Disposal of Calibrated Measurement and Test Equipment
mecramur
Should equipment in a calibration program that is being disposed or removed from the program be calibrated before it is disposed or removed?
Stijloor
Re: Disposal of calibrated equipment
Why would you? It does not make economic sense....
Stijloor.
Jerry Eldred
Re: Disopsal of calibrated equipment
Sometimes (usually) YES, but not always. The purpose of AS FOUND measurements in a re-calibration is to verify if the instrument drifted out of tolerance during the previous calibration cycle. So if it is not being re-submitted for re-calibration, but is being disposed, you still need that information. If you are pulling it out of service at the end of the calibration interval (or during it), you need to know if while it was being used in it's final cal interval, if any readings made were out of tolerance so that appropriate corrective action can be taken.
The reason it is a USUALLY, is depends on your quality system, and also, if it was not in an active calibration interval, under those circumstances, there may be no need for a final outgoing re-calibration. If it was in storage or inactive prior to being disposed, there is (in my opinion - maybe some others will think of reasons that don't come to mind) no need for a re-calibration.
If it is not a big cost, it is probably a better practice. You never know what eventuality may come up, and this draws a document traceability path. I remember in the Navy calibration program (way back when - maybe the same today) when ever we made something inactive, we also were required to to a calibration prior to putting inactive.
SteelMaiden
I probably would just to have a record that it was functioning properly (calibrated) so there would be no question about product produced after the last valid calibration and the time you destroyed it. I suppose it would depend on requirements for your industry, the past history of the measuring device etc. As long as you can justify what you do, you should be ok.
bobdoering
Stop X-bar/R Madness!!
Maybe not economic sense, but it does make sense. If you have made product with the device prior to decommissioning it, it would be good to know if it was reading correctly, or - if not - whether you need to recall product made using that gage.
Remember, calibrate does not mean 'adjust' - it means verify to the standard.
Welcome to the Cove. :bigwave:
Is your concern the fact that an item being disposed of was past its calibration due date at the time of disposal? In other words, is your concern that you'll have a record of a thing that wasn't calibrated when it was supposed to be, but has been gotten rid of? If this is the case, was the device taken out of service before its due date?
BradM
:agree1: Agreed. I still employ the practice.
If you are interested in the confidence in calibrated instruments and concerned with possible error in a calibrated instrument, disposing of an instrument does not immediately negate that concern.
If an instrument was used and any potential error from that instrument could have impacted a process, then I would say you would want some kind of verification that it was not way out of tolerance during use. Like Jerry suggested, if it's been sitting inactive and not used, then there is no need to calibrate.
The risk is that you could end up with some process deviations, and the piece of equipment that was disposed of, was part of that process. Could it have contributed to the deviations? That final check, IMHO, has value should a situation like this come up.:)
BradM
Exactly. :agree1: Sorry my post sounds like yours:eek:; I was compiling mine when you posted.
I know of a lot of people who buy thermometers (with a certificate), then toss them and buy new ones. My advice? Why bother with any of it? Just don't calibrate anything. :D
Most of the time I have never had an issue, as instruments being disposed weren't being used anyway (hence them being disposed:tg:). But you never know; I'd rather have the confidence. :agree1:
mecramur
Re: Disposal of Calibrated Equipment
Thank you for the inputs.
A little background information. I am re-writing our calibration SOP. The current SOP specifys that all disposed equipment be calibrated before it is taken out of the program. This is quite a restrictive statement and does not leave room for equipment that may not have been used during its last cal interval.
I agree with Jerry that calibrating an item that was never in use since it's lasts cal cycle, ie in storage, should be exempt from this requirement as it has no impact and is a unneccesary cost. This is the kind of information I am looking for.
Any other thoughts on exemptions from this policy?
