Dimensional Measurement of 10% accuracy and 25% uncertainty standard
W
wintay
Dear all,
I will like to verify if there are standards to comply with on the 10% accuracy and 25% uncertainty for dimensional measuring equipment.
Please advise.
Million Thanks.
dgriffith
Dear all,
Please advise.
Million Thanks.
Yes, of course. However, (opens can of worms...) we would need to know what dimensional equipment is being calibrated. Generally, a gage block will suffice as one type of dimensional standard.
As for 10% and 25%, don't confuse the two concepts.
I think you are referring to the standard having a resolution 10 times better than the unit under test. UUT has a resolution that reads to 0.001, so the standard should read to 0.0001. It's a mostly outdated concept but still used everywhere. It does not guarantee sufficient anything.
The 25% refers to the standard, or the collective standards if several are used in a calibration, having an uncertainty that is 25% or less of the UUT specification. If it does then the standards are considered to have a minimal impact/influence on the UUT measurements that can largely be ignored.
That's the superficial explanation.
Fire away, all.
W
wintay
The 25% refers to the standards, or the collective standards if several are used in a calibration, having an uncertainty that is 25% or less of the UUT specification. If it does then the standards are considered to have a minimal impact/influence on the UUT measurements that can largely be ignored.
Fire away, all.
Thanks dgriffith.
To understand further.
When you mentioned that the 10% accuracy(resolution) concept is already outdated, may I know what is the current concept? And which commercial or ISO standard I can refer to?
Thanks.
JAltmann
You won't find the 10% in any standard, it is a general acceptance, that many state is derived from a standard as that is what they were told, but can never produce it. Last I read it dated to somewhere in the 50's.
In today's world the closet I have seen is the AIAG MSA manual in regards to 10% GR&R acceptance criteria.
In regards to the 10% being outdated I think the poster was referring to ever tightening tolerances, making the 10% difficult to achieve in some cases. I still target 10%, but ultimately add in common sense/cost-benefit ratio to justify higher.
dwperron
Thanks for the question!
These are numbers I have always taken for granted, but you spurred me on to doing a little research on the matter.
Regarding the 10:1 ratio, the sources I found refer to this being a "rule of thumb" used in control charting. I can not find any document that cites this, even though, like many others, I have been taught that this is the "preferred" test accuracy ratio, and that if you cannot achieve 10:1 then 4:1 is acceptable.
So where does the 4:1 ration come from? I read in NASA publications that it goes back to the 1950's, when the Navy discovered that they were having difficulty maintaining a 10:1 ratio, and wondered if this was really necessary. Jerry Eagle of the Naval Ordinance Lab studied the matter and came up with a statistical analysis that a 1% consumer risk on calibration results would be considered acceptable. This is translated into about a 3:1 test accuracy ratio, and he then built in a "cushion" to recommend a more conservative 4:1 ratio. This became accepted as the standard.
As to standards requiring calibration accuracy ratios, I have found these:
ISO 10012-1:1992 in Section 4.3 Guidance states:
"The error attributable to the calibration should be as small as possible. In most areas of measurement it should be no more than one third and preferably one tenth of the permissible error of the confirmed equipment when in use". This is the only reference to a 10:1 ratio that I can find, it is "preferred" and not required. Also, the current version ISO 10012:2003 drops references to these requirements.
MIL STD 45662A 5.2 requires a 25% minimum ratio (4:1)
ANSI Z540-1 10.2 b) requires a "collective uncertainty of the measurement standard shall not exceed 25% of the acceptable tolerance" (4:1)
ANSI Z540.3 duplicates this requirement in section 5.3 b)
So it appears the the only current accuracy ratio requirement is the 25% (4:1 TUR)
Hope that this helps.
dgriffith
DW,
Nice research, thanks.
It can now be demonstrated that for consumer risk, using a 2% probability of false accept (claimed in tolerance when actually out), the test uncertainty ratio point is 4.6:1. This is for as-left out-the-door MTE, not as-found.
dsanabria
...and yes - top customer in the industry will require you to follow this principles - the same as the temperature principles without scientific or research data to back it up.
