets? Depending upon how you set it down, it's dimensions change. How do we verify that the dimensions called out on the drawing are correct if it is so flimsy?
Currently we are using a horizontal optical comparitor and placing the part on a piece of upright acrylic. The weight of the part deforms itself when 'stuck' on the glass vertically and we would like to find a way to avoid any deformation for quick and precise inspection.
We are thinking about making a go/no go template (an overlay on the display for the critical dimensions, but we would like something more concrete for the various radii this part has. Any suggestions are appreciated.
Tim Folkerts
Re: Inspection Technique - Silicone Part
An interesting problem, and one for which I have no first hand experience. But I'll try to answer anyway! :D
My first thought is that if you can't measure it, does it really matter much? :rolleyes: Perhaps you can just test if it works for the application it is designed for - if it fits, its good enough!
Another thought would be to weigh the piece. A bad weight would tell you the piece is a bad size. However, the reverse is not true - the piece could be too big on the OD but too thin and still fall in the correct range.
If you really want to test the dimension, it seems you need a way to hold the piece and measure the piece without putting any stress on it. The optical comparator approach should perform the measurements without stress. Holding it without any stress might be tougher. Two ideas that spring to mind include
  • air suspension: like an miniature air hockey table, only with closer-spaced holes and clear materials. Set the whole thing on top of the comparator. One problem is that the part may tend ot move around. (or perhaps slowly shut off the air flow until it settles to the surface.)
  • fluid suspension. you could float the part on a liquid. A saturated salt water solution has a slightly higher density (1.20) than silicone (1.17), so the part should float. Or glycerin has a higher density yet (1.26), so the part would float better.
Tim F
True Position
A vertical optical comparator is an option, but a pricy one.
A very similiar option is a toolmakers microscope, and you can get a radius eyepiece as an option with most of them. This may fit better into your price range. Also it allows the addition of assorted thread eyepieces as needed.
F
Frank T.
Is this part molded or stamped?
If stamped, we use a "mylar template" to verify the tooling, which tells us the tooling is ok. Our customers have approved this method, when no other easy way seems to work. Other than making a fixture resembling the actual component the part is used in or a go/no go gage. Do I dare mention, we yet to have a problem with fit, form or function of any parts, using this method. :notme:
This is just an opinion........
ScottK
Not out of the crisis
I like the idea of making a go/no-go gage based on the how the part will fit in use.
It's pointless to measure what is not measureable.
I run across this with o-ring and quad ring seals.
smimatt
The part is molded and the challenge is that every time you set it down, the dimensions change slightly. So a vertical comparator and toolmaker's microscope would give us the same problems.
I like the template / go-no go approach and we have discussed this. How can this be implemented practically into a quality system since we have not done it before? We have been doing inspecting our parts (mostly machined) using calipers, micrometers and the like, so this is a new approach and I would want to make sure it was done correctly.
Would someone mind further elaborating?
True Position
Could I get a picture of the part and maybe leader lines showing the dimensions you are concerned about or the drawing? Hopefully I'm not the only one, but working in the abstract sometimes causes me to miss obvious t hings.
Crash Not
For inspecting small flimsy parts, I use a Micro-Vu video measuring system. As far as the part moving, you may want to study the print. If it is drawn to ASME Y14.5M-1994 standards, it may specify if inspection should be carried out in "free state variation" or a "restrained condition".
ScottK
how many parts does your system call for inspecting now?
Can you get a sample the part(s) it sits on/between from your customer?