S The US FDA requirements on Disposal of a medical device US Food and Drug Administration (FDA) 1
Q EU Rep for Packaging waste, WEEE and Battery disposal CE Marking (Conformité Européene) / CB Scheme 0
A Disposal of a Medical Device EU Medical Device Regulations 3
R Industrial accidents - Cleanup & disposal of blood spill Occupational Health & Safety Management Standards 1
T Waste Disposal - Medical Devices Other Medical Device Regulations World-Wide 3
WCHorn Rendering Scrap Unusable before Disposal (AS9100D, Section 8.7) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R Mobile Auto Valeting Services - Waste Disposal (Environmental Perspective) Miscellaneous Environmental Standards and EMS Related Discussions 3
B Safe Disposal of No Clean Soldering Flux in NY State Manufacturing and Related Processes 6
S Monitoring Disposal (Disposition) of Documents and Records Document Control Systems, Procedures, Forms and Templates 5
A Microbiological Laboratory Waste Disposal Procedure(s) do you follow? General Measurement Device and Calibration Topics 4
K Records Disposal Notice Form Records and Data - Quality, Legal and Other Evidence 6
K Certificate of Disposal and Authority to Dispose - Example Food Safety - ISO 22000, HACCP (21 CFR 120) 3
P Disposal of Plastic used in Medical Parts (Scrap) ISO 13485:2016 - Medical Device Quality Management Systems 4
S Production, Consumption & Disposal - That's the 'story of stuff' ! Misc. Quality Assurance and Business Systems Related Topics 0
T How to establish KPI Disposal and Follow Up Process Quality Tools, Improvement and Analysis 7
S Guidelines for Effective Solid Waste Disposal - Questions Miscellaneous Environmental Standards and EMS Related Discussions 6
D Decontamination of "Used" Complaint Product & Disposal of Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
P Obsolete Quality Records - Approval Prior to Disposal Records and Data - Quality, Legal and Other Evidence 15
D Critical Testing Point for Surgical Disposal Product Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C Simpler Solution to Waste Disposal Site Audits Miscellaneous Environmental Standards and EMS Related Discussions 2
V Can we use same autoclave (sterilizer) for media preparation & waste disposal? Hospitals, Clinics & other Health Care Providers 3
V Auditing Treatment, Storage and Disposal Facilities - Non-Visit Audit ISO 14001:2015 Specific Discussions 20
A Cost Effective Methods of Paint Sludge Disposal Miscellaneous Environmental Standards and EMS Related Discussions 4
A Retention and disposal of documents and records procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Disposal of Controlled Substances Manufacturing and Related Processes 8
G Waste Electrical and Electronic Equipment Disposal Procedure for Office PCs Miscellaneous Environmental Standards and EMS Related Discussions 6
M Wastewater Disposal - Vibratory tumbler systems that generate wastewater Miscellaneous Environmental Standards and EMS Related Discussions 14
A Is Waste Disposal addressed in ISO 17025:2005 ISO 17025 related Discussions 7
P Disposal of obsolete documents - Mandatory in ISO9001:2000 to keep previous versions? Document Control Systems, Procedures, Forms and Templates 7
Sidney Vianna Impressive environmental news from Toyota North America - Zero landfill disposal Miscellaneous Environmental Standards and EMS Related Discussions 9
K Disposal requirements - Contamination from waste products and medical device disposal ISO 13485:2016 - Medical Device Quality Management Systems 1
B Evidence of Disposition and Disposal of Quality and Related Records Records and Data - Quality, Legal and Other Evidence 36
F 8.2.1 Customer Satisfaction - Designing & Building a Solid waste disposal facility ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
J Retention of Quality Records - NC for "access and disposal of quality records" Records and Data - Quality, Legal and Other Evidence 3
J Disposal of White and Brown goods Decree Miscellaneous Environmental Standards and EMS Related Discussions 4
J Gear Surface Finish - Print with the word "calibrated" Manufacturing and Related Processes 2
M What kind of instrument that must be calibrated? General Measurement Device and Calibration Topics 3
G Can calibrated device values be used instead of manufacturers spec? General Measurement Device and Calibration Topics 2
M Where to obtain a calibrated DICOM image? ISO 13485:2016 - Medical Device Quality Management Systems 1
Q Calibrated Equipment Managment Software Suggestions General Measurement Device and Calibration Topics 12
J Calibration Justification - Requirements for Measurement with a Calibrated Device General Measurement Device and Calibration Topics 1
O Storage of Calibrated Tools General Measurement Device and Calibration Topics 12
I Uncalibrated source to calibrated meter, then compare to UUT General Measurement Device and Calibration Topics 4
K Looking for Calibrated Tool Shadowboard Substrate Ideas AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
N Calibration Traceability - Fluke 753 dpc with thermocouple Calibrated by Fluke ISO 17025 related Discussions 4
T Auditor states my Oven Thermocouples must be Calibrated General Measurement Device and Calibration Topics 18
L Should Air Screwdrivers be Calibrated? General Measurement Device and Calibration Topics 15
S Using Calibrated OD mic over non-Calibrated ID mic for final dimension Manufacturing and Related Processes 17
G Filling out inspection report using calibrated pins Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P What are the uncertain digits of a 1/64" calibrated ruler? Measurement Uncertainty (MU) 6