Do it because it's being done before..... so once in a while - challenge back ;)
I Gage Error vs. Dimensional Tolerance - Accuracy needed for measurement equipment Measurement Uncertainty (MU) 10
P Dimensional Requirement: Precision vs. Accuracy of its Measurement General Measurement Device and Calibration Topics 2
G What information to put on measurement Dimensional Results APQP and PPAP 7
G MSA (Measurement System Analysis) and Dimensional Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
H Dimensional Measurement Uncertainity - Inspection of a component Measurement Uncertainty (MU) 5
N Design of Dimensional Measurement Gage for Bolt General Measurement Device and Calibration Topics 13
D AIAG Level 3 PPAP (100% dimensional measurement or just significant characteristics)? APQP and PPAP 2
J Measurement Uncertainty Budget for Comparative Dimensional Measurements Measurement Uncertainty (MU) 8
Q Measurement Uncertainty (MU) in Dimensional Inspection in a QC Laboratory Measurement Uncertainty (MU) 2
M Lever type dial gauge - Usage of a dimensional 'test indicator' for measurement General Measurement Device and Calibration Topics 10
W What is dimensional layout of the gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K COPLANARITY: Composite profile tolerance on multiple surfaces- what does" lower dimensional reference frame tolerance" control? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
V Recording CMM dimensional results on CFG-1003 APQP and PPAP 3
N How to resolve discrepancies in Level 3 PPAP supplier dimensional reports? APQP and PPAP 11
K Guard-banding and relaxed acceptance for dimensional gauges General Measurement Device and Calibration Topics 1
N Dimensional Inspection - Symbology cheat sheet Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Calibration Laboratory Dimensional Temperature Question General Measurement Device and Calibration Topics 2
G Procedure Creation specifically for dimensional (caliper, micrometer, dti) Document Control Systems, Procedures, Forms and Templates 8
G Caliper or Micrometer's Dimensional Flatness General Measurement Device and Calibration Topics 5
G Looking for a Metrology Course preferably Dimensional and Electronics Training - Internal, External, Online and Distance Learning 5
B Is Gage R&R required on a 100% Dimensional Layout? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
G Out of Dimensional Tolerance - MRB Audit Issue Nonconformance and Corrective Action 11
T How to report Basic Dimensions on a Dimensional Report (ISIR) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
knightarmourus Initial Samples with dimensional deviation in Serial Production Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
V Ford Dimensional Tag Characteristics requirements APQP and PPAP 2
M How to calculate Cg and Cgk for a 2-Dimensional Area Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J Slotted Hole Dimensional Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
B Changing dimensional tolerances to approve rejected product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Dimensional Issues because of the last years FORD Recall Manufacturing and Related Processes 2
T Variable Dimensions / Part of Production / PPAP Dimensional Report Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
W Dimensional Calibration Training Class Training - Internal, External, Online and Distance Learning 2
C Building a Dimensional Metrology Laboratory to Inspect various Physical Measurements General Measurement Device and Calibration Topics 2
P Dimensional Mechanical Inspection only as a Service - ISO17025 or ISO17020 ISO 17025 related Discussions 5
J Equipment required for a Dimensional Calibration Laboratory Document Control Systems, Procedures, Forms and Templates 1
C Content of PPAP Dimensional Report APQP and PPAP 8
I Machine Capability Analysis in Multi-Dimensional Cases Capability, Accuracy and Stability - Processes, Machines, etc. 2
O Dimensional Results Requirements for PPAPs APQP and PPAP 6
R Environmental Controls Procedure for Calibration of Dimensional Gages General Measurement Device and Calibration Topics 3
H Dimensional Inspection Procedure - Sample wanted Document Control Systems, Procedures, Forms and Templates 2
O The Layout of Dimensional Results and What to Provide the Customer APQP and PPAP 16
S Standard Equipment List for Stocking a Dimensional Metrology Laboratory General Measurement Device and Calibration Topics 8
A Criteria for taking Dimensional Measurements of a Painted Hole in a Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R Reference Standard for the Calibration of Dimensional Measuring Tools General Measurement Device and Calibration Topics 2
R Self Calibration of Dimensional Measuring Tools General Measurement Device and Calibration Topics 3
M Design Review/Dimensional Analysis feasibility program or spreadsheet? Design and Development of Products and Processes 1
M How to define Dimensional Tolerances for Plastic Injection Molded Parts Service Industry Specific Topics 11
M Luer Taper Tolerances - 6% or otherwise - Dimensional Accuracy Other Medical Device Related Standards 23
S Dimensional change with PA raw material product Manufacturing and Related Processes 3
K Inspection Dimensional Check Sheets - Over 500 part numbers Document Control Systems, Procedures, Forms and Templates 2
J PMA (Parts Manufacture Approval) Dimensional Inspections Federal Aviation Administration (FAA) Standards and Requirements 7
