Distance between two holes tolerance
jleond
Good morning,
I need to tolerance the 3D distance between the center of two holes, both have a true position tolerance of 1.5, What should be the distance tolernce between them, +/-1.5 or +/-3?:confused:
andygr
If you are going to set a true position for each hole then the distance will not be tolleranced but rather be basic.
Is it just a matter of knowing the seperation and the max allowable based on the holes individual TP or are you looking to restrict it even further?
jleond
Thanks Andygr, my customer just wants to know how much is allowable for the holes to be closer or farther between them. The 1.5 true position is already stated on the part print.
Duke Okes
I'm not a GD&T expert but it would appear to me that if you have already toleranced the position of each hole, then variation in the distance between them is already set by that. Each hole can be off a maximum of a certain amount in a particular direction, and you can total that variation to come up with the overall distance tolerance.
However, you might also want to think about it from a statistically based tolerance stackup perspective. What is the probability of being off by a certain amount for each hole, and how does that stack up. To me it would not simply be the mathematical sum of the two tolerances, but some amount less.
David DeLong
If your positional tolerance is a diametrical tolerance zone of 1.5 mm in a RFS mode (no circle M in the feature control frame), it means that the hole can shift off theoretical centres (true position) no more than 0.75 mm. The theoretical locations of each hole must be shown in a basic dimension.
Each hole can shift towards the other hole 0.75 mm or a combined value of 1.5 mm and away from each of 0.75 mm or combined value of 1.5 mm.
Looks like you have a +/- 1.5 mm tolerance between holes.
G
Gofar
In the UK, BSI publishes BS 8888 "Technical product specification" and, more importantly for me, two useful guides.
PP 8888-1 is a guide to the standard aimed at schools and colleges. It costs £25 or 5 copies for £75.
PP 8888-2 is aimed at further and higher education. Although it costs a faily steep £100, I find it very useful. It runs to about 260 pages and it would be inappropriate to paste the whole thing here, but maybe this short extract will be acceptable. It addresses your question and doesn't contradict the preious responses.
Perhaps your local standards body has an equivalent document.
jleond
That´s what I was thinking too, thanks!
This is great info, I will check the Geom. Prod. Spec and Y14.5M std to if I can find something extra, thanks for the info.
MIREGMGR
Good morning,
Not to open a can of worms, but is there a specific need for the "3D" statement?
A full 3D relationship statement for two non-zero-length (i.e. real, non-theoretical) holes requires consideration of the starting points not being in the same plane, and axis angle comparison from those starting points.
jleond
I said 3D because the CMM software can calculate the distance in 2D (1 axis) or 3D, in this case the holes lie on the same plane (Y) but haved different X and Z coordinates, just wanted to know how to give a correct tolerance to the distance.
mboucher
What Miremgr is referring to is that 3d includes the angle of the line that is drawn from one point to the other so bear that in mind when you look at the 3d distance output. If the diameters are on the same plane and measured at the same depth, providing you do not have automatic projection on, you should be okay but variations will appear if you measure at different depths. One way to avoid this is to project the diameters to the surface they are measured on before you ask for the distance.
Mark Boucher
V How to design a gauge (fixture) for measurement of distance between two hole Design and Development of Products and Processes 23
C Storage distance between flammable & non-flammable goods - guidelines/standards? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
D Interpolation of creepage distance IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
B IEC 60601 - Creepage Distance - Relay that acts as a means of physical mechanical protection Process Maps, Process Mapping and Turtle Diagrams 0
K IPC-610 Section 10.4.2.2 clarification - Distance to be measured Various Other Specifications, Standards, and related Requirements 0
S Some confusion about the creepage and clearance distance? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S Creepage distance IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
F Holes position inspection - Calculation of centre distance and plug sizes of a gauge Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
E Creepage distance accross insulation of step up transformer EU Medical Device Regulations 2
E Internal clearance distance according to 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M Bachelor of Engineering Course - Distance learning Training - Internal, External, Online and Distance Learning 2
L Patient Monitor Viewing Distance Usability Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
G Creepage and Clearance Distance for MOOP on Secondary Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
JoCam Equipment Guarding - Safe Distance - Is there a specified minimum distance? Occupational Health & Safety Management Standards 6
Steve McQuality Creepage Distance - Definition and Interpretation IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
Marc TV Viewing Distance Factor After Work and Weekend Discussion Topics 9
S Advice on Distance TS 16949 Auditor Training General Auditing Discussions 1
Stijloor Google Voice - Free long-distance? Oh yeah, Google's going there After Work and Weekend Discussion Topics 9
hogheavenfarm Reference Distance - Print which shows "1.656 REF" as a dimension Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
F Maximum walking distance for assembly line worker Human Factors and Ergonomics in Engineering 28
P What is Distance learning course? Training - Internal, External, Online and Distance Learning 8
Q Aerospace Quality related Distance Training/Learning/Exams Training - Internal, External, Online and Distance Learning 2
D Distance Education Question. (Online Degree) Training - Internal, External, Online and Distance Learning 5
Marc Distance Learning - From ivory tower to academic sweatshop Training - Internal, External, Online and Distance Learning 2
Wesley Richardson Internet distance training voice over IP (VOIP) for internet synchronous training Training - Internal, External, Online and Distance Learning 2
N Distance Learning - Quality Management and TQM - Seeking Recommendations Training - Internal, External, Online and Distance Learning 1
A Distance Learning where I would be able to obtain a 4 year degree in Quality? Training - Internal, External, Online and Distance Learning 7
N R&R for Differences between 2 measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S Distinction between a critical supplier and a Virtual manufacturer EU Medical Device Regulations 2
I Сorrespondence between hazards and risks ISO 14971 - Medical Device Risk Management 2
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Terminal Lugs sizes - Difference between 225/24 vs. 275/24 lugs Manufacturing and Related Processes 2
T Relationship between ISO 9001 and ISO – IEC BS EN 870079- 34 2020 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
Ron Rompen Surface Finish Correlation between Ra, Rz and Tp (bearing surface ratio) General Measurement Device and Calibration Topics 3
L MRA between EU and Switzerland - 1/2021 EU Medical Device Regulations 2
K Joint approval between OEM and Manufacturer on Design Documents ISO 13485:2016 - Medical Device Quality Management Systems 4
C Is my software an accessory? Telecommunication between HCP and patients EU Medical Device Regulations 10
K Verify Software Architecture - supporting interfaces between items IEC 62304 - Medical Device Software Life Cycle Processes 2
E ASTM F2118 - Fatigue testing of bone cement - Changes between the 2003 and the 2014? Other Medical Device Related Standards 1
DuncanGibbons How is the arrangement between Design and Production organisation envisaged? EASA and JAA Aviation Standards and Requirements 4
M Risk Analysis Flow - Confusion between ISO 14971 and IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
K %GRR was between 10-30% so we have to have a "backup plan" per auditor IATF 16949 - Automotive Quality Systems Standard 15
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 3