N Dimensional Inspection - Symbology cheat sheet Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Slotted Hole Dimensional Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
P Dimensional Mechanical Inspection only as a Service - ISO17025 or ISO17020 ISO 17025 related Discussions 5
H Dimensional Measurement Uncertainity - Inspection of a component Measurement Uncertainty (MU) 5
H Dimensional Inspection Procedure - Sample wanted Document Control Systems, Procedures, Forms and Templates 2
K Inspection Dimensional Check Sheets - Over 500 part numbers Document Control Systems, Procedures, Forms and Templates 2
L Acceptance Activities-Dimensional Inspection was missed. Parts already assembled 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
K Dimensional Inspection of Molded Plastic Parts in Seoul, Korea Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
I Contract Visual, Basic Dimensional Inspection Services Service Industry Specific Topics 2
A X-Ray for Dimensional Inspection and Scanning for Defects within Polyurethane Foam Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Q Measurement Uncertainty (MU) in Dimensional Inspection in a QC Laboratory Measurement Uncertainty (MU) 2
S Layout and Dimensional Inspection Training Training - Internal, External, Online and Distance Learning 0
T General convention used for dimensional inspection - 4x Accuracy? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Just accredited!!! CMM Dimensional Inspection Laboratory General Measurement Device and Calibration Topics 8
E Looking for Dimensional Inspection Service Service Industry Specific Topics 15
N Dimensional Inspection Business Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
G What information to put on measurement Dimensional Results APQP and PPAP 7
V Recording CMM dimensional results on CFG-1003 APQP and PPAP 3
N How to resolve discrepancies in Level 3 PPAP supplier dimensional reports? APQP and PPAP 11
K Guard-banding and relaxed acceptance for dimensional gauges General Measurement Device and Calibration Topics 1
G Calibration Laboratory Dimensional Temperature Question General Measurement Device and Calibration Topics 2
G Procedure Creation specifically for dimensional (caliper, micrometer, dti) Document Control Systems, Procedures, Forms and Templates 8
G Caliper or Micrometer's Dimensional Flatness General Measurement Device and Calibration Topics 5
G Looking for a Metrology Course preferably Dimensional and Electronics Training - Internal, External, Online and Distance Learning 5
B Is Gage R&R required on a 100% Dimensional Layout? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
G Out of Dimensional Tolerance - MRB Audit Issue Nonconformance and Corrective Action 11
T How to report Basic Dimensions on a Dimensional Report (ISIR) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
knightarmourus Initial Samples with dimensional deviation in Serial Production Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
V Ford Dimensional Tag Characteristics requirements APQP and PPAP 2
M How to calculate Cg and Cgk for a 2-Dimensional Area Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
G MSA (Measurement System Analysis) and Dimensional Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Changing dimensional tolerances to approve rejected product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Dimensional Issues because of the last years FORD Recall Manufacturing and Related Processes 2
T Variable Dimensions / Part of Production / PPAP Dimensional Report Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
W Dimensional Calibration Training Class Training - Internal, External, Online and Distance Learning 2
C Building a Dimensional Metrology Laboratory to Inspect various Physical Measurements General Measurement Device and Calibration Topics 2
J Equipment required for a Dimensional Calibration Laboratory Document Control Systems, Procedures, Forms and Templates 1
C Content of PPAP Dimensional Report APQP and PPAP 8
I Machine Capability Analysis in Multi-Dimensional Cases Capability, Accuracy and Stability - Processes, Machines, etc. 2
O Dimensional Results Requirements for PPAPs APQP and PPAP 6
R Environmental Controls Procedure for Calibration of Dimensional Gages General Measurement Device and Calibration Topics 3
O The Layout of Dimensional Results and What to Provide the Customer APQP and PPAP 16
S Standard Equipment List for Stocking a Dimensional Metrology Laboratory General Measurement Device and Calibration Topics 8
A Criteria for taking Dimensional Measurements of a Painted Hole in a Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R Reference Standard for the Calibration of Dimensional Measuring Tools General Measurement Device and Calibration Topics 2
R Self Calibration of Dimensional Measuring Tools General Measurement Device and Calibration Topics 3
M Design Review/Dimensional Analysis feasibility program or spreadsheet? Design and Development of Products and Processes 1
N Design of Dimensional Measurement Gage for Bolt General Measurement Device and Calibration Topics 13
M How to define Dimensional Tolerances for Plastic Injection Molded Parts Service Industry Specific Topics 11
